uus teema   vasta Tarkvara »  Linux & UNIX »  HDMI kaardi draiverid märgi kõik teemad loetuks
Karlsson
sõnum 10.10.2020 10:10:41 HDMI kaardi draiverid vasta tsitaadiga
Kuidas installida Linux Mint 20 all HDMi kaardi draiverid?
lspci -vvvnn
05:00.0 Multimedia controller [0480]: Philips Semiconductors SAA7160 [1131:7160] (rev 03)
   Subsystem: Philips Semiconductors SAA7160 [1131:0002]
   Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
   Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
   Latency: 0, Cache Line Size: 64 bytes
   Interrupt: pin A routed to IRQ 11
   Region 0: Memory at f7c00000 (64-bit, non-prefetchable) [size=1M]
   Capabilities: <access denied>
--edit--
Vahepeal sai pusitud.
https://bitbucket.org/powARman/v4l-dvb-saa716x/src/master/
Git clone ja sudo make lõppes veaga:
make[2]: Leaving directory '/home/user/Downloads/v4l-dvb-saa716x/v4l/firmware'
Kernel build directory is /lib/modules/5.4.0-48-generic/build
make -C /lib/modules/5.4.0-48-generic/build SUBDIRS=/home/user/Downloads/v4l-dvb-saa716x/v4l CFLAGS="-I../linux/include -D__KERNEL__ -I/include -DEXPORT_SYMTAB" modules
make[2]: Entering directory '/usr/src/linux-headers-5.4.0-48-generic'
make[3]: *** No rule to make target 'arch/x86/tools/relocs_32.c', needed by 'arch/x86/tools/relocs_32.o'.  Stop.
make[2]: *** [arch/x86/Makefile:232: archscripts] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-5.4.0-48-generic'
make[1]: *** [Makefile:44: default] Error 2
make[1]: Leaving directory '/home/user/Downloads/v4l-dvb-saa716x/v4l'
make: *** [Makefile:27: all] Error 2
viimati muutis Karlsson 11.10.2020 14:08:57, muudetud 1 kord
Kommentaarid: 88 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 79
sõnum 10.10.2020 11:05:07 vasta tsitaadiga
misasi on HDMI kaart?
sul on seal mingi tootja mingi konkreetne raud. tuvasta see ja installi.
Ketas, ketta, ketast, kettasse, kettas, kettast, kettale, kettal, kettalt, kettaks, kettani, kettana, kettata, kettaga. <--SPIKKER! https://www.yaga.ee/mox-fulder
https://www.facebook.com/marketplace/profile/100087345405856/ värskeim loetelu.
Kommentaarid: 1104 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 704
Karlsson
sõnum 10.10.2020 17:53:03 vasta tsitaadiga
Kaart on Timeleak HD72A. Aga draiverid peaks ju kiibipõhised olema?
Supiplex
Supiplex
sõnum 11.10.2020 21:05:04 vasta tsitaadiga
Seda faili ei leita https://github.com/torvalds/linux/blob/master/arch/x86/tools/relocs_32.c
Sul tunduvad mingid kerneli headerid olemas olevat, aga sellest nähtavasti ei piisa (ega ma oma headerite seast taolist faili samuti ei leia). Võid proovida terve kerneli sortsu alla sikutada (sudo apt install linux-source).
Samas 6-7 aasta vanust draiverit, mida mainline pole üles korjanud, käima saada tundub üsna väljakutsuv - jõudu!
The young lady had an unusual list,
Linked in part to a structural weakness.
She set no preconditions.
Kommentaarid: 38 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 34
Karlsson
sõnum 17.10.2020 01:18:07 vasta tsitaadiga
Nii alustasin teise lähtekoodiga. https://www.linuxtv.org/wiki/index.php/TBS_driver_installation Luis Alves variandiga.
Git clone ja vastavalt õpetusele. Samuti relocs_32.c ei leitud. Installisin
ja
# sudo cp /usr/src/linux-source-5.4.0/linux-source-5.4.0/arch/x86/tools/* /usr/src/linux-headers-5.4.0-51-generic/arch/x86/tools/
siis uus ikaldus on selline:
arch/x86/tools/relocs.h:18:10: fatal error: tools/le_byteshift.h: No such file or directory
   18 | #include <tools/le_byteshift.h>
Mis paki nüüd installima peaks?
olavsu1
külaline
sõnum 17.10.2020 01:37:50 vasta tsitaadiga
pane see puudu olev *.h fail otsingusse ja saad vihjeid.
see on androidi värk? androidi devel pakid siis vajalikud...
Karlsson
sõnum 17.10.2020 13:44:01 vasta tsitaadiga
Ei ole Androidi värk. Linux Mint on.
olavsu1
külaline
sõnum 17.10.2020 13:47:37 vasta tsitaadiga
aga sorts, mida sa kokkulasta soovid paistab olevat androidile.
Karlsson
sõnum 18.10.2020 02:38:28 vasta tsitaadiga
Millest sa seda järeldad?
olavsu1
külaline
sõnum 18.10.2020 13:42:57 vasta tsitaadiga
et androidi kerneli teeke nõuab.
mis nimega arhiivist see kood pärineb? enamasti ütleb arhiivi nimi, mis sorti platvormile on tema sisu.
seni antud info järgi vajad androidi kerneli devel pakke.
Karlsson
sõnum 19.10.2020 04:07:08 vasta tsitaadiga
Arhiivi pole. Kasutasin seda
git clone https://github.com/ljalves/media_build.git
olavsu1
külaline
sõnum 19.10.2020 09:20:59 vasta tsitaadiga
sa oled saand kuskilt aegunud viite eksperimentaalsele asjale, mis ei peagi käima minema.
tõmba siit kogu kood: https://github.com/ljalves/linux_media
kirjas on, et peab toetama ka tavalist linuxit.
https://github.com/ljalves/linux_media/wiki
seal on kirjas mida tööle saad.
Karlsson
sõnum 19.10.2020 18:15:05 vasta tsitaadiga
Oleme vist alguses tagasi..
Puhastasin ja reinstallisin linux-source ja linux-header pakid.
Tegin selle wiki järgi https://github.com/ljalves/linux_media/wiki
ja make osas:
olavsu1
külaline
sõnum 19.10.2020 18:24:40 vasta tsitaadiga
kuidas see nõidus aitab...
In the make file, just change SUBDIRS=$(PWD) into M=$(shell pwd)
teine lahendus on 32 bit linux ( i386 ) päisefailid vaja paigaldada.
