praegune kellaaeg 24.05.2024 11:30:23
sõnum |
30.04.2020 14:36:19
Kui delli bios i uuendus ei õnnestu (15r n5010 näitel) |
Venelased ütlesid, et "ära sega masinat töötamast". mul oli vaja hakata uuendama töötava dell inspiron 15R N5010 biosi. Loomulikult delli lehel oleva exega, windowsi all. aku täis ja toitejuhe taha ja klikk.. tuleb uuendamise aken, kus graafiliselt on näha, mida tehakse, valged kastid kustutatud, punased kastid kirjutatud, rohelised kastid kontrollitud. kustutab hulka sektoreid tühjaks ja ühtäkki teatab, et "aku on saanud tühjaks" ning läheb pildituks. aku on 100% laetud, umbes kahetunnine.
ootan natuke, võtan aku tagant ära ja toitenupu vajutamisel piiksub. selge. tellis. kiirelt guugeldama ja tuleb välja, et on olemas bios recovery mode.
https://www.wimsbios.com/forum/notebook-bios-and-other-problems-f38/dell-inspiron-n5010-ami-bios-recovery-t12181.html#p56085 <- jõuan siia. kirjutab:
tsitaat: |
Hi,I was performing a BIOS update on Dell Inspiron N5010(using Win7 64bit) to Latest bios version A10 when the
laptop became inactive plus the fan started to run at full speed. i could not even switch off the machine by pressing the power button. At the end i had to pull out AC cord and BAttery.Now the its dead
(No activity at all).
After searching around i found that there is some bios recovery solution.
the solution was taking Phoenix Bios But mine Is American AMI(i read the word american on top left corner of bios menu screen before flashing).
The bios i used was A10
http://ftp.us.dell.com/bios/N5010A10.EXE
after spending some time i was able to extract n5010a10.hdr and n5010a10.rom file from the bios exe File using the following switch
C:\>N5010A06.exe /writeromfile
C:\>N5010A06.exe /Writehdrfile
here are the 2 files.
http://www.mediafire.com/?r6a36mduwjcoiu0
Now i am stuck. I don't know to follow any procedure for AMI Bios.
I don't want to create more mess.
Plz Help. |
mida öelda taheti oli see, et
1. varustad ennast ühe mälupulgaga, mis on FAT (mitte fat32 ega ntfs vms) ei pea olema buutiv.
2. tõmbad delli veebist biosefaili, näiteks
http://ftp.us.dell.com/bios/N5010A10.EXE tegelikult on uusim bios sellele masinale A15, failinimega n5010a15.
3. kui see tõmmatud, tuleb selle exe seest kätte saada kaks faili: *.HDR ja *.ROM
neid delli exe faile 7zipi või winrariga lahti ei saa, tuleb teha keerulisemalt.
programm selleks on su arvutis command promt (cmd) näol olemas. sul on vaja vastav käsk käivitada kaustas, kuhu pole ligipääsupiiranguid. nt. vaikimisi on c: kettal kirjutamispiirang. käsk tahab exe seest lahti pakitud faili kirjutada sinna samma kausta aga kuna ta ei saa seal kirjutada, saad veateate. mina tegin nii, et tegin documendid (documents) kausta alamkausta dell ja kopeerisin n5010a15.exe sinna.
3.1.Et saada delli biose käivitad cmd adimistraatorina. avanenud aknas liigud CD (change directory) käsuga kausta: c:\users\lauri\dell ning seal veendud käsuga "DIR", et su n5010a15.exe näha on.
3.2. Et saada delli biose uuendamiseks kaks vajalikku faili *.rom ja *.HDR, tuleb nüüd kasutada kahte käsku:
süntaks(syntax)
N5010A06.exe /writeromfile mis kirjutab samasse kausta faili N5010A15.ROM
N5010A06.exe /Writehdrfile mis kirjutab samasse kausta faili N5010A15.HDR
*esimeses õpetuses saab siin tarkus otsa.
4. Saadud *.HDR ja *.ROM tuleb nüüd kopeerida vajalikule FAT failisüsteemiga mälupulgale NING NIMETADA ÜMBER nii, et saaks MUDELINIMI.HDR ja MUDELINIMI.ROM ehk siis failid
n5010a15.rom ->N5010.ROM
n5010a15.hdr ->N5010.HDR
5. kui failid on pulgal, võtad dellil ära aku ja toitejuhtme ning pistad mälupulga USB pessa.
6. vajutad ja hoiad all klaviatuuril klahvi END ning paned toitejuhtme arvuti külge tagasi. arvuti lülitub sisse, END klahvi enne lahti ei lase kui ekraan lööb helendama ja tuleb kiri BIOS RECOVERY CONSOLE ning pakub välja biosi, mis on su pulgal.
* kui lihtsalt masin sisse lülitada siis see piiksub, kui masina küljes on pulk aga failid on vale nimega ning sa hoiad END klahvi all, on piiksud lühemad ning kõlavad erinevalt. (osad mälupulgad ei pruugi masina jaoks arusaadavad olla)
MA EI GARANTEERI, ET SINU ARVUTIT ON VÕIMALIK NIIVIISI PARANDADA, MA EI VÕTA VASTUTUST VÕIMALIKU EDASISE KAHJU EEST MIS VÕIB VÄÄRAMATU JÕU TAGAJ'RJEL SÜNDIDA, LIHTSALT KIRJELDAN ERINEVATEST ALLIKATEST LEITUD PROTSEDUURE, MILLE KOKKU PANEMISEL ÕNNESTUS EBAÕNNESTUNUD BIOSE UUENDUSEGA 15R5010 ELLU ÄRATADA. oluliseks võib saada, kas sinu masinas on tavaline või UEFIbios.
https://www.linkedin.com/pulse/solved-recover-dell-inspiron-laptop-corrupted-bios-how-roland-ihasz
teine õpetus, millest leidsin ka failide nimetamise vajaduse.
_________________ Ketas, ketta, ketast, kettasse, kettas, kettast, kettale, kettal, kettalt, kettaks, kettani, kettana, kettata, kettaga. <--SPIKKER! https://www.yaga.ee/mox-fulder
https://www.facebook.com/marketplace/profile/100087345405856/ värskeim loetelu. 25.05 ilmselt Tallinnas |
Kommentaarid: 1104 loe/lisa |
704 |
lisa lemmikuks |
