_________________ "I have never followed a rule. That is my rule. Do you follow? I don't." The Joker
Lexuse summutist tuleb vaid lilleõisi ja ükssarvepeeru - HV foorum M: E36 varuosad
osta touareg, ma sain 11 kuud remontimata sõita _________________ "I have never followed a rule. That is my rule. Do you follow? I don't." The Joker
enam ei ole õhkvedrustusega, pigem vedrustuseta _________________ "I have never followed a rule. That is my rule. Do you follow? I don't." The Joker
Aastate jooksul märganud, et siin on palju lexuse fänne. Teemakohane küsimus ka, GS300 või GS450h (plussid/miinused) ? 07-08a.
Kust sa osta kavatsed sellise? Eestis peaks vist reaalselt 1-2 autot olema, mis ostmist väärivad järelturult. _________________ www.FunBox.ee - kvaliteetsed õhupallid, lahedad kingitused jpm vajalikku hea peo korraldamiseks!
Adding the ozonator to the powertrain control scheme helps to solve several shortcomings of the hybrid HCCI design along with adding improvements in fuel economy. Since ozone (O3) is more combustible than the fresh (O2) that is usually brought into the cylinder, it can be injected in order to run the low-load compression mode when the ambient temperature is cool. Extending the running time of the low-load mode helps to improve fuel economy along with reducing emissions.
The second part of the equation is that injecting ozone allows for the engine to run under stoichiometric conditions when in low-load which allows the implementation of a standard three-way catalytic converter instead of using an expensive after treatment system like you might find on a diesel vehicle. Another benefit of ozone injection is an overall reduction in the output of nitrogen oxides (NOx). Studies have shown that NOx is greatly reduced when combined with ozone and directed to a catalytic reactor.
mis filmis stalloonel selline oli..? _________________ Ketas, ketta, ketast, kettasse, kettas, kettast, kettale, kettal, kettalt, kettaks, kettani, kettana, kettata, kettaga. <--SPIKKER
mõned sülerid, mis hetkel müüa on -> https://www.facebook.com/marketplace/profile/100087345405856/ värskeim loetelu. Ei mingit otsa.ee d. kätte saad asap.
Kellelgi on kogemusi, mis aastakäigust alates autoliisingu intressimäärad tarbimislaenu kõrguselt ühekohaliseks muutuvad?
Küsiks üldse niipidi, et millise aastakäigu autoga autoliising kahe kohaline või üldse üle viie protsendi on? Ehk ajad segamini autolaenu ja autoliisingu?
noh, kus kultusmehed nüüd on jutuga, et mis imejurakas see on, mida veel 12+ aasta vanusena liizingusse peab võtma? _________________ Ketas, ketta, ketast, kettasse, kettas, kettast, kettale, kettal, kettalt, kettaks, kettani, kettana, kettata, kettaga. <--SPIKKER
Krt, ilge himu on endale kah mingi roigas soetada, millega kaugemaid reise kannatab teha.
Chrysler Grand Voyager/Pacifica/Town&Country, Lancia Voyager, Mitsu Grandis, Toyota Previa, vbla veel mingi mida ei tea.
Millest tuleks mööda vaadata?
