praegune kellaaeg 09.06.2024 22:31:14
sõnum |
07.01.2016 00:38:15
Uus WiFi-standard: 802.11ah (WiFi HaLow) ja on mõeldud peamiselt Asjade Interneti (IoT) tarbeks. |
Taas väljas uus WiFi-standard: 802.11ah (WiFi HaLow) ja on mõeldud peamiselt Asjade Interneti (IoT) tarbeks.
tsitaat: |
For the last decade or so, wireless networking has been entirely about short range, high speed communications. The type of networking needed by an Internet of things is fundamentally incompatible with WiFi, and the reason for this is due to the frequencies used by WiFi networking gear. 2.4 and 5 GHz are very fast, but cannot penetrate through walls as easily as lower frequencies.
This week the WiFi alliance introduced IEEE 802.11ah into the WiFi spec. It’s called WiFi HaLow (pronounced like angel’s headwear), and unlike other versions of 802.11, WiFi HaLow uses low frequencies for low bandwidth but a much larger range.
WiFi HaLow uses the 900 MHz ISM band to communicate, divided into 26 channels. The bandwidth is low – a mere 100 kbps, but the range is huge: one kilometer, or about four times the approximate range of 802.11n.
This is not the only WiFi spec aimed at the Internet of Things. In 2014, the WiFi alliance introduced 802.11af, a networking protocol operating in unused TV whitespace spectrum between 54 and 790 MHz. 802.11af has a similar range as 802.11ah – about one kilometer – but products and chips utilizing 802.11af have been rare and hard to find.
WiFi Alliance Introduces 802.11ah
http://hackaday.com/2016/01/05/wifi-alliance-introduces-802-11ah/
Kommentaarid: 284 loe/lisa |
211 |
reints
07.01.2016 13:09:30
Kas enam ei peagi uudiseid eesti keelde tõlkima või ?
Lajataks ise ka terve hunniku uudiseid aga tõlkida pole aega
Äkki teeb sinust ka |
Kommentaarid: 221 loe/lisa |
203 |
Psych0
07.01.2016 13:16:12
reints, aga lajata. Mina sain oma info siit igal juhul kätte, tänan.
Kommentaarid: 61 loe/lisa |
57 |
07.01.2016 13:27:59
reints, see teema oli uudisvihjete all, kuhu igaüks saab kirjutada.
Pmst piisabki paarist eestikeelsest lausest, ülejäänud võib inglisekeelne olla.
Parem midagi, kui üldse mitte midagi.
_________________ HV valuutakalkulaator |
Kommentaarid: 461 loe/lisa |
12 :: |
7 :: |
356 |
robertjako
09.01.2016 05:30:31
Väga hea uudis. Bluetooth Low Energy põhised seadmed pole laialdast levikut veel saavutanud ning nii tegijate kui ka ettevõtjate esimene soov on alati olnud Wifi / interneti põhine nutiseadmete vaheline ühendus.
_________________ Kõik arvamused esitatud eraisikuna. |
Kommentaarid: 2 loe/lisa |
lisa lemmikuks |
