sõnum |
h3rr
12.05.2017 12:05:47
yerba kirjutas: |
h3rr kirjutas: |
yerba kirjutas: |
ufo56 kirjutas: |
tsitaat: |
Näiteks tegin hiljuti ühe ülekande ja confirmimine võttis aega 45 minutit.
Pikemad ajad endal olnud 4-5 tundi. |
Uue aadressiga sai oodatud 3 ööpäeva... |
Proovisin esimest korda Poloniex-st coinbase kanda litecoin-e. 5 minutiga olid coin-d kohal. |
Err, Sa ju kirjutad litecoinidest.
http://www.coindesk.com/information/comparing-litecoin-bitcoin/
Transaction differences
The main difference is that litecoin can confirm transactions must faster than bitcoin. The implications of that are as follows:
•Litecoin can handle a higher volume of transactions thanks to its faster block generation. If bitcoin were to try to match this, it would require significant updates to the code that everyone on the bitcoin network is currently running.
•The disadvantage of this higher volume of blocks is that the litecoin blockchain will be proportionately larger than bitcoin's, with more orphaned blocks.
•The faster block time of litecoin reduces the risk of double spending attacks – this is theoretical in the case of both networks having the same hashing power.
•A merchant who waited for a minimum of two confirmations would only need to wait five minutes, whereas they would have to wait 10 minutes for just one confirmation with bitcoin.
Transaction speed (or faster block time) and confirmation speed are often touted as moot points by many involved in bitcoin, as most merchants would allow zero-confirmation transactions for most purchases. It is necessary to bear in mind that a transaction is instant, it is just confirmed by the network as it propagates. |
Tean jah, lihtsalt kuu aega tagasi oli coinbase-s ainult Eth ja bitcoin toetatud
Augustus
12.05.2017 16:43:06
Bursti hüpe |
Kas keegi oskab kommenteerida, millest võiks olla tingitud Bursti väärtuse tõus vähem kui ööpäevaga 3,5-kordseks (200----676)?
murka390
12.05.2017 18:32:34
Re: Bursti hüpe |
Augustus kirjutas: |
Kas keegi oskab kommenteerida, millest võiks olla tingitud Bursti väärtuse tõus vähem kui ööpäevaga 3,5-kordseks (200----676)? |
Mina, mina!
Pulli värk ehk. Kui muid uudiseid avalikult pole.
kert06
15.05.2017 18:57:08
Monero üsna stabiilne, pigem isegi passiivne olnud viimasel ajal. Enda arust täitsa normaalne krüptoraha, aga ei taju eriti, miks see nii ebapopulaarne on.
h3rr
15.05.2017 19:20:42
kert06 kirjutas: |
Monero üsna stabiilne, pigem isegi passiivne olnud viimasel ajal. Enda arust täitsa normaalne krüptoraha, aga ei taju eriti, miks see nii ebapopulaarne on. |
Nad ei panusta peaaegu üldse enda promomisse. Kunagi need arendajad seda ise ka öelnud, et kui õnnestub, siis lihtsalt sellepärast, et hea projekt.
Chaza!
m
17.05.2017 20:50:23
Keegi on eestis btc müünud, on huvilisi?
Tulevikus tahaks rahaks teha kunagi.
_________________ Müün erinevaid klaase, peegleid ja klaaspakette. |
h3rr
17.05.2017 21:20:16
Internet suur ja lai, kus seda müüa
m
17.05.2017 21:36:30
Internet on suur ja lai jah aga tunnen huvi just selle vastu kas eestis ka turgu on
h3rr
17.05.2017 22:26:31
No pmst kogu bitcoini kaubandus käib virtuaalsetes vahetuspunktides nagu poloniex ja kraken. Ei usu, et Eestis väga keegi niisama kuskil foorumist otsiks bitcoine, mida osta.
mteachx
17.05.2017 22:31:25
h3rr kirjutas: |
No pmst kogu bitcoini kaubandus käib virtuaalsetes vahetuspunktides nagu poloniex ja kraken. Ei usu, et Eestis väga keegi niisama kuskil foorumist otsiks bitcoine, mida osta. |
Wrong
_________________ Vahetan tabletite/telefonide ekraane.Küsi lisa!
SisNok OÜ - Sinu isiklik nutipartner |
Ollaz
23.05.2017 18:33:07
Ostsin ennast rongile mõni päev tagasi. Täna võib poest jäätist tuua küll
qwerty007
23.05.2017 21:55:10
Ollaz kirjutas: |
Ostsin ennast rongile mõni päev tagasi. Täna võib poest jäätist tuua küll |
Mul joppas bytecoiniga, ostsin olematu hinnaga, nüüd paugutas taevasse
yerba
24.05.2017 17:04:41
Kuna öö otsa jändasin ühe mineriga, mis kohe kuidagi ei tahtnud käima minna, siis sai kohandatud üks palve. Ning peale selle lugemist kargasid kõik kaardid kenasti käima.
Meie eeter, kes Sa oled võrgus!
Pühitsetud olgu Sinu blokk. Sinu onublokk tulgu.
Sinu blokiahel sündigu nagu võrgus, nõnda ka kaevuri masinas.
Meie igapäevaseid eurosid kanna meile tänapäev.
Ja anna meile andeks koolenud videokaardid, nagu meiegi andeks anname väsinud toiteplokkidele.
Ja ära saada meid SEB panga rüppe, vaid päästa meid ära palgatööst.
Sest Sinu päralt on krüptorahandus ja blokiahel ja kaevurid igavesti.
Aamen.
elukaz
24.05.2017 19:12:22
Klopsi üks palve kursi langemise vastu ka, varsti võib vaja minna.
Heade hindadega võib päris kiirelt ära harjuda. Klassik ja monero ka lõpuks tiibu saamas.
Chaza!
24.05.2017 20:58:55
Väga hea luule.
Aga jah õigel ajal hüppasin btc-lt eetrir rongile. Nüüd lausa rõõm tuleb peale, kui kurssi vaadata. Peaks Monerot ka juurde krabama äkki. Kardan, et praegu ostes tuleb varsti üks korrektsioon.
_________________ Linux - Future
1984 was not supposed to be instruction manual |
murka390
24.05.2017 21:32:02
ETC võib hoida ETHi 10% tuules. Niiet kasvuruumi on praeguse seisuga veel. Aga see on ainult minu arvamus.
Kihvt kaader tänasest ETH/XBT graafikust TabTraderis - https://drive.google.com/file/d/0B7m_WsJ6EJJ1dzIxXzM3MzZmZE0/view?usp=sharing
Ei tea kas mujalgi selline jälg jäänud?
Edit: Tunne on selline, et krabada võiks kõike ja siis hoida niikaua kuni kannatab. Isegi kui üks kaob ära, asendub teise ja paremaga. Kui alguses sinna kopika sisse oled pannud, teenib tasa.
blokiahela trend tundub aina tõusvat. Aga mis elu see on?
teretalv
25.05.2017 21:33:13
Kui kõik hakkavad raha bitcoini panema siis kas see võib muutuda ohuks muudele valuutadele põhjustades pangajooksu ja hüperinflatsiooni? Muutes seejuures jälle ka väärismetallid seksikaks.
Mõtlen aastaid hiljem, mida rohkem tõestab bitcoin end seda vähem inimesed usuvad mängu monopoliraha printijate õhust loodud raha, praegune euro ja dollar ei ole vabaturumajanduse põhiselt tekkinud väärtus vaid kuntslikult üles pumbatud hirmul ja ahnusel põhinev illusioon edukusest ja väärtusest.
Euro ja dollar põhineb vaid orjanduslikul ühiskonna korraldusel: "kui sa ei maksa iga kuu siis jääd oma kodust ilma ja võid vangi ka veel minna..." Hirm on euro ja dollari ainus väärtuse tagaja, samas bitcoini ja käega katsutavate varade väärtuse aga tagab kindluse tunne mis tekib seda omades.
Nii nagu kõik riigid viimasel ajal võlts sildistavad üksteist protektsionismis siis dollar ja euro ja fiat raha on oma olemuselt üks "donald trumpi poolt soositud vihatud protektsionism" Tähendab ei nähta palki enda silmas, et ise ollakse veel hullemad või samasuguse poliitika salaja pooldajad kas salakavalalt teadlikult või puhtast rumalusest enda teadmata.
Vabaturumajanduse solkijad on ära teeninud korraliku rahanduskriisi, nii loogilisest, filosoofilisest, religioonilisest, inimlikust kui ka karma vaatepunktist.
Kõigele lisaks sonitakse mingisugusest majanduskasvust, majanduskasv ise on oma olemuselt ebaloogiline ootus mis eeldab et vahendeid on lõpmatuseni käes mida muidugi julgustab uskuma rumalad kosmosekaevanduse jutud. Fakt on see, et rahal puudub vääärtus kui kõik puud maha saetakse, keskkond ära reostatakse, kõik loomad ja taimed ära süüakse majanduskasvu nimel, rääkimata veel kahjustatud inimpsühholoogiast sel kommunistliku alatooniga visiooniga majanduskasvu uskumise teel hitlerliku järjekindlusega.
Rahanduslik mitmekesisus on tulevik kus samaaegselt eksisteerib nii bitcoin kui väärismetallid. Igaühele oma, vabaturumajanduse tingimustes on see võimalik. Kõige suurem oht vabaturumajandusele on riigid ise kes sonivad pidevalt mingist vabaturumajandusest, riik oma olemuselt on vabaturumajanduse kõige suurem solkija, jällegi ei nähta palki oma silmas ja nähakse turusolkijaid pigem kapitalistides kui protektsionistides.
Kas on kuskil mõnd foorumit veel eestis kus saab vabalt rääkida ja konstruktiivselt arutleda bitcoinist ja rahast ilma, et peaks kartma et postitus kustutataks nagu delfis?
_________________ Ära usu kes kutsuvad kuskile raha investeerima. Suurt tootlust ei tule keegi kandikul kätte tooma! Head ja kindlat tootlust saab ainult siis, kui ise enda kontrolli all on kogu protsess või enamus sellest.
Teen Hobikorras Audio, Video, Foto ja Trükiettevalmistust/Kujundust ja Python Scripte |
ufo56
25.05.2017 21:39:45
tsitaat: |
Saad rääkida siin ju kenasti...
_________________ Lae pildid -> pilt.io |
Killer85
25.05.2017 22:08:29
Sellist iba võiks vandenõuteemas vast ajada.
teretalv
25.05.2017 22:21:04
tsitaat: |
Bitcoin sai alguse just tänu reaalelulistele vihale ajavatele ja frustreerivatele faktidele mida enamik nimetavad vandenõuks.
Sai alguse sellest et inimestel on kõrini totaalkontrollipõhisel vabaturumajanduse solkimisel baseeruvast majandus ja rahasüsteemist kus puudub austus isegi kastusel oleva valuuta suhtes, pead maksma suuri teenustasusi ja päevi ootama pankadevahelisi ülekandeid... Kui see kõik on vandenõu siis soovitan bitcoini teemat mitte jälgida. Bitcoini puhul on vähemalt vabadus au sees ning inimlikud teenustasud, ülekande kiirused ja vabaturumajanduse solkimise mõju on minimaalne kuid mitte olematu siingi. See kes bitcoini leiutas sai aru, et see pole lihtsalt vandenõu vaid reaalelulistel faktidel ja olukordadest tulenev kasvav nõudlus sellise asja vastu mis on just selle "vandenõu" ohtude minimeerimiseks.
elukaz
26.05.2017 00:35:04
Asoh, vot siis kust btc alguse sai
Chaza!
26.05.2017 08:04:19
Kuigi teretalv väljendab ennast väga ekstreemselt, siis olen nõus selle koha peale, et riikidel ei tohiks olla kontrolli raha (trükkimise) ja muu seesuguse üle.
Tundub, et tõusmine on nüüd läbi saanud ja nüüd on kohal tammumine või väike langus isegi.
Ollaz
26.05.2017 10:19:05
Mu meelest sai Bitcoin alguse Satoshi Nakamoto nimelise aliase alt väljastatud white paperi ja koodijupiga, aga võin ka valesti mäletada..
degreal
26.05.2017 10:32:22
Ollaz kirjutas: |
Mu meelest sai Bitcoin alguse Satoshi Nakamoto nimelise aliase alt väljastatud white paperi ja koodijupiga, aga võin ka valesti mäletada.. |
Õige jutt. Satoshil võis oma maailmavaade olla küll aga Bitcoini tegi võimalikuks ikkagi tehnoloogiline läbimurre.
