praegune kellaaeg 23.05.2024 22:11:52
sõnum |
24.01.2014 10:24:04
Carbon Nanotubes Could Solve Overheating Problem for Next-Generation Computer Chips |
IEEE Spectrum pajatab siis oma uutes uudistes, et:
Computer chips used in next-generation smartphones and supercomputers can't get much faster without overheating. That's why engineers hope carbon nanotubes offer a possible cooling solution that could enable processing speeds to continue accelerating.
The overheating problem has become steadily worse as engineers cram more power-hungry transistors into the same microchip space, because much of the electricity that powers the transistors is wasted as heat. Carbon nanotubes have high thermal conductivity that could carry the excess heat away from the microchips, but only if engineers can figure out how to improve the heat transfer at the point of contact between the nanotubes and microchips.
Kogu jutt ise pikemalt lingil:
http://spectrum.ieee.org/tech-talk/computing/hardware/carbon-nanotubes-could-solve-overheating-problem-for-nextgen-computer-chips
lisa lemmikuks |
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
