Modified PvP weapon damage modifier so players will deal about 20% more weapon damage to each other (note that this change does not impact skill damage)
Added more kill volumes to Dragon’s Nest map. When exiting the map area, characters will be automatically killed
Ehk siis need kellele juba praegu ei meeldi PVP osa DZ-is, siis neil pole enam üldse asja sinna tsooni
See season pass omanikud saavad iga kuu 1-l ja 15-l supply drop-I väljaspool tumedat tsooni.
Ja kui sul on rohkem kui üks karakter tehtud level 30, siis saad mõlemaga neid lahti teha.
Mul on pmst 2 level 30 peal ja kolmas on level 14 et ainult DZ mängida level 14 peal olles.
Pmst esimese karakteriga sain mingi 229GS gear kollase ja mingi 229 AUG saastade talentidega ja siis 268GS tactician vesti.
Teise karakteriga sain ühe alphabridge 268 GS ja teine oli nomad mingine 268GS ja mp7 229 relva.
Esimese karakteriga ei olnud isegi botte ja sain drop-I avatud lihtsalt.
Teise karakteriga oli vist 4-5 level 32 botti kaitsmas.
Need supply drop-id ei kao kuhugi ja võid avada neid 2 nädala jooksul kuni uus tekib.
Kui uus tekib siis vana kaob.
Here are the list of changes to be implemented with the July 28th maintenance.
Fixed a bug where players could initiate 1 Phase Operations in Heroic difficulty by pressing a combination of buttons on their input device.
Rewards from Underground Operation Directives will now also include all gear sets from Updates 1.1 and 1.2 and you have a chance to receive additional loot when completing Operations with 4+ Directives.
Rewards from Underground Sealed Caches will now include all weapon types as well as all Underground and Update 1.3 gear sets.
Named NPCs in the Underground now have increased drop rates across all difficulties and doing multiple phase operations will give you a better chance at higher quality gear.”
nii katki ,et kui välja tulin mängisin 2nädalat ja sain aru ,et asi on lootusetu.
mäng ammu unistallitud möödas mingi 2 kuud ja ei mõtle ka peale panna.
unustatud teema never again ubish1t
Mäletan siven kui algus eitahtnud uskuda mind ja pedereerisid mind, et ole vait see game of the year mäng Keegi eusknud mind tegelt aga see selleks.
Ise loodan siiski siiralt, et watch dogs tuleb korralik ja southpark, see wildlands on minuarust ikka jube puine ja jääb isegi divisionile alla. _________________
mäng oli fun 2 nädalat ei kurda lihtsalt on siiralt kahju ,et sellise massive potentsiaaliga asi rikutakse ära:S
wildlands on jah kahjuks juba maha kantud. watch dog tundub ka selline 5/10 pela olevat 20 euri maks.
Kõige parem on see, et teevad expansione MAA ALLA.. kui nende mängu ilu oli terves hämmastavalt suures New Yorki linnas.. fuck dis. _________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
Mulle meeldib see mäng! Ainuke asi mis häirib on see, et DZ vastane nii tugevaks tehti Kuradi rakse on arvuti vastu seal saada. Ise grindin Metroos enamasti.
grindiks ka aga mis point on?
ausalt teel selles mängus kaugele ei jõua...
kuradi haxorid ja exploiterid jooksevad sellise geariga ringi ,et paha... sa ei grindi elus neile järgi.
ja kaua sa seda pve ikka toksid põhirõhk siiski ju pvp osal vähemalt minu jaoks.
Jabur on lugeda ja vaadata seda steam mängijate numbreid. Kahju et uplay's seda pole.
Mis teeb asja veel jaburamaks on see, et mäng koos sp-ga on ikka 60 euro.
Kui see langeks kuskile 40 peale, siis ehk saaks mängijaid juurde ka.
Algse hype-ga sai see mäng kindlasti kuldseid kasumeid. Nüüd lihtsalt suurem osa mänguritest on huvi selle mängu vastu kaotanud.
Eile olin jälle mingis Hiina serveris vist, kuna level 29 olles, ei saanud teist mängurit maha.
Ega mul midagi erilist ka polnud 80K dps, 114K toughness ja 13K skill power level 29 rank 55.
Eestis või mujal maailmas? Meil on uued Ubi mängud tihti kohapeal odavamad, kui uplays, Division on Gamestaris 35€ (varem 45€). _________________ Press A to disagree.
<Too late!>
Lehys, tavamäng mingi 23euri.. üsna okei. Õnneks tundub, et päris alla pole veel antud ja ikka tegeletakse mängu kallal. _________________ Krüpto
Jah päris alla pole antud et kes pidevalt on teemat jälgib see teab mis toimub.
Õnneks avas massive ennast ja otsitakse pidevalt lahendusi et core gameplay korda saaks,kes veel ei tea siis natuke aega tagasi hakati ka kommuuniga tihedamalt suhtlema ja nende ettepanekuid kuulama.
Mille tulemusena loodi elite task force kutsuti casual mangijaid ja hardcore mängijaid ning ka kuulsaid ja vähem kuulsaid juutuubereid rootsi et nad annaks enda nägemuse ja ideid mida muuta mängus,kogu tegevus toimus suletud uste taga mille tulemusena siis paar posti ülesse poole ka video selle kohta.
Ning sellel nädalal peaks avanema ka public test serverid kõikidele kes on mängu soetanud,kus siis hakatakse testima fixe jne jne,mis lõpuks jõuavad mängu (sarnaselt nagu BF4-l oli )
Marcostyle(youtuber) rääkis ka paljudest muudatustest ja andis mõista et väga palju asju on veel tulemas aga nad hetkel NDA all ja väga palju rääkida ei saa.
