praegune kellaaeg 03.06.2024 17:34:15
sõnum |
09.06.2003 11:45:04
lm_sensors ehk paneme linuxi riistvara jälgima |
Mõtlesin, et uurin, kuidas linuxi all toimub riistvara monitoorimine. lm_sensors tundus olevat just see, mida vaja.
Lähtepunkt:
Distro: Mandrake 9.1
Emaplaat: Matsonic 8137(Via KT266)
CPU: Duron1200
Installisin
lm_sensors-2.7.0-2mdk.i586.rpm ja liblm_sensors1-2.7.0-2mdk.i586.rpm (ksensors-0.7.2-4mdk.i586.rpm kah aga see ei puutu praegu teemasse).
Tegin sensors-detect'i, mille logi on järgmine - http://www.zone.ee/mark0/varia/lm_sensors.log.txt
Tegin siis, mida nõutud:
To load everything that is needed, add this to some /etc/rc* file:
#----cut here----
# I2C adapter drivers
modprobe i2c-viapro
modprobe i2c-isa
# I2C chip drivers
modprobe it87
modprobe eeprom
#----cut here----
ja
To make the sensors modules behave correctly, add these lines to either
/etc/modules.conf or /etc/conf.modules:
#----cut here----
# I2C module options
alias char-major-89 i2c-dev
#----cut here----
Kuna ei tahtnud oodata järgmise boot'imiseni, tegin root'ina kohe:
modprobe i2c-viapro
modprobe i2c-isa
modprobe it87
modprobe eeprom
Ning käivitades sensors'i nägin :
[root@Katk mark0]# sensors
it87-i2c-0-2d
Adapter: SMBus Via Pro adapter at 5000
Algorithm: Non-I2C SMBus adapter
VCore 1: +1.72 V (min = +1.53 V, max = +1.87 V)
VCore 2: +2.54 V (min = +2.25 V, max = +2.75 V)
+3.3V: +6.36 V (min = +2.96 V, max = +3.60 V) ALARM
+5V: +4.86 V (min = +4.50 V, max = +5.48 V)
+12V: +13.16 V (min = +11.36 V, max = +13.80 V)
-12V: -20.00 V (min = -15.86 V, max = -13.40 V) ALARM
-5V: -9.09 V (min = -10.13 V, max = -9.44 V) ALARM
Stdby: +3.86 V (min = +4.50 V, max = +5.48 V) ALARM
VBat: +3.21 V
fan1: 0 RPM (min = 3000 RPM, div = 2) ALARM
fan2: 0 RPM (min = 3000 RPM, div = 2) ALARM
fan3: 0 RPM (min = 3000 RPM, div = 2) ALARM
Temp1/MB: +30°C (min = +20°C, max = +60°C)
Temp2/CPU: +67°C (min = +20°C, max = +60°C) ALARM
Temp3: +28°C (min = +20°C, max = +60°C)
it87-isa-0290
Adapter: ISA adapter
Algorithm: ISA algorithm
VBat: +3.21 V
eeprom-i2c-0-50
Memory type: SDRAM DIMM SPD
Memory size (MB): 256
Kui tahate seda graafiliselt näha, siis on näiteks KDE jaoks olemas Ksensors, mille link on teema alguses. See lisab ühe applet'i, mida saab siis KDE paneelile sättida.
Kas ma kribasin selle teema, et kedagi aidata? Ei, algselt mitte. Algul oli mul probleem sellega, et sensors teatas "No sensors found!" ning kui hakkasin siia vastavat teemat looma, avastasin, et mul olid modprobe'd jäänud tegemata.
Hetkel on mul veel midagi valesti, kuna CPU temperatuur on väidetavalt 68 kraadi(tegelikult kusagil 50). Aga loodetavasti saab ka selle varsti lahendatud. Kui keegi oskab midagi soovitada, siis oleksin hirmus tänulik, sest /etc/sensors.conf'i lugemine võttis silme eest kirjuks.
Ahjaa:
Copy prog/init/lm_sensors.init to /etc/rc.d/init.d/lm_sensors
for initialization at boot time. |
See on endal veel segane. Kuskohast selle faili leian? Ei hakanud teda nagu kusagil silma. Hetkel lükkasin vastavad read lihtsalt suvalisse faili /etc/rc.d 's.
Kommentaarid: 178 loe/lisa |
144 |
09.06.2003 14:26:30
Nonii.
Enam-vähem täpse tulemuse annab lm_sensors'i pakutava tulemuse 0,78'ga läbikorrutamine. Viga on (vist) paar-kolm kraadi.
Lisa: ei, ka see pole õige. CPU koormus on 25% kandis ja temperatuur ronib ikka kuuekümne kanti(winxp all oli kõvasti vähem).
144 |
pyromaan
09.06.2003 19:41:49
hmm, suhteliselt sarnane on KGrellm, mis pakub igasuguseid kellasi-vilesi
temp'ida jaoks on tal olemas OFFSET, mille abil saab tempi õieti paika
Kommentaarid: 14 loe/lisa |
14 |
10.06.2003 09:34:32
pyromaan kirjutas: |
temp'ida jaoks on tal olemas OFFSET, mille abil saab tempi õieti paika |
Kuidas OFFSET'i kasutada?
144 |
12.06.2003 11:50:26
Uh-oh, äkki keegi oskaks tolle OFFSET'i kohapealt valgustada?
144 |
pyromaan
15.06.2003 17:26:36
hmm, ennista panin mälust. OFFSET jah, prose puhul kinni aga FACTOR ajab asja ära
epox nforce2 emme puhul siis
modprobe i2c-isa
modprobe w83781d
sensors -s
[raimo@speedy raimo]# sensors
w83627hf-isa-0290
VCore 1: +1.55 V (min = +0.00 V, max = +0.00 V)
VCore 2: +1.60 V (min = +0.00 V, max = +0.00 V)
+3.3V: +2.59 V (min = +3.13 V, max = +3.45 V)
+5V: +4.91 V (min = +4.72 V, max = +5.24 V)
+12V: +11.67 V (min = +10.79 V, max = +13.19 V)
-12V: -12.24 V (min = -13.21 V, max = -10.90 V)
-5V: -5.61 V (min = -5.26 V, max = -4.76 V)
V5SB: +5.48 V (min = +4.72 V, max = +5.24 V)
VBat: +3.07 V (min = +2.40 V, max = +3.60 V)
fan3: 2596 RPM (min = 750 RPM, div = 8)
temp1: +15C (limit = +60C) sensor = thermistor
temp2: +36.5C (limit = +60C, hysteresis = +50C) sensor = thermistor
temp3: +26.5C (limit = +60C, hysteresis = +50C) sensor = thermistor
vid: +0.000 V
alarms:
beep_enable:
Sound alarm disabled
14 |
RPG16
24.04.2006 21:05:39
kuidas installida pakki lm-sensors_2.10.0-5_i386.deb
proovisin sudo dpkg -i lm-sensors_2.10.0-5_i386*
faili asukoht /home/rauno/Desktop
Kommentaarid: 202 loe/lisa |
165 |
marqs
24.04.2006 22:27:13
ei ole vaja toda pakki ise alla sikutada, lase synaptic'ul ja/või apt-get'il musta tööd teha.
_________________ 0xDEAD
0xBEEF |
Kommentaarid: 28 loe/lisa |
RPG16
25.04.2006 08:01:41
ja kui on synapticuga hangitud (im-sensors leidsin)
kuidas ma teda käivitan, kas sudo programminimi?
165 |
Ho Ho
25.04.2006 09:05:52
http://secure.netroedge.com/~lm78/docs.html
Kommentaarid: 106 loe/lisa |
86 |
lisa lemmikuks |
