sõnum |
Killzone88
Kommentaarid: 20 loe/lisa |
madd0g
16.07.2008 16:54:58
Toidab ilusti. Hätta ei jää.
_________________ Mõõdan üheksa korda enne kui lõikan, aga ikka on kuradi naljakas. |
Kommentaarid: 120 loe/lisa |
108 |
AJ
16.07.2008 19:32:58
Toidab aga mis on sellel pistmist jahutusega?
Kommentaarid: 37 loe/lisa |
36 |
Killzone88
18.07.2008 22:41:55
AJ kirjutas: |
Toidab aga mis on sellel pistmist jahutusega? |
Vabandan vale koht
Sain arvuti tööle aga kuradi arvutikeskus OCZ vanq cpu jahutus sain neil laost otsa ,ning siis panid mingi thermaltake`i junni kaasa http://www.thermaltakeusa.com/Product.aspx?C=1148&ID=1551 lärmab ja väga raske mobo peale panna
madd0g
18.07.2008 23:27:00
Lärmata se küll ei tohiks. Mis hinnaga said?
108 |
AJ
36 |
Killzone88
19.07.2008 23:29:26
madd0g kirjutas: |
Lärmata se küll ei tohiks. Mis hinnaga said? |
tsitaat: |
One of the worst CPU fans I owned. According to the spec noise level supposed to be 21dBA. In reality, it's more like 40. In addition to regular fan noise it produces a whistling sound, which makes it almost unbearable.
I'm returning this piece of junk back to the seller.
Buyer beware of misleading name and spec. |
tsitaat: |
If you have this processor, you'll want to make sure your CPU fan is dynamically controlled, meaning your computer adjusts the fan speed based on how hot the processor is.
At idle (when the processor is doing very little work) this fan is actually very quiet. However, as soon as you start to do anything that makes the CPU work harder, the fan speeds up and makes a very annoying and LOUD sound that's very different than the normal "whoosh" of increased air flow; it's a droning sound somewhere between a buzz and a hum.
If you don't have dynamic fan speed adjustment on your computer, then this fan will run full-speed all the time, which means as long as the computer is on, you'll never get a break from the noise.
Even if noise is not an issue for you, this fan is mediocre at best. It's quite a bit bigger than the stock fan that comes with the retail CPU, but doesn't seem to cool it much better.
I don't know how this model made it past QA at Thermaltake, but I won't be buying that brand again. |
madd0g
19.07.2008 23:34:21
Killzone88, Mul on küll Thermaltakega hea ajalugu. Tegijal ikka juhtub;). Oman Thermaltake toidet mille juhtmed läbipõlesid ja sai edasi kasutatud:D . Ja thermaltake korpus mis oma 7me fan-niga ja Ketaste paigutusega on päris jahe ja vaikne.
108 |
AJ
19.07.2008 23:51:20
madd0g kirjutas: |
Killzone88, Mul on küll Thermaltakega hea ajalugu. Tegijal ikka juhtub;). Oman Thermaltake toidet mille juhtmed läbipõlesid ja sai edasi kasutatud:D . Ja thermaltake korpus mis oma 7me fan-niga ja Ketaste paigutusega on päris jahe ja vaikne. |
See, et sul on norm Tt toide või korpus, ei tee veel igat Tt poolt toodetud jahutit heaks. Pealegi vaevalt on suu toide tegelikult Tt tehtud.
36 |
madd0g
20.07.2008 01:06:24
AJ, Nää se läks vahetusse. Ausalt... Ennem oli thermaltake purepower max fan speedil läks päris valjuks. Thermaltake vist ei oska vente teha? Või lihtsalt väike viga tuleb sisse tootmisel mida teistel pole.
108 |
AJ
36 |
madd0g
20.07.2008 11:10:26
AJ, Nn aju pesu ostjatele? Ainult logo peale ja uus firma valmis? Paar enda asja ka sisse vajadusel.Ja ongi kohe uus firma?
108 |
AJ
20.07.2008 17:39:10
madd0g, enamus suuremad tootjad ei valmista ise oma toitekaid.
36 |
