-huviline-
07.05.2013 14:12:58
| Keegi siin enda tarbeks või laiemale publikule missioone ka on juba treinud arma 3-es?
| Kommentaarid: 17 loe/lisa |
16 |
allavett
07.05.2013 19:32:48
Keegi ArmA 3 ja ACRE'ga viitsib jännata? Otsiks mingi missiooni ja täristaks?
E: Väike juhend ArmA ja ACRE'i tööle saamiseks, mille oma TS serveri tabeks kirjutasin:
-ACRE for ArmA 3 - where can I get it?
http://projectawesomemodhost.com/
-How to install ACRE for ArmA 3?
You need to download CBA_A3, ACRE, JayArmA3Lib. Extract these to your ArmA 3 installation folder which is located in your Steam steamapps\common folder. Take keys from each mod folder and put them in the 'Keys' folder. Copy/cut 'userconfig' folder from '@ACRE' and paste it in ArmA 3 folders root. Now you will need to add modline (-mod=@CBA_A3;@ACRE;@JayArmA3Lib) to ArmA 3 launch options in Steam.
For TeamSpeak to work you have to take the appropriate (32 or 64bit) TS plugin from @ACRE folder and place it in TS plugin folder.
-How to setup TeamSpeak for use with ACRE?
GUIDE
-How do I use radio if I find one?
You speak into your radio by pressing your CAPSLOACK key. Press it, say what you need to say, and release the key.
It is possible to take multiple radios with you. You can switch between radios by pressing CTRL + SHIFT + A.
You can pull up your radio interface by pressing CTRL + SHIFT + X.
-How do I communicate with someone who is really far away?
For this, you will need either the PRC119 or the PRC117F . On the PRC119, change to it by pressing CTRL + SHIFT + A. Change the PWR (power) mode to HI (high) or, if you are in a vehicle, to PA (Power Amplified). This will make the signal much stronger.
-I already bound my CAPSLOCK key to my Teamspeak 3 push to talk button. Is it possible to set another key for my ACRE radio?
Go to your ArmA2 directory and open the file userconfig\acre\acre_keys.hpp
Change the key found under 'class PTTRadio { key = 58 ... }'
58 is the CAPSLOCK key. If you scroll all the way down in the acre_keys.hpp file, you will see a list of all keys and their codes.
TS severi aadress: 90.191.163.121
_________________ Twitch.tv/allavett |
| Kommentaarid: 50 loe/lisa |
47 |
-huviline-
11.05.2013 18:39:25
Kui keegi tahab niisama laskmist harjutada. Tegin väikse SP missiooni.
viimati muutis -huviline- 12.05.2013 00:36:43, muudetud 1 kord |
16 |
allavett
11.05.2013 22:16:33
Esimese hooga proovisin 1st personiga. Sain sumpsi nii mis kole
47 |
Aeg maha 1p
11.05.2013 22:20:02
Ma ykspäev installisin ka ära ja proovisin mingit esimest ettejuhtuvat online serverit...pidi miskises baasis jooksma ja yksteist nottima ... krt osad controlid peab vist yle vaatama...häiris ukse avamine spacega ja geari ma ka ette ei saanud
| Kommentaarid: 94 loe/lisa |
81 |
Lovvi
11.05.2013 22:29:46
| Super AMOLED kirjutas: |
Ma ykspäev installisin ka ära ja proovisin mingit esimest ettejuhtuvat online serverit...pidi miskises baasis jooksma ja yksteist nottima ... krt osad controlid peab vist yle vaatama...häiris ukse avamine spacega ja geari ma ka ette ei saanud  |
Gear nüüd I tähega.
| Kommentaarid: 61 loe/lisa |
58 |
-huviline-
12.05.2013 00:38:20
| allavett kirjutas: |
| -huviline- kirjutas: |
| Kui keegi tahab niisama laskmist harjutada. Tegin väikse SP missiooni. |
Esimese hooga proovisin 1st personiga. Sain sumpsi nii mis kole  |
Kui päris aus olla, siis ma pole seda isegi veel läbi suutnud teha. Mõtled küll, et peaks kõik vaenlased otsas olema, aga siis kuskilt tuleb ikka laks sisse.
E1: Tegin mõned parandused/täiendused.
http://www.upload.ee/files/3304065/Houseparty.Stratis.pbo.html
16 |
beljo91
| Kommentaarid: 9 loe/lisa |
Mafia
15.05.2013 22:59:48
Deem! Keegi on Dev buildi uusi sounde ja lightingut proovinud ve? Päris lahe
Öö on küll nüüd hetkel selle tulemusena veidike valgem aga uus valguse süsteem annab oluliselt juurde ikka
Also, juba vihjati, et paari nädala pärast on BETA infot oodta
_________________ Bawse |
| Kommentaarid: 19 loe/lisa |
17 |
beljo91
DeTHiCa.
24.05.2013 01:32:04
uut kraami lisati
Sniper Package (WIP) staged for testing
1 x BLUFOR sniper and spotter duo
1 x BLUFOR sniper rifle
1 x OPFOR sniper and spotter duo
1 x OPFOR sniper rifle
Known issue: missing firing sounds
Currently the reload after every shot for bolt action rifles like M320 is wrong. We are looking into it.
1 x Rangefinder
Field Manual records |
et siis kumbki pool sai omale snaiprid koos ghillie suitide, rangefinderite ja täpsuspüssidega.
140 |
Velociraptor
| Kommentaarid: 32 loe/lisa |
30 |
Redikate
24.05.2013 05:13:08
Keegi on kursis kuidas on lood arma 3 serveri hostimisega.
ainult winni alt, või unix süsteemid ka toetatud vms? Dedicated masinatega kuidas on jms?
E: Tundub et dedi serverit pole veel ja steami installiga koos a3'mega linux masinasse konsoolis on vist üsna raske.
_________________ http://nodejs.org/
"I'm also a person. Programming is just one thing I do." |
| Kommentaarid: 34 loe/lisa |
33 |
Mafia
24.05.2013 09:48:11
| DeTHiCa. kirjutas: |
uut kraami lisati
1 x Rangefinder
et siis kumbki pool sai omale snaiprid koos ghillie suitide, rangefinderite ja täpsuspüssidega.  |
Korralik kraam Uus snaipri sihik on ka palju tõetruum kui senine: http://i.imgur.com/WiVawm2.jpg
Eks nüüd peaks vaikselt Beta contenti tulema hakkama, ilmselt E3 näeb ka nii mõndagi
17 |
DeTHiCa.
24.05.2013 10:33:38
| Redikate kirjutas: |
E: Tundub et dedi serverit pole veel ja steami installiga koos a3'mega linux masinasse konsoolis on vist üsna raske. |
windows dedicated server on juba mõnda aega olemas.
140 |
Redikate
24.05.2013 10:39:36
windows dedicated server on juba mõnda aega olemas. |
Nojah, windowsi omaga pole palju teha.
33 |
Velociraptor
25.05.2013 01:23:08
| Mafia kirjutas: |
uut kraami lisati
1 x Rangefinder
Eks nüüd peaks vaikselt Beta contenti tulema hakkama, ilmselt E3 näeb ka nii mõndagi  |
Varem oli ju ainult ACOG ?
Anyway, kuidagi proovida seda ka saab või ?
_________________ 🕊 Kuruppo ぽ 🕊
https://www.last.fm/user/Ingvaarr |
30 |
Mafia
25.05.2013 01:56:49
| Velociraptor kirjutas: |
| Mafia kirjutas: |
uut kraami lisati
1 x Rangefinder
Anyway, kuidagi proovida seda ka saab või ? |
Ee jah aga ma mõtlesin pigem nagu Arma 2 oma, mis on sarnane ACOG-le, kus terve ekraan on must ja siis mingi osa on sihik seal. Selline mitte kogu vaatevälja piirav lahendus meeldib rohkem, isegi kui sihiku ümbrus on ka zoomitud (vastasel juhul tuleks ümbris ja sihik eraldi renderdada ja see näeks välja nagu auto peeglid, mis oleneks sinu PIP seadetest).
Proovida saab kui sa liitud Dev build/branch-ga. Ehk sa saad igapäev WIP uuendusi, mis võivad olla vigased ning need jõuavad hiljem kunagi Stable buildi
17 |
-huviline-
25.05.2013 13:11:49
| krt ma ei saa aru, peale viimast stable build uuendust pole enam võimalik mängida. iga natukese aja tagant jookseb mäng kokku.
16 |
Mafia
27.05.2013 21:59:48
Esimene Beta pilt
17 |
labidas
28.05.2013 13:48:43
helikopteri tiivikud on udukogud... ootan arma4
34 |
Sarin
28.05.2013 14:02:28
puud on ikka nagu 2d multikast... ootan arma4
| Kommentaarid: 7 loe/lisa |
Aeg maha 1p
28.05.2013 14:09:13
Minu arvutil ilmselt jõnksutab... ootan arma4
81 |
SinineSiil
28.05.2013 14:37:47
pilt on jpeg kompressitud... ootan arma4
| Kommentaarid: 20 loe/lisa |
19 |
Lovvi
28.05.2013 15:24:43
pilved tulevad maa seest... ootan arma4
58 |
DeTHiCa.
28.05.2013 16:25:30
combo breaker!
aga et postitus tühja ei läheks, tänane update:
28-05-2013
We published an update, but it was reverted because it wouldn't even run at all. Stand by until tomorrow. |
140 |
bush
| Kommentaarid: 31 loe/lisa |
30 |
Velociraptor
30.05.2013 00:18:57
| bush kirjutas: |
piix mäng ootan arma4 |
Väga informatiivne ja põhjendatud postitus. Tegemist on fucking alphaga
Ja ausalt öeldes jookseb päris hästi, lihtsalt contenti on vähe, sest nii vähe asju on testimisel alles..
30 |
SinineSiil
30.05.2013 00:31:31
| bush kirjutas: |
Ja ausalt öeldes jookseb päris hästi, lihtsalt contenti on vähe, sest nii vähe asju on testimisel alles.. |
Ta tegi nalja naljaga, ta lihtsalt ei märganud, et tegemist oli juba uue leheküljega.
Arvan ma
19 |
bush
30.05.2013 01:01:13
Tegelikult ootan täiega juba Betat. Hetkel on Alfa suhteliselt igav üksi mängimiseks kui on kiire või vaba hetk tekib, gruppi ei leia.
_________________ >50$ pokkeri bankroll |
30 |
DeTHiCa.
140 |
Mafia
30.05.2013 21:01:04
Nice!
Korralik aparatuur
17 |
Arvutipäss
30.05.2013 21:49:25
mõttetu masin ootan arma4
| Kommentaarid: 47 loe/lisa |
43 |
lauri23
| Kommentaarid: 29 loe/lisa |
29 |
Velociraptor
31.05.2013 17:57:09
Masinad on jah suht kahtlased, nagu mingist multikast võetud Muud halba öelda pole.
30 |
Mafia
17 |
KrisVr
01.06.2013 20:07:55
Algas jah!
Pesukaru
| Kommentaarid: 30 loe/lisa |
-Kaivo-
01.06.2013 20:27:42
| loll paks prill, võiks midagi normi seal näidata. pfff.
| Kommentaarid: 16 loe/lisa |
15 |
KrisVr
01.06.2013 20:28:45
Oiii, Commanche!
Mafia
02.06.2013 13:14:28
Nice, Kes ei näinud siis: http://www.twitch.tv/arma3official/b/411222908
Põhiliselt keskenduti sellele, kuidas normaalset missiooni teha (õpisin paar uut trikki isegi) ning seal kasutati ja demonstreeriti uusi asju.
Üks ingliskeelne memo asjast:
Things that will be included in the beta (more to come):
3D scopes (Pole päris PIP aga olenemata sellest et kogu ekraan zoomitud on, näevad palju paremad välja kui senised)
Strider (MRAP similar to Ifrit)
HEMTT (Truck)
Comanche
Zafir (future version of the pkm)
AA Launcher "Titan" (Uses Javlin sighs)
Green Faction (Greek Army)
Mi48
FN2000
New lighting
SDV underwater vehicle (the mini-submarine)
Things that might be added later to the beta:
Altis (developer build) (Jay mainis, et Dev Branch saab selle ilmselt beta lõpu faasis)
Stream-friendly UI
Steamworkshop integration (Lõpuks saab missioone steamworkshopist laadida, ilma et peaksid mängu vahepeal kinni panema. Isiklikult ootasin seda asja juba ammu, muud ma võin armaholic.com-st tirida aga missioonidega on igavene kebla)
Things not included in the beta:
Static AA/AT
MBT's (Main Battle Tanks) (Ja ka lennukid, kuid Jay mainis et beta lõpufaasis võivad Roomikutega tankid siiski tulla)
Java support (might be added later)
Other usefull things to know:
Q3 2013 is still the aimed release date for ArmA 3
Beta will be release a few weeks after E3 (Täpsemalt 2 - 3 nädalat peale E3)
Beta content will be first released on the Developer build of the Alpha (umbes 1 - 2 nädalat peale E3) |
17 |
chesm6mmi
03.06.2013 15:36:09
Niih kuna sain juurde natuke riistvara jälle siis viskasin üles ka ühe arma 3 misiooniga servu, AW Invade & Annex täpsemalt siis. Rohkem infi saab siit:
http://www.armaholic.com/page.php?id=19647
Lühidalt et saab co opis igasugu erinevaid missioone teha plus baasisi igasugu kõik võimalikud masinad mida saab kasutada selleks =)
Üles leiab hv.ee tagi järgi listist ja jookseb stable buildi pealt.
102 |
bush
04.06.2013 00:29:14
Keegi All In Armat juba proovinud? Endale meeldib täiega A10-nega Stratisel ringi lennata. Super!
Kui keegi kogemusi omab siis kas Multiplayer ka toetab AIA-t?
30 |
Karl P.
04.06.2013 16:56:07
| Open beta ka tuleb kunagi?
30 |
supersize
04.06.2013 17:05:02
| Karl0len kirjutas: |
| Open beta ka tuleb kunagi? |
Ei
DeTHiCa.
05.06.2013 13:25:19
nad ise nimetavad seda open betaks, kuna igal ühel on võimalus sinna pääseda - vaja ainult investeerida.
http://alpha.arma3.com/sitrep-00014
SPOTREP #00005
reported
by Joris-Jan van 't Land
on Wednesday 5th June 2013
TO: Alpha Users
UNIT: Arma 3 Alpha, Arma 3 Alpha Lite
ACTIVITY: Game Update: 0.60 (Sniper Package)
CHANGELOG
DATA
Added 1 x BLUFOR M320 LRR .408 sniper rifle
Added 1 x BLUFOR ghillie suit sniper and spotter duo
Added 1 x OPFOR GM6 Lynx 12.7mm sniper rifle
Added 1 x OPFOR ghillie suit sniper and spotter duo
Added 1 x Rangefinder binoculars
Added sniper Field Manual records
Added rangefinder hint
Added Stance Indicator
Not yet linked to options, but it will be
Known issue: sometimes shown off-screen - reset user profile or wait for positioning option in Beta
Fixed: Adjusted rotation speed of turrets for Speedboat
Fixed: http://feedback.arma3.com/view.php?id=3351 (BLUFOR Speedboat shouldn't have optics for rear gunner)
Fixed: http://feedback.arma3.com/view.php?id=8558 (adjusted speedometers for Ifrit, Hunter and Offroad)
Revamped hitpoints for wheels in all soft vehicles to destroy correct wheels
Vehicle weapons are now lockable to prevent losing lock during weapon change
TRG now uses correct 5.56x45mm ammunition
Fixed: Ammo for MXM in special ammo box
Combat pace transition from stand to kneel while moving FL fixed
Weapons disabled in running states
Radio Protocol: enlarged Combat Protocol - over 100 lines (additionally recorded and configured)
Radio Protocol: fixed missing Stealth sentences (additionally recorded and configured)
Radio Protocol: 53 new names added for identity usage
Disabled Difficulty tab in Game Options in MP
Fixed: When respawnOnStart was set to 1 in description.ext, death scripts were sometimes executed after respawn scripts
BIS_fnc_addCommMenuItem: Arguments [caller:Object, cursorPos:Array, target:Object, is3D:Bool, itemID:String] are now passed into expression field as _this
Removed doubled onPauseScript execution
Ballistic penetration of bushes (foliage) adjusted
Fixed: Evasive left and Lean left toggle are not conflicting actions
Adjusted default friction material to allow vehicles to slide a bit over the rocks and boats over terrain
Fixed: http://feedback.arma3.com/view.php?id=8414 (particle effect was always generated on the ground)
Fixed: http://feedback.arma3.com/view.php?id=4620 (light of vehicles’ destruction is disabled under water now)
oxygenCapacity parameter of all units changed
Fixed: http://feedback.arma3.com/view.php?id=8589 (OPFOR squad leader was named "Rifleman")
Fixed: Number of group members of motorized groups
Changed: Minefield Site now rotates all mines in the direction of the Site module
Added: Dialog for custom init code for virtual providers in Supports module
Added: Dialog for custom supply crate init code for supply drop in Supports module
Fixed: broken Showcase Helicopters texts
ENGINE
Fixed: Incorrect reloading while in optics
Fixed: Crash on exiting the game (audio-related)
Fixed: Crash while ordering subordinate to fire artillery same time as having Hunter selected to receive orders
Helicopter AI improvements (e.g. diving too much during attack runs)
Improved ship AI path planning
Added: Reveal action reveals mines
Decreased mine reveal angle
Dynamic light influence on AI visibility tweaked further
Changed threshold for when AI puts on NVG
Decreased flashlight influence on side recognition
Terrain decal fix (Stratis runway)
Fixed: Stabilize car turrets
Fixes to refreshing of difficulty indicator in Campaign and Scenarios displays
Fixed: Selection of first RscTree item after opening Scenarios dialogue
Added: UI controls validator (inventory can recognize which UI controls were not properly initialized, and show some error information)
Fixed: Visual representation of broken wheels not matching the correct wheel for wheels destroyed using scripts
Fixed: Tree destruction animation
Sprint now overrides Combat Pace in all cases
Aiming down in combat pace doesn't make player start running anymore
Added config multiplier of damage that crew receives when vehicle crashes to object
MP score table properly integrated into debriefing display
Fixed: Ragdoll could interfere with cargo poses in multiplayer
Fixed: Ragdoll launching into air by destroyed objects
Fixed: When user tries to pick an item from a corpse to a slot and that slot already contains another item, linked item would disappear
Non-local objects shouldn't collide with ground (breaking joints - http://feedback.arma3.com/view.php?id=7884)
Fixed: Random rotation of the submunition pattern (artillery)
Fixed: Setting of full-screen gamma
Fixed: markerDir return value type
Improved loading of scenario overview images from PBOs (one known issues to do with subfolders remains)
140 |
Mafia
05.06.2013 14:12:01
Pre-E3 Hangout!
Join us live as we're getting ready for the E3 Expo in Los Angeles. This Saturday, June 8 at 17:00 UTC, Mission Designer Thomas Ryan (supported by multiple other Arma 3 devs) will play through the Combined Arms Showcase mission - which will be available in the upcoming Arma 3 Beta. Oh, we might show a little bit of Altis too! |
| As RoyaltyinExile (Jay) pointed out, it was also a bit of a trial run for next Saturday (and possibly other hangouts in the future). This Saturday we'll be showing off the Combined Arms showcase from the upcoming Arma 3 Beta. The idea is to do 2-3 playthroughs, taking a different approach each time. Joining Zipper5 (Thomas), are Encoding Lead Petr Kolar (Pettka), Nelson Duarte (creator of the Combined Arms showcase), and our Senior Designer Karel Moricky. |
17 |
SinineSiil
19 |
DeTHiCa.
05.06.2013 16:10:23
| viimased nädalad veel odava hinnaga arma3 saada, kui beta tuleb siis hind tõuseb.
140 |
rewer
| Kommentaarid: 1309 loe/lisa |
922 |
lauriklade
06.06.2013 23:34:39
Kaua muidu veel aega on selle betani? Ostaks Alpha ära saaks odavamalt aga pole hetkel raha.
Edit: Mis vahe on Alphal ja Digital Deluxe Edition vahel? 15 euri vahe
