uus teema   vasta Tarkvara »  Arvutimängude foorum »  DayZ (arma 2 mod) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 89, 90, 91 ... 119, 120, 121  järgmine
allavett
allavett
sõnum 27.04.2013 15:26:27 vasta tsitaadiga
Tundub, et DayZ serveritest meil puudust ei tule. Sai isegi üks põlveotsas nikerdatud.
-Mods used on server:
CBA;
ACRE - ARMA has to be run as administrator for ACRE to work;
ST ACRE Volume Control - in ARMA controls menu you have to add a hotkey for "Talk on Direct channel" - example;
ST map auto brightness;
ST Movement.
Mod line should look like this if all mods are used: -mod=@dayz;@CBA_CO;@JayArmA2Lib;@ACRE;@st_acre_vol;@st_movement;@st_map_auto_brightness
-How to setup TeamSpeak for use with ACRE?
GUIDE
-How do I use radio if I find one?
You speak into your radio by pressing your CAPSLOACK key. Press it, say what you need to say, and release the key.
It is possible to take multiple radios with you. You can switch between radios by pressing CTRL + SHIFT + A.
You can pull up your radio interface by pressing CTRL + SHIFT + X.
-How do I communicate with someone who is really far away?
For this, you will need either the PRC119 or the PRC117F . On the PRC119, change to it by pressing CTRL + SHIFT + A. Change the PWR (power) mode to HI (high) or, if you are in a vehicle, to PA (Power Amplified). This will make the signal much stronger.
-I already bound by CAPSLOCK key to my Teamspeak 3 push to talk button. Is it possible to set another key for my ACRE radio?
Go to your ArmA2 directory and open the file userconfig\acre\acre_keys.hpp
Change the key found under 'class PTTRadio { key = 58 ... }'
58 is the CAPSLOCK key. If you scroll all the way down in the acre_keys.hpp file, you will see a list of all keys and their codes.
viimati muutis allavett 28.04.2013 13:34:48, muudetud 1 kord
Kommentaarid: 50 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 47
Leo Kalme
Reasõdur
sõnum 27.04.2013 15:55:50 vasta tsitaadiga
mdvwtflol kirjutas:
nii,tunnistage nüüd üles,kes lasi meie offroadi rotti heli crashi juurest kui me seda lootisime :@
kollane offroad? või roheline, mis Lopatinos oli?
On kuskil täpsem info ka Mercenary kohta? Nagu mis masinad/relvastus/varustus muutus ja mida lisati.
Kommentaarid: 23 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 14
mdvwtflol
sõnum 27.04.2013 15:59:04 vasta tsitaadiga
oli mingi rohelist värvi landrover kohe sellest heli crashist 5m kaugusel oli ja me olime just seljaga selle poole ja mingi vend lihtsalt istus sisse ja sõitsis signaalitades minema,me küll lasime ta pihta kui minema sõitsis aga pihta vist ei saanud icon_biggrin.gif
Leo Kalme
Reasõdur
sõnum 27.04.2013 16:11:27 vasta tsitaadiga
mdvwtflol kirjutas:
ok, siis peaks minu oma veel alles olema.
Lovvi
Lovvi
sõnum 27.04.2013 16:58:44 vasta tsitaadiga
Shorty kirjutas:
Kel huvi tulge proovige uut moodi Mercenary. (saab commanderist sikutada)
82.131.80.5:2302
Kas teil mingi mumble või TS on, et adminitega ühendust võtta? Üks pani just combat logi icon_sad.gif
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 58
Shorty
Shorty
sõnum 27.04.2013 17:09:07 vasta tsitaadiga
Lovvi kirjutas:
Shorty kirjutas:
82.131.80.5:2302
TS
rps.ee
Kalme: varsti lisan osad uued relvad/autod nimekirjana
Leo Kalme
Reasõdur
sõnum 27.04.2013 17:54:26 vasta tsitaadiga
Shorty kirjutas:
Lovvi kirjutas:
Shorty kirjutas:
82.131.80.5:2302
TS
rps.ee
Lugesin juba enamvähem Mercenary foorumist mis relvastuses uut on. Pole paha.
Liituksin teiega kohe aga kuu neti liimit on täis ja kiirus piiratud, ei saa kuidagi tõmmatud seda modi. icon_sad.gif Järgmise kuu alguses tulen kah mängu - niikaua peab Diablo 2'ega leppima icon_biggrin.gif
Kes arvas, et botid on hullud, peab Mercenary'st eemale hoidma. 40% chance of spawning, eesmärk tappa kõik elav alal. Pidid oma AI poolest normaalsel tasemel olema, inimesi hakkab surema. icon_biggrin.gif
Rauno1800
Rauno1800
sõnum 30.04.2013 19:43:00 vasta tsitaadiga
http://www.youtube.com/watch?v=uJh7lfqG9_s
Sai mõni telk alla aetud, kõik telgid oli igast paska täis. Vahepeal oli seal 4 ghillie camo sees
Lõpus mõned niisama meil tehtud mängimise ajal pildid
Kommentaarid: 44 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 43
Leo Kalme
Reasõdur
sõnum 01.05.2013 00:01:51 vasta tsitaadiga
Keegi leidis desert offroadile kasutuse või lasti ka raisku nwafil?
allavett
allavett
sõnum 01.05.2013 00:26:28 vasta tsitaadiga
helar66 kirjutas:
Twitch.tv/allavett
Arvutipäss
Arvutipäss
sõnum 01.05.2013 01:08:09 vasta tsitaadiga
Kommentaarid: 47 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 43
lauriklade
sõnum 01.05.2013 18:48:17 vasta tsitaadiga
Tere,
Kuna just hiljuti avastasin selle mängu ja hakkas endale ka meeldima siis tahtsingi küsida: Kas on seda mõtet osta? Mõtlen just sellepärast, et praegu ostad ära ja saad natuke mängida aga varsti tuleb ARMA 3 ja siis kardan, et ARMA 2 serverid jäävad väga tühjaks ning raha põhimõtteliselt raisku läinud.
Arvutipäss
Arvutipäss
sõnum 01.05.2013 19:03:26 vasta tsitaadiga
lauriklade,
Arma OA saad 7,99€ vene keelne aga keelt saab muuta!
Armal see hea et tal pole ainult dayz mod, tal paljusi teisi häid moode!
Arma 3 on juba väljas ja ka sellele tuleb dayz, kui hea tuleb, seda ei tea
Ning on tulemas DayZ Standalone, seda ei tea kuna tuleb, aga tuleb huvitav!
lauriklade
sõnum 01.05.2013 19:20:30 vasta tsitaadiga
Nii, et pole kartust, kui ARMA 3 tuleb siis serverid kohe tühjad?
Peab vaatama kuidas rahadega lood on, viimasel ajal palju arvutit uuendanud.
Mikujr
sõnum 01.05.2013 22:08:45 vasta tsitaadiga
Võid kohe ARMA 3-e võtta..
Või siis kannatad natukene ja ostad standalone.
XBL: Mikuke
allavett
allavett
sõnum 02.05.2013 23:30:43 vasta tsitaadiga
Tänud Tarakanilie hea lingi eest! Ei mäletagi, millal viimati nii head DayZ gameplay videot nägin.
Link
Twitch.tv/allavett
-myyr-
-myyr-
sõnum 02.05.2013 23:48:42 vasta tsitaadiga
Tema videoga on ikka see teema, et temp läheb lillaks kui mingi sõda lahti.. hax or not.. but still is fun icon_biggrin.gif
Autovaruosad Pärnus/kuni -30%
www.mardigarage.eu
tatslinkov
sõnum 03.05.2013 00:09:35 vasta tsitaadiga
Link
xonix
sõnum 03.05.2013 01:16:38 vasta tsitaadiga
Mida kuradit icon_biggrin.gif vähe viitsimist peab olema, et sellist asja ajada.
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 68
LKits
LKits
sõnum 03.05.2013 07:23:02 vasta tsitaadiga
allavett kirjutas:
Ega jah - Frankie videod on üleüldse väga head.
Vend on sõbralik, aga samas mitte üldsegi naiivne, vaid oskab näha ohtu seal, kus see võib ka reaalselt olla. See ongi selle mängu point - ei ole vaja tappa kõike, mis liigub, aga siiski - "trust noone" icon_wink.gif
allavett
allavett
sõnum 03.05.2013 09:24:02 vasta tsitaadiga
LKits, jep, see mulle ta video juures kõige rohkem meeldiski. Oli selline rahulik tüüp - tühja koha peal lahmima ei hakanud - ajas oma asja. Kui oli kontakt andis tüüpidele võimaluse puhtalt välja tulla. Kuigi suurem osa rahvast mõtles, et on kõvad mehed ja said surma icon_biggrin.gif
Twitch.tv/allavett
Leo Kalme
Reasõdur
sõnum 03.05.2013 11:07:06 vasta tsitaadiga
Selline asi töötab ainult siis kui sa ei tea inimesi, kellega koos serveris oled. Eesti serveris, kus enamik on tuntud ebausaldusväärsuse poolest ja shoot-on-first-sight poliitika on jõus, ei saa niimoodi asju ajada. Sest kui sa lased kellegi elusana minema siis järgmisel hetkel tema sind minema ei lase. Kui näed, eriti bandite, siis kuul pähe ja elu muretu. Olen selle poolt praeguseks kuigi paljud võivad mu juttu nüüd pasaks pidada kuna polnud ammu see aeg kui ma ei lasknud ühtegi kuuli player suunas. Aga tõsiasi on see, et kui sa oma sõbralikkuse pärast tuhat korda surma saad ja aega raiskad siis lõppeks tahaks eluga kah pääseda sellistest olukordadest.
Ma ei saa öelda, et lasen tingimata at first sight aga üldiselt kui ma kellegagi kokku jooksen siis mulle endale on lihtsam kui ma kõrvaldan tundmatud playerid. Loodan, et minu puhul toimitakse samamoodi, siis on lootust, et teistelegi jääb gear alles.
Velociraptor
Velociraptor
sõnum 04.05.2013 11:56:47 vasta tsitaadiga
🕊 Kuruppo ぽ 🕊
https://www.last.fm/user/Ingvaarr
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 30
Shorty
Shorty
sõnum 04.05.2013 13:52:26 vasta tsitaadiga
Velociraptor kirjutas:
Proovisin ka ise seda kuid ei meeldi kohe üldse..plussideks on ehk mõned teised relvad ja skinnid kuid Zedide soundid on jube ärritavad mingi rõve "fog" + serveritesse aegajalt ei pääse korralikult sisse, sest jääb loadis stucki.
Velociraptor
Velociraptor
sõnum 04.05.2013 17:03:10 vasta tsitaadiga
Udu on väga hea, kahju ainult, et renderab samamoodi nagu rohi (teatud kaugusel)
🕊 Kuruppo ぽ 🕊
delux1337
sõnum 04.05.2013 17:04:21 vasta tsitaadiga
riietust vahetada siis udu kaob ära
Velociraptor
Velociraptor
sõnum 04.05.2013 17:05:00 vasta tsitaadiga
Kahjuks jah
🕊 Kuruppo ぽ 🕊
allavett
allavett
sõnum 05.05.2013 15:36:28 vasta tsitaadiga
Sai eile natukene mängitud.
Link
Twitch.tv/allavett
Arvutipäss
Arvutipäss
sõnum 05.05.2013 15:39:13 vasta tsitaadiga
chesm6mmi
chesm6mmi
sõnum 05.05.2013 15:47:06 vasta tsitaadiga
tahaks ka miskit infi jah, tea kas ma loll aga netist ei leia kuskilt infot sellekohta, paar päeva tagasi vähemalt veel ei leidnud
Kommentaarid: 107 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 102
helar66
sõnum 05.05.2013 15:50:01 vasta tsitaadiga
http://zoombiesmod.com/index.php ametlik lehekülg
Kommentaarid: 19 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 17
Rauno1800
Rauno1800
sõnum 05.05.2013 15:58:26 vasta tsitaadiga
Oskab keegi anda arma 2 head DayZ serverit?
Leo Kalme
Reasõdur
sõnum 05.05.2013 16:09:03 vasta tsitaadiga
Ühesõnaga sama mis tava DayZ, lihtsalt ARMA 3'e peal.
Inventory tundub parem.
chesm6mmi
chesm6mmi
sõnum 05.05.2013 16:12:58 vasta tsitaadiga
eks ta veitsa bugine ikka on jah veel kuna arma ise alpha ja see mod pole seal isegi alpha staadiumis veel... samas suund on hea ja tundub et mingeid suuri takistusi neil seal pole aga vaja aega lihtsalt et asja valmis teha, samas kui teevad samakorraliku või korralikuma veel kui SA tuleb siis küll häbi häbi Rocketile...
DarkStyle
sõnum 05.05.2013 22:18:17 vasta tsitaadiga
Sai täna siis proovitud kuidas on mängida DayZ siis kui pead täielikult rolli mängima.Päris hea kogemus on kui aus olla.Mängust seest võite võibolla mind leida nimega Igor Chernobyl.http://www.dayzrp.com/
allavett
allavett
sõnum 06.05.2013 20:44:55 vasta tsitaadiga
Huvitavat lugemist seoses DayZ modi portimisega Arma 3le: http://dayzmod.com/forum/index.php?/topic/134366-arma-3-zoombies-released-not-zombie-sandbox-rubbish/
Twitch.tv/allavett
Arvutipäss
Arvutipäss
sõnum 06.05.2013 21:05:25 vasta tsitaadiga
Arma 3 DayZ serverid on nüüd ka saksamaal, ehk nüüd paremad pingid meil
DeTHiCa.
DeTHiCa.
sõnum 06.05.2013 23:17:57 vasta tsitaadiga
allavett kirjutas:
jaah. see "pwnoz0r" on tüüp, kes veel eelmine aasta ei osanud ridagi koodi kirjutada, ta tuli minult tunngle foorumis küsima, kuidas väga basic asju tehakse. naljakas on nüüd lugeda, kuidas tema kusagil skaibis kirjutab et ta dayzSA lubab ära kräkkida.
lisaks siis veel sellele, et ta teiste tehtud töö suhtes lugupidamatust üles näitab.
allavett
allavett
sõnum 06.05.2013 23:22:42 vasta tsitaadiga
DeTHiCa. kirjutas:
Link
Twitch.tv/allavett
xonix
sõnum 06.05.2013 23:55:39 vasta tsitaadiga
Tip of the day: Ärge katkise kopteriga tankla katusele, alla saades olete surnud icon_biggrin.gif
chesm6mmi
chesm6mmi
sõnum 07.05.2013 00:01:34 vasta tsitaadiga
DeTHiCa. kirjutas:
allavett kirjutas:
Sellest osast saan aru jah et päris niisama teiste tööd üle võtta ja siis endaoma kuulutada vms pole väga ilus. Samas ilgelt tahaks neilt vendadelt uurida sealt et okei kui neil mingri projekt käib on siis raske teistele sellest teada anda et millegi sellise kallal tööd tehakse ja värki või laseks siis teistel ligi proovima seda varianti vms... Et elu ei pea ju ometigi täiesti seisma jääma kui Rocket ala puhkusel on.. Isegi seda SA osa edasi lükatud ühte ja teistpidi pidevalt et noh kaua võib =)
Leo Kalme
Reasõdur
sõnum 07.05.2013 00:06:12 vasta tsitaadiga
Jälle üks hea elamus dayzst. Kui kvaliteetsete playerite vastu mängida siis saab ikka parajalt actionit selles mängus.
Tänud rocu ja bubbles
rocu
sõnum 07.05.2013 16:19:43 vasta tsitaadiga
Leo Kalme kirjutas:
Iga kell icon_wink.gif . Sõjast osavõtjaid võiks teine kord rohkem olla, aga muidu oli thumbs_up.gif
Aeg maha 1p
sõnum 08.05.2013 10:10:49 vasta tsitaadiga
Jooksin ka hommikul yksinda serveris...
Edit: sain lõpuks omal BAF ja PMC dlc'd käima... oh kui kenad tekstuurid osadel sõidukitel võivad ikka olla...
Eile lülitasin veel üle pika pika aja ka taustamuusika sisse... tekitas veidikene seda tunnet kui esimest korda sai mängitud ja zombisid juba kaugelt kardetud icon_biggrin.gif
Leo Kalme
Reasõdur
sõnum 11.05.2013 05:52:09 vasta tsitaadiga
Kas server restardib ennast nüüd sama intervalliga, mis M107 spawnib?
Suht nutune, et päevas on 2 restarti.
dohc-48v12
Aeg maha 1p
dohc-48v12
sõnum 11.05.2013 13:05:16 vasta tsitaadiga
kas kellelgi ka veel on arma 2 (obs) streamimisega probleeme ?
ET võin jagada PS-i kaudu õpetust
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid!
Kommentaarid: 112 loe/lisa Kasutajad arvavad:  :: 6 :: 0 :: 85
Arvutipäss
Arvutipäss
sõnum 11.05.2013 14:57:45 vasta tsitaadiga
allavett
allavett
sõnum 11.05.2013 18:22:06 vasta tsitaadiga
Üks ütlemata kaunis trollimise video:
Link
Twitch.tv/allavett
vasques
vasques
sõnum 13.05.2013 12:29:13 vasta tsitaadiga
http://www.elu24.ee/1232928/galerii-mudelisminaitus-minimaailm-2013-lauluvaljakul/1747906 vaatasin et vasakul kole tuttav maja icon_lol.gif
Chuck Norris on juba 2 aastat surnud. Vikatimees kogub siiamaani julgust, et seda talle öelda.
DarkStyle
sõnum 13.05.2013 17:26:56 vasta tsitaadiga
Kuulge seda ,et keegi teist jagab seda squad.xml värki?
uus teema   vasta Tarkvara »  Arvutimängude foorum »  DayZ (arma 2 mod) mine lehele eelmine  1, 2, 3 ... 89, 90, 91 ... 119, 120, 121  järgmine
