uus teema   vasta Raud »  TSI (TeeSeeIse) »  IP kaamerad + 3G/4G ja muu seonduv märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 11, 12, 13, 14  järgmine
sõnum 17.03.2023 23:35:40 vasta tsitaadiga
Reolinkil on neile nõuetele vastavaid kaameraid küll. Mul on RLC-510WA.
Teistel tootjatel samuti olemas.
New Reolink Client v.8.8.5 - Auto Upgrade Client Feature!🥳
Hi guys!
The Client (PC software) v.8.8.5 is now available! You can download the Client v.8.8.5 now via the Reolink download center: http://bit.ly/3ZSVl5z
What's more! We have turned on the auto upgrade feature for your Reolink Client. We use the grayscale release strategy so that the update time will differ in different regions. Just like the Reolink App, it takes some time to arrive in your Client software.
What's New:
Added update notes on the "About Reolink" page.
Added information security notices.
Added Night Mode Focus Enhancement for RLC-823A 16X.
Added the Image Layout Settings for fisheye cameras.
Added a switch for the doorbell button sound.
Supports Reolink TrackMix LTE Plus + Reolink Solar Panel Plus.
What's Improved:
Improved the logic of switching stream types in live view and playback.
Improved the options in the doorbell status LED setting.
Improved the interfaces of the "Date & Time" page.
Improved filters for recordings: separating smart detection events ("Others") from "Any Motion" events.
Improved display of device status: when the NVR goes offline, its channel name in the device list will go dark.
Linked the pre-alarm function to the switch of the siren: when the siren is off, the pre-alarm function will be automatically off; when the siren is on, the pre-alarm function will be automatically on.
Improved the device initialization process and the WiFi configuration process.
Improved the image display of fisheye cameras FE-P/FE-W: the images of their playback and live view, the thumbnail image of playback, and the image for time-lapse will keep the original ratio.
Improved download function:
When the channel names are the same, the channels will not be merged into one option in the download window.
Even when the channel names are the same, the channels will be shown separately in the download window.
Allows you to select and download recordings by different channels of the camera.
Fixed Other bugs
Thanks😊
https://www.facebook.com/groups/reolink/posts/1238294807071060/
sõnum 28.03.2023 07:47:29 vasta tsitaadiga
Lapsetuppa kaamerat vaja. Kallist pole vaja ajutiseks, aga pilt võiks öösel enamähem olla.
Pildi kvaliteet tundub enamusel kole olemat, nii et millist võtta?
Xiaomi c400 tuli välja, kallim kui c200 ja 300, aga äkki natuke parem pilt....60€ võiks selline max hind olla
Mingeid alternatiive sama raha eest?
sõnum 28.03.2023 08:20:32 vasta tsitaadiga
Mul on mingi suvaline ali 15 eurone keeratav ja kallutatav, wifiga. Näitab pimedas rahuldavat pilti
€ 11,49 53%OFF | Original ycc365 1080P Cloud HD IP Camera WiFi Auto Tracking Camera Baby Monitor Night Vision Security Home Surveillance Camera
https://a.aliexpress.com/_mtNTLmQ
Janis
sõnum 28.03.2023 08:21:59 vasta tsitaadiga
Mul oli 30 eurone c1c selleks
sõnum 28.03.2023 10:04:36 vasta tsitaadiga
Janis kirjutas:
sinutorust vaadata videot sellest, siis pilt tundub küll väga kehvake....
Võtsin selle c400 ära, eks vaatab mis pilti see näitab.
Asjaga kiire, ali ei sobi tellimiseks
von Wu
von Wu
sõnum 04.04.2023 12:23:02 vasta tsitaadiga
Sai juhtmega IP-kaamerate (DaHua) süsteemi lisatud 3 uut kaamerat jagajaid kasutades. PoE switchist läheb 2 kaablijuppi jagajasse, sealt 1 pikk kaabel teise jagajasse, millest väljub 2 kaablijuppi. Kummagi otsas üks kaamera.
Täna avastasin, et eile oli paljudel kaameratel mingiks ajaks kadunud ühendus salvestiga. Ja mitte ainult jagatud kaabli otsas, vaid ka mitmel teisel. Veateade IPC Offline. Eile lõunast kuni praeguseni on jälle korralikult töötanud.
Kas asi on jagajates või milleski muus? Miks need kaamerad ära kadusid, mis pole jagatud kaabli otsas?
Müüa 3D-printer
Hunnik DVD filme oksjonil: link
sõnum 04.04.2023 12:36:34 vasta tsitaadiga
jeesus188 kirjutas:
https://reolink.com/product/e1-zoom/
https://reolink.com/product/e1-pro/
sõnum 04.04.2023 12:56:27 vasta tsitaadiga
läks xiaomi juba loosi, sai alustuseks vajalikud asjad tehtud
von Wu
von Wu
sõnum 06.04.2023 19:58:52 vasta tsitaadiga
EZVIZ Wifiga kaamerad. Kes see **** arvas, et on hea mõte, kui kaamera pilti saab vaadata ainult sel juhul, kui wifivõrk on ühendatud internetiga?
Internetita Wifisse ühendada üritades teatab lihtsalt, et ebaõnnestus. Ei sõnagi sellest, miks. Kui pärast ühendamist internet ära võtta, siis õnneks salvestab sisemällu edasi, aga vaadata saab ainult siis kui internet tagasi panna.
Kas Reolink laseb internetita ka vaadata?
Müüa 3D-printer
sõnum 07.04.2023 00:36:43 vasta tsitaadiga
Sisevõrgu IP-ga kaamerale ligi ei lase kui Interneti pole?
elukaz
elukaz
sõnum 07.04.2023 01:16:09 vasta tsitaadiga
Ma vaatan ka välise ip kaudu, ei viitsi kahte aadressi kasutada. Tekib küll ajuvaba ring aga noh, sest saab icon_redface.gif
von Wu
von Wu
sõnum 07.04.2023 21:28:20 vasta tsitaadiga
SKG kirjutas:
Nii jah.
new1
sõnum 22.04.2023 11:10:17 vasta tsitaadiga
Neid vanu telefone 4tk juba tekkinud, millel ekraanid ämblikud, kuular ei toimi või muud sellised hädad ja vedelevad tühja. Mõtlesin et paneks parklas auto peale vaatama ning leiaks veel mingi rakenduse ühele ja lõpuks viitsisin selle alfred äpiga proovida et kuidas toimiks. Tasuta versioonil see video kvaliteet nii saast, et ei kõlba kuhugile. Tavalise telefoni kaameraga filmides versus see mida läbi selle alfredi võimaldab ei kannata võrrelda. Otseselt mul seda vaja pole sinna ja kuutasu ma küll maksta ei näe pointi. On mõni vabavaraline väpp, mis liikumise peale salvestab normaalselt ja sellise kvaliteediga, nagu telefoni kaamera maksimaalselt võimaldab või tasuta versioonide puhul võib sellest ainult unistada? Ühekordse max paarikümne eurise makse võiksin teha ka äpi eest, need vist seotakse kontoga ja saan hiljem järgmisele telefonile uuesti tasuta alla laadida nagu aru saanud olen, näiteks leafspy pro, ainuke äpp mille eest maksnud olen, see vähemalt on õnnestunud hiljem järgmistesse telefonidesse sedasi alla laadida.
Hiid
Hiid
sõnum 06.06.2023 18:47:53 vasta tsitaadiga
On Reolinki kaamera RLC-510WA
Seni katsetasin WIFI võrgus, salvestas kõvakettale miskiseid faile ja osa SD kaardile. Mis suva järgi, pole veel aru saanud.
Panin siis SD kaardi sisse, tahaks teise metsa viia, aga kuidas ma siis neid faile näen, mis sinna on salvestatud?
Tassin koju iga kord? Või saab teloga kuidagi ka ligi? SKG, tead? icon_razz.gif
Hapud viinamarjad
sõnum 06.06.2023 19:10:40 vasta tsitaadiga
Teoorias peaks toimima nii, et teed uhe telefoniga wifi hotspoti, kuhu kaamera ja teine telefon uhenduvad, siis saad teise telefoni abil katte.
Teiseks, see kaamera pole sellise asja jaoks moeldud, kus wifi puudub, vaid Go seeria omad, kuhu SIM kaart sisse kaib.
rex
rex
sõnum 07.06.2023 18:31:52 vasta tsitaadiga
Või viskad mingi 4G ruuteri kõrvale. Kui Reolink oma nina pilve suudab pista, et sealt kinni hakata, pole fix IP-d vaja.
sõnum 14.06.2023 20:25:01 vasta tsitaadiga
Mingi uus mudel, mil vaidetavalt varviline night vision.
https://reolink.com/product/cx410/
elukaz
elukaz
sõnum 14.06.2023 21:26:20 vasta tsitaadiga
Kahjuks ei loe sealt tundlikkust välja, hikvisioni colorvu pakub 0.0005lux https://www.hikvision.com/europe/products/IP-Products/Network-Cameras/Pro-Series-EasyIP-/ds-2cd2147g2-l-su-/
Janis
sõnum 16.06.2023 09:41:35 vasta tsitaadiga
Värviline on siis kui küljes olev lamp põleb. Mul selline paar aastat seinal olnud
sõnum 18.06.2023 16:31:29 vasta tsitaadiga
SKG kirjutas:
https://fb.watch/leM9ngyBvD/
Hiid
Hiid
sõnum 18.06.2023 17:13:54 vasta tsitaadiga
soovitage jahikaamerat
üks FBs ütles, et VIKERI pidi hea olema
link
Hapud viinamarjad
pois11
sõnum 18.06.2023 17:29:58 vasta tsitaadiga
Hiid kirjutas:
link
Mõtle nüüd hästi järgi, 4K 32MB ja 60€... midagi ei klapi. Olen sellist kaamerat seadistanud. Pildi sensor on ehk 1,3MB või siis 3MB eraldusvõimega aga mitte rohkem.
Hiid
Hiid
sõnum 18.06.2023 17:59:41 vasta tsitaadiga
FBs jahikaamerate grupis oli kaamera kraavis, kus kevadepoole Ilves, nüüd karu , kult ja kits.
Kõigil pilt briljantne. See sama tüüp soovitaski.
link
Hapud viinamarjad
pois11
sõnum 18.06.2023 18:13:27 vasta tsitaadiga
Eks see ajab muidugi asja ära aga ise ilma GSM funktsioonita kaamerat küll ei ostaks. Hea ju kaugteel seadistada ja näha mis kaamera juures toimub.
Hiid
Hiid
sõnum 18.06.2023 19:21:11 vasta tsitaadiga
kuhu see GSM oma infi pritsib? Migisse servusse või arvutisse? Või kuda see käib?
Hapud viinamarjad
uus teema   vasta Raud »  TSI (TeeSeeIse) »  IP kaamerad + 3G/4G ja muu seonduv mine lehele eelmine  1, 2, 3 ... 11, 12, 13, 14  järgmine
