praegune kellaaeg 24.05.2024 04:47:32
sõnum |
kaupz
10.04.2022 19:00:48
Emui 12.0.0.132 (c431e3r2p2) tuli,
tsitaat: |
[Notification Panel and Control Panel]
Allows you to swipe down from the top left of the screen to access the notification panel to view notifications, and swipe down from the top right of the screen to access the control panel to use shortcuts. |
https://www.huaweiupdate.com/huawei-p30-pro-ne-getting-stable-emui-12-update/
Kõik uuendused:
tsitaat: |
Innovative interactions
[Font]
Supports more flexible font customization where you can adjust font size and width with a slider.
[Neuromorphic Theme]
Applies the concept of neuromorphism to UI elements. It uses simple colors, tones, shadows and highlights to achieve a more realistic effect.
[Smart Folders]
Supports pressing and holding app folders on the home screen to enlarge them and make it easier to access the apps inside.
Adds an audio control panel to the panel to make it easier to switch between different audio devices and apps. Allows you to quickly enable cross-screen collaboration by tapping icons for Huawei laptops and tablets in the “Device+” section of the control panel.
Smart Life in all scenarios
[Cooperative Security]
Adds a cooperative authentication function between mobile phones and laptops, which allows you to unlock your phone by entering the screen unlock password for the phone on the Huawei laptop when the phone and the laptop are connected to each other via the cross-screen cooperation are.
[Cross-Device File Management]
Supports accessing documents or pictures on the phone via a laptop without connecting the two devices with a data cable.
[MeeTime]
Adds the MeeTime app that allows you to make HD voice and video calls over WiFi or a data network.
Adds support for screen sharing during video calls, allowing you to tag and share key information in video chats.
Note: MeeTime is only available in certain countries and regions: https:// consumer .huawei.com/en/support/content/en-us00956296/
[Huawei Share] Improves Huawei Share
transfer speed for faster file sharing between Huawei phones, tablets and laptops. |
edit: algne tekst, ei teadnud et see on nüüd featuur, et vasakult saab kraapida.
aga TEAVITUSED EI AVANE ÜLEVALT RIBA PEALT !
------------- kui keegi on uuenduse teinud, võiks proovida, kas toimivad: vastamata kõned, kalender, jne ikoone näitab üleval Juhtpaneel / control panel vaates,
aga kui ülevalt alla tõmmata siis ei näita nende sisu. vaid avaneb 3-rida juhtnuppe.
(tuttaval P30 tuli ka uuendus ja toimib) tegin restardi ja Wipe Cache aga ei midagi.
telefoni ja sms ikooni peal number näitab teavituste arvu ja üleval riba peal on väike ikoon, kuid alla tirides ei näita ühegi teavituse sisu.
_________________ O: VW T2 Hipibussi Transporter T2a VolksWagen T1 või Vana Põrnika |
Kommentaarid: 86 loe/lisa |
RõõmusOlen
28.05.2022 23:52:16
Kas praegu on Huawei telefonidel Google pood lubatud?
Oleksin huvitatud Huawei P30 Pro ostmisest,kuid võimatu teda uuena kusagilt saada kasutatuna ei julge osta,sest ei tea mis võib viga olla...
alpha
28.05.2022 23:58:58
P30 peaks veel olema google poolt toetatud, aga uuemad mitte
Kommentaarid: 5 loe/lisa |
lisa lemmikuks |
