sõnum |
tanel112
Kommentaarid: 3 loe/lisa |
Dominus
Kommentaarid: 104 loe/lisa |
76 |
d3t
12.04.2005 18:22:43
tsitaat: |
The Cell chip in the Playstiation 3
Posted Feb 8, 2005, 4:59 PM ET by David Touve
IBM, Sony and Toshiba showed off the specs of the upcoming Cell processor. The chip is to be the brains within upcoming Playstation 3, IBM workstations and Toshiba televisions. Though intended to be OS agnostic, the chip has not been confirmed by those in the know to be being tested with Windows.
tsitaat: |
PlayStation3 Will Use Blu-ray
Fraser Lovatt
09 August 04
Sony has a announced that its forthcoming PlayStation3 console will include a Blue-ray drive DVD drive. Blue-ray is a higher density DVD technology, and will be able to store around 50gb of data by the console's release at the end of 2005.
The inclusion of the Blue-ray drive is sure to guarantee mass market acceptance for the format, in the face of competition from other high density DVD technologies. Sony are particularly keen to see the format flourish as it is one of the founders of the Blu-ray group and has invested heavily in the technology. The main competitor, HD-DVD, has recently received a boost from Microsoft when they announced that their next version of Windows, codenamed Longhorn, would support it.
Blue light optical disks can store more data on them because the wavelength of blue coherent light is shorter, and therefore can read smaller pits, which are also packed closer together.
As Blu-ray is not currently compatible with standard DVD technology, this means that the drive will not be able to play standard red laser DVDs, or run Playstation2 software. It remains to be seen if Sony will be using a special dual-format drive, of taking the expensive step of including two drives in the console.
Playstation3 architecture revealed
rambo software
_________________ next.Insiders - koht mängijatele ja tehnikahuvilistele toredaks ajaveetmiseks.
Lecktor - 3D printerid ja lisatarvikud, Voron, Prusa jne |
Kommentaarid: 85 loe/lisa |
72 |
prints
12.05.2005 14:51:44
millal huvitav juba pildid avaldatakse
Kommentaarid: 35 loe/lisa |
26 |
tobler
Kommentaarid: 16 loe/lisa |
12 |
miga
17.05.2005 09:22:43
NONIII SONY PLAYSTATION 3 ametlik disain on teada ning see uus pill näeb välja siis selline 8)
Pilt 1
Pilt 2
Pilt 3
Pilt 4
Pilt 5
Pilt 6
Pilt 7
Pilt 8
Minu arust väga kena disain konsoolil, kuid pult annab küll väheke soovida v mis te arvate ?
Kommentaarid: 34 loe/lisa |
486
17.05.2005 10:30:42
Kui isegi peaks selle kunagi ostma siis kindlasti musta, kus see blueray ja dvd ketaste sisse pääs on?
Kommentaarid: 46 loe/lisa |
39 |
Exalibur
17.05.2005 11:58:32
isenesest suht kobe aga puldid on ära muudedtud kuigi need vanad on nii käpa järgi see on küll paha
_________________ M:Katkise videoga laptop |
Kommentaarid: 15 loe/lisa |
14 |
miga
17.05.2005 12:59:08
see pult on nagu kahe otsaga dildo...väga ebamugav käes hoida ma arvan...
tahate näha, milline näeks välja The Getaway mäng PS3 peal...palun siin see on
mulle jättis küll sygava mulje 8)
EDIT: Kutt tutvustab demode põhjal PS3 graafikat ja sellega seonduvat...huvitav
Klipp Vision GT'st
Unreal Tournament 2007
Tundub, et pox on täielikult uuel tasemel, minu jäi karp lahti igatahes.. vaadake ja veenduge ise..EA Sports Fight Night Round 3
Mulle tundus juba igatahes, et vaatan TV 3'st otseylekannet...Formula-1
vana hea Tekken, sellest võib midagi suurt tulla 8)
OMG MotorStorm liiiiga ulme 8) 8)
peab ytlema, et fyysika mootori arendamisega on kõvasti vaeva nähtud... Exploding Gas Station
Konsool peaks müügile paiskuma mitteametlike andmete järgi 2006.a kevadel...et siis enam-vähem 1.a pärast
Siin on siis PS3 ametlikud andmed:
CPU
Cell Processor
PowerPC-base Core @3.2GHz
1 VMX vector unit per core
512KB L2 cache
7 x SPE @3.2GHz
7 x 128b 128 SIMD GPRs
7 x 256KB SRAM for SPE
* 1 of 8 SPEs reserved for redundancy
total floating point performance: 218 GFLOPS
GPU
RSX @550MHz
1.8 TFLOPS floating point performance
Full HD (up to 1080p) x 2 channels
Multi-way programmable parallel floating point shader pipelines
Sound
Dolby 5.1ch, DTS, LPCM, etc. (Cell- base processing)
Memory
256MB XDR Main RAM @3.2GHz 256MB GDDR3 VRAM @700MHz
System Bandwidth
Main RAM 25.6GB/s
VRAM 22.4GB/s
RSX 20GB/s (write) + 15GB/s (read)
SB< 2.5GB/s (write) + 2.5GB/s (read)
System Floating Point Performance
2 TFLOPS
Storage
Detachable 2.5" HDD slot x 1
I/O
USB Front x 4, Rear x 2 (USB2.0)
Memory Stick standard/Duo, PRO x 1
SD standard/mini x 1
CompactFlash (Type I, II) x 1
Communication
Ethernet (10BASE-T, 100BASE-TX, 1000BASE-T) x 3 (input x 1 + output x 2)
Wi-Fi IEEE 802.11 b/g
Bluetooth 2.0 (EDR)
Controller
Bluetooth (up to 7)
USB 2.0 (wired)
Wi-Fi (PSP)
Network (over IP)
AV Output
Screen size: 480i, 480p, 720p, 1080i, 1080p
HDMI: HDMI out x 2
Analog: AV MULTI OUT x 1
Digital audio: DIGITAL OUT (OPTICAL) x 1
Disc Media
CD PlayStation CD-ROM, PlayStation 2 CD-ROM, CD-DA, CD-DA (ROM), CD-R, CD-RW, SACD, SACD Hybrid (CD layer), SACD HD, DualDisc, DualDisc (audio side), DualDisc (DVD side)
DVD: PlayStation 2 DVD-ROM, PlayStation 3 DVD-ROM, DVD-Video, DVD-ROM, DVD-R, DVD-RW, DVD+R, DVD+RW
Blu-ray Disc: PlayStation 3 BD-ROM, BD-Video, BD-ROM, BD-R, BD-RE
viimati muutis miga 17.05.2005 17:08:41, muudetud 11 korda |
486
17.05.2005 13:04:16
PS3ga saab dvd-sid kirjutada?
39 |
erick
17.05.2005 13:08:52
1.8 TERAFLOPS graafikakaart
Ma ei tea, mida nVidia sinna sisse pistis, aga teoreetiliselt on GF6800 ULTRA võimsus ainult 80 GIGAFLOPSi kanti... PS3 chip aga umbes 1800 GIGAFLOPSi Gaad, ja mina veel arvasin, et CELL on võimsaim asi selle konsooli juures oma 218 GIGAFLOPSiga
_________________ WoT Stats Twitch Stream |
94 |
ppg
17.05.2005 14:42:22
valge päris stiilne ...ei usu et pult ebamuguav on...kõvakettaga versiooni pole siis?
Kommentaarid: 170 loe/lisa |
137 |
17.05.2005 16:31:11
ppg kirjutas: |
valge päris stiilne ...ei usu et pult ebamuguav on...kõvakettaga versiooni pole siis? |
just hea, kui HDD'd pole, kuna nad ei pane nagunii kunagi piisavalt suurt ketast sisse sinna - parem ostan ise sinna nii suure kui vaja ja odavamalt.
mul on praegu PS2-l 120GB ketas ja jääb ka väheks - 200GB ehk piisaks
_________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..." |
Kommentaarid: 373 loe/lisa |
313 |
prints
17.05.2005 17:18:18
lihtsalt vorratu
26 |
ppg
17.05.2005 18:55:25
Skeptik, küsimus veel selles kas seal on selleks koht olemas...mistahes ketas võiks sees olla küll juba näiteks mängude salvestamiseks
137 |
17.05.2005 18:56:19
ppg kirjutas: |
Skeptik, küsimus veel selles kas seal on selleks koht olemas...mistahes ketas võiks sees olla küll juba näiteks mängude salvestamiseks |
koht on olemas
tsitaat: |
Detachable 2.5" HDD slot x 1 |
313 |
ppg
17.05.2005 19:01:53
Siis hea, kuid asi läheb kalliks arvestades sülearvuti (2,5") ketaste suurusi ja hindasid hetkel
137 |
miga
18.05.2005 12:18:58
ei tea palju PS3 maksma võib hakata
kui ma õigesti mäletan, siis kas PS2 ei maksnud yle 6000 kui myygile tuli ?
18.05.2005 12:34:21
miga kirjutas: |
kui ma õigesti mäletan, siis kas PS2 ei maksnud yle 6000 kui myygile tuli ? |
hehee... PS2 maksis eestis 2000 aasta lõpus 9990.- minu teada
PS3 hinnast: http://ps3.ign.com/articles/615/615745p1.html?fromint=1
313 |
arvutisõber
Kommentaarid: 55 loe/lisa |
53 |
Tamps14
04.06.2005 14:11:40
Skeptik kirjutas: |
miga kirjutas: |
PS3 hinnast: http://ps3.ign.com/articles/615/615745p1.html?fromint=1 |
see ei olegi ju mingi hind suur hind 465 taala see on ju meie rahas umbes 5000 eek , meie poed teevad ka ju juurdehindlust ja algues võib selle hind olla umbes 7000-9000 eek
Kommentaarid: 20 loe/lisa |
17 |
Elof
04.06.2005 14:22:41
Tamps14 kirjutas: |
see ei olegi ju mingi hind suur hind 465 taala see on ju meie rahas umbes 5000 eek , meie poed teevad ka ju juurdehindlust ja algues võib selle hind olla umbes 7000-9000 eek |
Jaapanis omahind tunduvalt madalam kui euroopas ning mitte unustada EU tolli (Palju see oli, ei mäletagi) mis võibolla 18% vähemalt. Siis EU's oleks juba natuke üle 6900 EEK ilma poe juurdehindluseta.
Muuseas 465$ = umbes 5900 EEK hetkel
Kommentaarid: 212 loe/lisa |
175 |
arvutisõber
53 |
08.06.2005 06:51:33
jep
seda näidati SONY E3-e prssikal ka tegelt kõige viimasena
313 |
Yorick
Kommentaarid: 1 loe/lisa |
