uus teema   vasta Tarkvara »  Arvutimängude foorum »  League of legends märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 101, 102, 103 ... 110, 111, 112  järgmine
Minu meelest on LoLi kogukond...
Sõbralik. Viisakas. Andekas!
5%
 5%  [ 8 ]
Keskmine. Ei erine teistest kogukondadest.
37%
 37%  [ 56 ]
Mürgine.
57%
 57%  [ 85 ]
hääli kokku : 149
Rasvane
Rasvane
sõnum 27.09.2014 19:40:29 vasta tsitaadiga
sander989 kirjutas:
FNC vs OMG oli KhaZix bug mobi bootsidega. Ôhkôrn lootus on rematchile.
https://twitter.com/RiotNickAllen/status/515899973838176256
Guess not. Kuigi sealtsamast esimesed kommentaarid "V1.0.0.120: Will now mark you in combat for receiving/dealing any damage, even if it is absorbed by shields." + "Riot have made it clear with that patch note that damage to shields = damage dealt to champions"
E: Need commentid on mobide kohta, mitte homeguardide. Ehk siis ei tule mingit rematchi prolly. Naad saaksid liiga palju heitti.
e2: siin on ka hästi lahti seletatud:
"What Riot didn't take into account with this is the fact that recalls aren't cancelled by damage taken in the last 0.5 seconds of it (this is one of the not-a-bug-it's-a-feature things in League). This damage should still put someone in combat and I believe it did. HOWEVER, someone in Riot skipped over a bit of coding on the on-recall instant activation of Homeguard so it doesn't check for combat, meaning that, although Kha WAS in combat, he got the Homeguard bonus WHICH YOU SHOULD NOT BE ABLE TO GET WHILE IN COMBAT. THIS IS A BUG."
e:3 http://www.reddit.com/r/leagueoflegends/comments/2hm1au/spoilerin_the_game_between_fnc_and_omg_happend_a/cku06i7?context=3 - Siin see Allen räägib, et khazix ei võtnud dmg seega homeguardid läksid tööle. Kuigi liigub ringi pilt ja vodist on nka näha kuidas ta kaotab hp'd wraithidelt -> http://i.imgur.com/Sbb6FiH.png
viimati muutis Rasvane 27.09.2014 20:31:45, muudetud 3 korda
sander989
sander989
sõnum 27.09.2014 19:46:39 vasta tsitaadiga
Eks näeb mis saab.
Kommentaarid: 78 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 66
koiott
sõnum 27.09.2014 19:49:03 vasta tsitaadiga
sander989, Korea näide selle pärast, et neil kõige tugevamad ja ühtlasemad tiimid, EUs, NAs saaks Fnaticu poisid pea igasse tiimi ja oleks seal ka staarid. NWS on kõik mängud väga uimaselt alustanud ja ALL on ennast suht hästi käima saanud ja seekord karistasid ka ära. SSB mängu vaatasin lõiguti, aga tundus, et kõik, mis pekki sai minna, ka pekki läks.
Archangel, täpselt selle ebastabiilsuse tõttu ei saakski nad kuskile. Kui talvel/kevadel oli Fnatic 7-0 ja siis 0-7, siis kõik teised feilisid ja Rekkles oli ikka tipus ja Rekkles on selle poole aastaga veel palju paremaks saanud (agressiivsem, aga sureb ikka väga harva). Peke on ehk ainuke, kes suudab oma halva mängu feed festi peatada, kui YS, sOAZ või Cyanide minema hakkavad, siis tavaliselt enam pidama ei saa.
Kommentaarid: 138 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 130
sander989
sander989
sõnum 27.09.2014 21:29:18 vasta tsitaadiga
Aga noh Rekkles on üks nendest top carrydest maailmas (selle vastu ma ei vaidle). Lisaks Defti ja Uzi ka veel.
robertzon
sõnum 27.09.2014 23:22:56 vasta tsitaadiga
Uzi on ikka väga top level minu silmis, iga mäng lihtsalt suurepäraselt mänginud
sander989
sander989
sõnum 28.09.2014 07:18:04 vasta tsitaadiga
Uzi on jah suht hull. Vôitleb iga CSi eest ja üldse väga agressiivne.
Archangel
Archangel
sõnum 28.09.2014 12:26:35 vasta tsitaadiga
sander989
sander989
sõnum 28.09.2014 13:48:51 vasta tsitaadiga
Nôustun sinuga Archangel, ja head mängud siiski FNC poolt kui esimene välja arvata.
traksid
traksid
sõnum 28.09.2014 16:17:20 vasta tsitaadiga
Bye Bye Fnatic
Cyril
Aeg maha 1p
sõnum 28.09.2014 16:43:27 vasta tsitaadiga
Mis naudingut te nende profimängude jälgimisest saate kui tohib küsida? icon_biggrin.gif
Rasvane
Rasvane
sõnum 28.09.2014 17:16:21 vasta tsitaadiga
Mis naudingut sa [insert random comparison here] saad?
Archangel
Archangel
sõnum 28.09.2014 17:17:39 vasta tsitaadiga
Cyril kirjutas:
jonathan19
jonathan19
sõnum 28.09.2014 17:32:11 vasta tsitaadiga
Cyril kirjutas:
ns pull
Kommentaarid: 40 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 38
koiott
sõnum 28.09.2014 17:33:40 vasta tsitaadiga
Cyril, lihtsalt näiteks: Jalkat mängid? Jalkat vaatad? Sama asi.
Nightfire
sõnum 28.09.2014 17:48:20 vasta tsitaadiga
Archangel
Archangel
sõnum 28.09.2014 18:12:05 vasta tsitaadiga
Nightfire kirjutas:
sander989
sander989
sõnum 28.09.2014 19:07:59 vasta tsitaadiga
s0AZt välja kindlasti mitte. Pigem aidata tal ôppida oma emotsioone talitsema. Ja nad on siiski tiim, toetagu s0AZt ja hoidku tuju üleval kui tema lane campi saab vms. Vôi kas tôesti s0AZ lülitab välja ennast kui asi peeti minema hakkab vói terve tiim tilt kui s0AZ tildib(milles ma muidugi kahtlen)?!
Nightfire
sõnum 28.09.2014 19:24:55 vasta tsitaadiga
Ärge unustage, et neli 4/5 Fnatic'u mängijatest on alates Season 1-st pelanud. Poleks mingi ime, kui keegi neist lihtsalt retireda tahaks.
Neid playereid on väga vähe, kes nii kaua aktiivsed olnud. Ise arvan, et skilli poolest on nad kõik veel konkurentsis, kuidas lood motivatsiooniga on, selles pole kindel.
Noorematel mängijatel jagub seda tavaliselt rohkem, üheks parimaks näiteks ongi Rekkles.
Psych0
Psych0
sõnum 28.09.2014 19:30:15 vasta tsitaadiga
sOAZ oli eelmine aasta liiga ebastabiilne ning on ka see aasta. Minu arust võiks samuti sOAZ'e välja visata, kuna teiste performance on hea.
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 57
Archangel
Archangel
sõnum 28.09.2014 20:22:18 vasta tsitaadiga
sander989 kirjutas:
Noh, kindlasti mõjutab ühe tiimiliikme tilt ka teiste oma. Üksteist tuleb muidugi toetada aga kõik sõltub muidugi sellest, et mis täpsemalt probleemiks on. Kui campitakse, siis vaevalt, et tilt niiväga hull on, sest ilmselgelt mängijal endal pole väga midagi teha. Kui ta ikka ilusti kaitses mängis ja lihtsalt terve vastase tiim selga lendas, siis võib tegemist olla suht vältimatu probleemiga. Kui mängu alguses ikka warde väga pole, siis on tihti võimatu pakkuda mis lane vastane järku paugutab. Kogu tiimi ülesanne olukord lahendada ja üksteist toetada. Aga asi on hoopis teine, kui sa Luluga solo pushid vaenlase top turretit ilma wardide kaitseta ning nägemata, kus ülejäänud vastase tiimiliikmed on. Või telepordid kaotatud team-fighti lihtsalt selleks, et feedida. Või, kui sa otsustad vaenlase turreti all pm. recallida või viskad oma Rumble ulti keset vastase fountanit vms. Asjad, kus süü on pm. pea täies mahus ühe inimese kukil. icon_biggrin.gif
Soaz ei ole otseselt halb mängija, maailma eliidis siiski, kuid tema vead on kohati lihtsalt väga absurdsed. Võib-olla on probleemiks lihtsalt see, et kuna ta on nii pikalt mänginud, siis iga-aastased reeglite muudatused ja Meta muutumine on tal juhtme krussi ajanud.
Kas enda lemmikud ei sobi praegusesse metasse ja vastaste taseme vastu või vastupidi tiimi heaks võtab champe milles väga proff ei ole.
Ma oleksin tahtnud näha rohkem Ireliat või Jax'i. Miks mitte ka Mundot või isegi Shivanat. Midagi, millel rohkem sustaini, või tankimis potentsiaali, 1 vs 1 võimsust ja samas ka piisavalt escape. Lulu tundub nii mõttetu seal top lanes. Veidi Poke, slow'd, veidi kilpi ja speed-up'i kuid pm. dämmi eriti pole, tankimine vaid kilbiga, sustain piiratud, escape piiratud. Vastane peale lendab, siis on väga tihti kellad. Rohkem nagu teine support, mis peaks mid-late game carrysid oma utilitiga toetama, kuid IMO "easier said than done".
Rumble veidi parem, kuid nagu näha siis farmimine on üldiselt raske ja ultimate on raske täies mahus kasutusse panna. Team-fight champ, kuid s0AZ'i telepordid selles mängus midagi erilist olnud pole. Ilma farmita ja ilma pideva fightimisega ning sealt saadavate killideta olev Rumble on pm. feeder.
Seega jah - ei tahaks kõike negatiivset ainult mängija oskustele loopida, sest osad champide valikud on lihtsalt küsitavad ning ma ei ole kursis palju ise s0AZ otsustab selle koha pealt ja kui palju tiim.
sander989
sander989
sõnum 28.09.2014 22:01:41 vasta tsitaadiga
s0AZe champ pool on üks suuremaid top lanerite seas aga ju ikka oli mingi eesmärgil Fnaticul kui need 2 Lulu picki nt tuli. Toyz coach ka veel aga lihtsalt ei õnnestunud.
Vaatan NWS-C9 tiebrakerit järgi praegu. Ulme mäng ikka.
Archangel
Archangel
sõnum 28.09.2014 22:43:44 vasta tsitaadiga
sander989 kirjutas:
Kahjuks on tänapäeval tase muidugi suht selline, et suur champ pool pole väga reaalne enam. Selles suhtes, et pole lihtsalt aega kõike väga tasemele harjutada, eriti kuna champe muudetakse ning muutuvad ka itemid ja meta. Mängida võivad nad osata muidugi absull kõike champe ning isegi kordades paremini kui mistahes non-pro mängija, kuid absoluutselt kõrgeimal tasemel on väga raske mitmeid champe mängida. Kui s0AZ üritab endiselt oma champ pooli väga suurena hoida, siis võib-olla tasuks seda just kokku tõmmata veidi. Strateegia on väga oluline, kuid kui kogu vundament peab tugev olema. Mehaaniline oskus ja olukorra mõistmine/taktika peaks võib-olla s0AZ'i suund olema tuleviku tarvis.
Eks see Lulu pick oli mõeldud kindlasti carryde toetamiseks mid-late game. Annab väga lahedaid lükkeid teha, just Fnatic stiilis. Kui aga early-game Luluga maha jääd ning veel hullem, vastastele feedi ka veel annad, siis kokkuvõttes on sinust tiimile vähe kasu. Kui vastane eest minema saab kullaga, siis on nad niivõinaa juba itemitega sinu carrydest ees. Lulu kesine utility mahajäänud mängus ei tee tasa seda, et vastastel on need extra itemid ja vbl veel extra AP carry/Bruiser carry. Kokkuvõttes on minu arust risk lihtsalt liiga suur Luluga. Ta ei ole nii "safe" oma lanes nagu näiteks teine AP top Ryze, kes suudab alates teatud punktist väga hästi farmida ning peale paari itemit võib ka veidi maha jäädes team-fightis hullu dämmi teha/split pushida.
Selline utility champ nagu Lulu jäägu supporti või siis Mid'i. Mid on lihtsalt farmimiseks ohutum Jungleri pideva läheduse tõttu ning seetõttu on üldiselt garanteeritud kõrgem farm ja mid-late game kasulikkus + isegi early-game roaming potentsiaal. Topis ei ole muhvigi teha. Liiga avatud gankidele ja campimistele ning 0 kasu AD carryle. Parimal juhul saad Midi roamida ja veidi aidata, kuid ka see on küsitav.
Aga noh - spekulatsioonid ja teoretiseerimine. Pro mängijatel siiski vähe teine mõttekava kindlasti ning pro-coachid ju samuti olemas, kes väga keerulisi plaane paika panevad. Lihtsalt kahju, et Fnaticu potentsiaal jäi ühel või teisel põhjusel realiseerimata.
ertr2
ertr2
sõnum 29.09.2014 09:34:41 vasta tsitaadiga
. Kui aga early-game Luluga maha jääd ning veel hullem, vastastele feedi ka veel annad, siis kokkuvõttes on sinust tiimile vähe kasu.. Kui aga early-game Luluga maha jääd ning veel hullem, vastastele feedi ka veel annad, siis kokkuvõttes on sinust tiimile vähe kasu.
vastupidi, lulu on strong pick just sellepärast, et isegi kui ta taga on saab ta teamfightides tänu utilityle tiiimi aidata. Samuti on toplane lulu jaoks parem kui mid, sest jungleril on sinna raskem gankida, kui midi ning samuti ei oleks lulu midist tänu nõrga early game tõttu abi
Kommentaarid: 67 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 65
Archangel
Archangel
sõnum 29.09.2014 10:33:14 vasta tsitaadiga
ertr2 kirjutas:
Jah, maha jäädes saab tiimi aidata küll, kuid IMO ei tee see utility seda tasa, et tiimis üks korralik damage dealer/tank vähem. Fnaticu mängus oli näha, et kui ikka tiim maha jääb, siis see Lulu kilp ja utility ei tee lihtsalt tasa vastaste ekstra high-dam/tank champi. Probleemiks ka see, et maha jäänud Lulu hakitakse pm. mistahes vastase champi poolt ära/imetakse kergelt ult välja, seega on roam suht raske ja kasu tiimile tugevalt piiratud.
Ma näen selles pickis potentsiaali, kuid IMO on see nii spetsiifiline ja nõuab nii head mängimist mitme nurga alt, et ma ei näe sellel riskil mõtet.
Ja ma ei ütleks, et Top/solo lane raske gankida on, vastupidi kõige lihtsam gankida, sest ligipääsu kohti on palju ning warde enamasti kõige vähem. Lane on pikk ning ilma hard-escape'ta champ ei suuda enamasti oma turreti alla peitu joosta, sest tihti saad gankiks isegi vastase selja taha pugeda. Kui vastaste jungleril silma peal hoiad, siis kaardi all otsas olev jungler ei jõua pilgutadagi selleks ajaks kui gank läbi. Midi puhul on gankida raskem, sest esiteks junglerid on pidevalt midile suht lähedal. Counter-gank on seega tihti reaalsem ning kuna lane on niivõrd lühike, siis enamik suudavad väga ilusti gankist minema saada. Üks flash on enamasti piisav. Lisaks on enamasti tiimidel jungle sissepääsude juures wardid mida iga korralik jungler ka uuendab, seega üldjuhul mid'i väga üllatada ei õnnestu.
Seetõttu ongi Top lane campimine hetkel metas päris popp. Üldiselt saab hästi lähedale hiilida ning vajadusel ka tower dive teha. Keskendutaksegi tihti sellele, et lihtsalt lülitatakse vastaste top laner mängust välja. Milleks riskida bot-lane campimisega kui edu on seal raskem saavutada. Dual lane on enamasti hästi warditud ning nõuab rohkem resursse, et midagi teha ning mid on nagu on. Flash ja "safe".
Seetõttu minu arvamus ongi, et praeguses Metas on lihtsalt liiga riskantne Lulu't top lanes mängida. Mitte, et teisi champe samuti campida ei saaks, kuid paljudel bruiseritel on 1 vs 1 ja 1 vs 2 võitmise ja ellujäämise potentsiaal ikka tunduvalt suurem.
ertr2
ertr2
sõnum 29.09.2014 14:39:09 vasta tsitaadiga
sõnastasin vb natukene valesti, topi on küll kõige lihtsam gankida jah, aga kui vastase jungler gankib topi ja sinu jungler on mapi allosas, siis on sul megapalju võimalusi mida teha, drake on allpool, vastase blue, botlane- ala topi gankimine avab vastastele väga palju võimalusi
uus teema   vasta Tarkvara »  Arvutimängude foorum »  League of legends mine lehele eelmine  1, 2, 3 ... 101, 102, 103 ... 110, 111, 112  järgmine
