Youtube kommentaare lugedes näeb, et inimestele lihtsalt meeldib midagi vihata, vallandab serotoniini ja ei tea mis muid ajukeemikaale, et saaks end paariks sekundiks üleolevalt tunda.
Kõigeparem on see, et kui heiditakse algul ja pärast asi tuleb välja siis on nad suured fan boyt. On ka vastupidi, näiteks No Man Sky. True Story bro
Parem karta ja heitida, vastupidiseid näiteid on kahjuks väga vähe
Heitida ja karta asja mida pole veel olemas... skisovärk. Aga kui teisiti ei suuda, siis andke tuld! Heitige ka oma veel sündimata last, venda, õepoega jne, tont teab mis sealt sündida võib, eks?
Xbox: The Official Magazine (UK) also had a Mass Effect: Andromeda cover story. No new screenshots. There is some speculation in it, so I only mention what they actually bring as facts. Not much new stuff.
* There are 'several highly advanced alien races' we'll meet in Andromeda
* Barrier can now deflect projectiles at foes
* Powers have individual cooldowns
* Blades confirmed as a craftable melee weapon (we already knew hammers)
* After a couple of encounters with the Kett, you'll be able to craft some of their technology (they use plasma guns)
* Crafting is entirely optional, not important to the story
* Based upon your dialogue choices, there can be tensions in the team
* You see planets and stars fly by from the Tempest's bridge, al windows on the ship give a view of your current location on the galaxy map
* 'Interrupts' are not paragon/renegade, but 'disarm' for example (it's a strategic choice, not a moral)
* You'll be able to understand the Kett motivations, they're more nuanced as an enemy
* There's a whole seperate storyline besides the Kett
* The Kett were originally designed to be completely nude, but it was akward in cutscenes
* All squad members have a loyalty mission (they seem to be 'a string of objectives' rather than one single mission)
* The loyalty missions will explain the squad members' motivation for leaving the Milky Way
* Michael Gamble: 'I definitely wouldn't call Andromeda an open-world game. We like to use the term exploration-based game. Sometimes that happens in open spaces, but not always. You can cruise around some of these planets in the Nomad, but it's not the traditional sandbox-type game.'
* You don't have to fuel the Tempest
* Side quests will be 'more varied and interesting than ever', says BioWare
* Active abilities/powers (like Overload, etc.) have an alternate fire mode
* There is no level cap, you can keep leveling until you run out of skills to put points into
* 5 difficulty levels, including narrative (very easy, just the story)
* Nomad's top speed is 130+ km/h
* Tempest top speed is 13 light years per day
* You can upgrade the omnitool (the blade)
Mulle meeldib eriti see mooramehe soeng, oleks nagu lärakas PVA liimi lagipähe pandud ja hunnik rebitud pabereid peale visatud.
Eks näis mis sellest välja tuleb, aga minu ootused on suhteliselt madalad. Arvestades sellega, et Mass Effect 3 rikuti kõik karakterid ära ja see värviline ending oli paras bullshit. Aga olen valmis proovima Andromedat, kui see välja tuleb.
Oleks siis Bioware kunagi minevikus ilgat paska tootnud, et oleks põhjust karta, et mäng tuleb kehv...
Wat ? Bioware viimased head mängud olid DA:O ja Mass Effect 2. Ja ME2 lugu oli juba päris kehvake.
Vaatasin trailerit praegu ja asi tundub päris naeruväärne.
2017 Triple A game. Top notch animatsioonid. Trailer peaks nagu parimat contenti näitama...
Jutt käis ilgest pasast. ME3 ja DAI polnud ilmselgelt parimad mängud ever aga need olid mängitavad.
Need animatsioonid seal traileris olid placeholderid. Kui ma ei eksi, siis igas sellises eelvaate traileris on kuskil ka väike tekst "does not represent the final product quality" vms.
Athunik kirjutas:
No aga paljudes mängudes on suurepärased juuksed siis? Isegi Tomb Raiderit ja Witcherit kritiseeritakse, et juuksed ei tundu reaalsed. Mis lootust siis teistel veel üldse on?
Et siis laseks paar "lets play'd" enne mängu välja tulekut?
Oodake launch ära, vaadake asi üle ja siis otsustage, milleks halada?
Võib olla eksin, aga minu arust vanasti nii oligi, et enne mängu väljalaset oli juba mitu kuud mitmed gameplay videod olemas tootjalt endalt. Mäletan veel kuidas pikalt Crysise videosid vahtisin suvel, mäng tuli kunagi novembris vist välja alles. Aga see selleks. _________________
Mis detailsusi te siin taga otsite, ma ei saa aru. Peaasi, et tuleks vähemalt võrdväärne elamus eelmiste osadega võrreldes ja oleksin väga rahul. Parimaid kosmoseseiklusi mida kunagi mänginud olen ja mängu muusika oli omaette nauding. Kohe ostma kindlasti ei kipu.
Rääkides mängu muusikast. Komistasin vist OST-i otsa (täiesti pooljuhuslikult). Ma ei tea nüüd kas see on osa MEA soundtrackist või kas see üldse ehtne on, kuna sellel youtube kontrol rohkem videoid pole. Igatahes kuulake siit: https://www.youtube.com/channel/UCZ2kjhfJkQIuta24iaXz4xg
Mom said it was my turn to use a gun.
DA:I alla olen matnud rohkem tunde kui DA:O ja DA2 kokku pandult. IMO 2x parem mäng kui ükski teine. ME2 story kehva? Mine pane kanep tasku tagasi.
Ning kui sa Mass Effect'i ostmist kaalud mingi traileri animatsioonide põhjal, siis ilmselgelt pole see mänguseeria üldse sulle mõeldud.
Ah, mida ma üldse räägin. Siin teemas on vbl 1-2 inimest minu tasemel Bioware mänge mänginud ning ilmselgelt on "casualidel" vähe teised nõudmised mängudele. Peab meeletult "front-loaded" kõik olema. Kui esimese 5 minutiga kaifi kätte ei saa igas aspectis siis pole üldse mõtet mängidagi.
Mul on ME seeria alla ca. 2000 tundi pandud, Dragon Age alla ka oma 1000+, rääkimata vanematest mängudest. Ma olen õppinud nautima Bioware mängude sisu ja põhjalikkust, mitte pealiskaudset "veidi nokitsen, ühe korra mängin läbi ja vsjoo" kogemust.
SP osas ma ei tea palju ma kokku olen mänginud eelmisi osi. Ilmselt kuskil 500 tunni kanti kõigi kolme peale. ME3 MP olen mänginud ligi 2500 tundi, kuna see oli ja on üllatavalt hea. Nüüd veel eriti koos modidega kui saab ise muuta paljusid MP aspekte
ME3 MP on tõesti hea. Ma on-off mängin, kuid kuna nö. ametlik toetus eventide jms moel lõpetati paar aastat tagasi ära, siis pole väga viitsinud grindida.
Aga SP'd kütan suht off-cooldown.
Teen kogu triloogia läbi ja alustan kohe uuesti. Vist 10x vähemalt kogu triloogia läbi tehtud, kuid ikka leiab midagi uut ja huvitavat kuna variatsioone on lihtsalt niivõrd palju. Eri klassid, eri kaaslased missioonidel, teine moraalivalik, teine Shepardi sugu jne. ALOT graafika modid peale ning visuaalide pärast ei pea samuti muretsema.
Seega mnjah, minu poolest võiks ME:A'l üldse igasugune promo puududa ja mul oleks see ikka pre-orderis, sest ma lihtsalt ei näe võimalust, kuidas see mäng mulle ei võiks meeldida. Sama ka Dragon Age seeriaga. Andke mull võimalus teha DA4'le preorder mitte midagi mängust teadmata ja ma teeks kohe ära.
Ma ütleks, et Tomb Raideris on kordades kenamad juuksed. See pilt Andromedast meenutab mulle seda, nagu keegi oleks proovinud mooramehe soengut teha Max Payne'i esimese mootori peal. Mitte üks teps ei meenuta soengut, mis peaks olema ühes tänapäeva mängus.. Näiteks see soeng on suhteliselt okei mis sellel nais peategelasel on, aga ma ei tea miks mooramehel on pakk pabereid pähe visatud
Eelnevalt olen läbi mänginud ainult ME2 ning mälu järgi oli väga hea mäng kuna uus tulekul ja huvi suur siis otsustasin kõik kolm läbi mängida.
Hetkel plaan kõik järjest läbi mängida ning peab mainima, et esimene osa näeb hetkel veel super hea välja kuigi vahepeal esineb screen teari olenemata VSync olekust.
Kiidan otsust, aga kuidas ME1 juuksed on? Kannatab ikka vaadata/mängida?
