uus teema   vasta Uudised »  Riistvara »  Intel protsessorites avastati tõsine viga, turvaparandus vähendab jõudlust 5-30% märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3, 4, 5 ... 15, 16, 17  järgmine
sõnum 04.01.2018 10:55:33 vasta tsitaadiga
jeesus188 kirjutas:
2018-01-04 The Register ülevaade Inteli pressiteatest We translated Intel's crap attempt to spin its way out of CPU security bug PR nightmare
Kõige huvitavam "nali" - on hetkel vist küll see, et Microsoft lappis igaks juhuks ette ära ka AMD ning ARM Chipsettide turvaaugud. icon_smile.gif
Microsoft Releases Emergency Windows Update to Fix Intel, AMD, ARM Chip Bug
All Windows versions provided with critical fix
Microsoft has just released an emergency Windows update to address a vulnerability in Intel, AMD, and ARM chipsets that would allow attackers to bypass kernel access protections and take control of systems.
The security flaw, which was first believed to exist only in Intel processors, but which was then confirmed to also affect other chips, exposes kernel memory areas in a way that allows all apps to read protected content, thus exposing the data to unauthorized access.
Microsoft responded fast with today’s update, shipping it to all versions of Windows. What’s important to know, however, is that only Windows 10 is getting the update automatically today, while Windows 7 and Windows 8.1 will be offered the update on Patch Tuesday next week. Users can, however, install it manually already via the Microsoft Update Catalog.
Systems enrolled in the Windows Insider program in the Fast ring received the patch before the end of 2017 and no further action is required.
http://news.softpedia.com/news/microsoft-releases-emergency-windows-update-to-fix-intel-amd-arm-chip-bug-519216.shtml
wezztern
sõnum 04.01.2018 11:03:32 vasta tsitaadiga
Ega jah sellest oli kohe mainitud, et microsoft nn fixib ka AMD seda viga mida neil pole.Mis tähendab et amd võib ka nüüd windowsis mingi aeg raskeks minna kunu saab selgust, linuksis saab seda välja lülitada aga windowsis vast mitte.
NATAS999
sõnum 04.01.2018 11:05:08 vasta tsitaadiga
pigem siis juba terve x86(-64) fundamentaalselt auklik, mitte ainult kernelid, nendele ehitatud o/s'de haavatavusi pole mõtet mainidagi. icon_rolleyes.gif
mannatera
mannatera
sõnum 04.01.2018 11:08:12 vasta tsitaadiga
wezztern kirjutas:
Spectre on ka AMD prosedel auguks, aga selle vastu nagu ma aru saan rohtu polegi peale prose arhitektuuri muutuse.
Kommentaarid: 21 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 16
sõnum 04.01.2018 11:09:38 vasta tsitaadiga
link :: Today's CPU vulnerability: what you need to know
Selle info järgi on ka AMD mõjutatud.
Kommentaarid: 178 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 144
vanarebane
vanarebane
sõnum 04.01.2018 11:22:19 vasta tsitaadiga
wezztern kirjutas:
https://www.cnbc.com/2017/12/19/intel-ceo-in-memo-we-are-going-to-take-more-risks.html
Intel CEO to employees: 'We are going to take more risks'
Intel's Brian Krzanich wrote in a memo to employees on Tuesday that the company faces "an exciting challenge" in areas where it's an underdog.
The company's growth strategy is ultimately about data, he wrote.
ja sama aeg müüs oma inteli osakuid... ju siis oli teada, et kuskilt midagi hakkab lekkima..
https://www.fool.com/investing/2017/12/19/intels-ceo-just-sold-a-lot-of-stock.aspx?source=isafpbcs0000001&utm_campaign=firehose&utm_medium=feed&utm_source=sharewise
Kes ei hooma, siis Intel ei tee ainult CPUsid. Ehk ei ole vaja karta, et nad turul kohe nii kukuvad. Allikas
Aga jah, Inteli serveri CPUde müügile pani põntsu AMD oma Threadripperiga ja nüüd siis see turvaaugu krahh.
Tähenärimine on hammastele kahjulik!
Kommentaarid: 84 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 77
Reaper
Reaper
sõnum 04.01.2018 11:28:34 vasta tsitaadiga
Inteli aktsiad eile 4% kukkusid, aga tänaseks tagasi tõusnud, kokkuvõttes ainult -1%
Kommentaarid: 29 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 27
sõnum 04.01.2018 11:37:49 vasta tsitaadiga
Mark0 kirjutas:
https://googleprojectzero.blogspot.com.ee/2018/01/reading-privileged-memory-with-side.html
Jah, ka AMD (ning ARM).
sõnum 04.01.2018 11:39:20 vasta tsitaadiga
troglodyte kirjutas:
https://spectreattack.com/
https://googleprojectzero.blogspot.com.ee/2018/01/reading-privileged-memory-with-side.html?m=1
sorry aga pooled postid siin teemas ajavad aju lihtsalt valutama.
me teema on nii 2017 nagu keegi juba ütles.
opsüsteem puutub inteli vea puhul (meltdown) võrdlemisi vähe asjasse, tehtav on see kõigi all ja lahendus (mitte täielik lahendus vaid vähendab haavatavust oluliselt) praeguseks on kaiser patchid, mis kõigil kolmel suuremal opsüsteemil tulemas või olemas.
spectre on keerulisem ja haavatavad on kõik out-of-order prosed (ehk siis pea kõik tänapäevased laiatarbe prosed, kaasa arvatud arm). üht-teist annab teha softis haavatavuse vähendamiseks aga lõplikku lahendust ei ole.
edit:
muide, see jutt, et amd saab paigad ja neid pole vaja on lihtsalt rumal. andke andeks aga turva alal need asjad lihtsalt ei käi nii.
tegemist on avastatud ründe tüübiga, millele ka amd (ja ka arm) on potentsiaalselt haavatavad. ründe mõju vähendavad paigad lajatatakse peale kõigele ja siis hakatakse maha korjama kui on selgunud, et antud juhul kindlad protsessorid ei ole haavatavad. lisaks tasub lugeda ka meltdowni uurimustööd. uurijad märgivad seal muude protsessorite kohta nii:
We also tried to reproduce the Meltdown bug on several ARM and AMD CPUs. However, we did not manage to successfully leak kernel memory with the attack described in Section 5, neither on ARM nor on AMD. The reasons for this can be manifold. First of all, our implementation might simply be too slow and a more optimized version might succeed. For instance, a more shallow out-of-order execution pipeline could tip the race condition towards against the data leakage. Similarly, if the processor lacks certain features, e.g., no re-order buffer, our current implementation might not be able to leak data. However, for both ARM and AMD, the toy example as described in Section 3 works reliably, indicating that out-of-order execution generally occurs and instructions past illegal memory accesses are also performed.
- londiste
viimati muutis londiste 04.01.2018 11:49:02, muudetud 2 korda
Kommentaarid: 238 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 213
lynxfelinae
sõnum 04.01.2018 11:41:48 vasta tsitaadiga
2018-01-04 The Register: Meltdown, Spectre: The password theft bugs at the heart of Intel CPUs
Kommentaarid: 249 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 210
vanarebane
vanarebane
sõnum 04.01.2018 11:47:39 vasta tsitaadiga
Mina sain ühe oma HP masina patchitud HP enda välja lastud parandusega. Ei olnud vaja oodata Windowsi fixi.
Näite: https://www.dropbox.com/s/932ngltx2rolvjr/inteli-auk.jpg?dl=0
EDIT: Oota, kas see polegi see auk millest hetkel juttu? Aga check tool oli ju siin mainitud
lynxfelinae
vanarebane kirjutas:
EDIT: Oota, kas see polegi see auk millest hetkel juttu? Aga check tool oli ju originaalpostis
Tegemist Intel ME, SPS ja TXE probleemidega, mis praeguses teemas ei puutu asjasse.
sõnum 04.01.2018 11:50:34 vasta tsitaadiga
londiste kirjutas:
opsüsteem puutub inteli vea puhul (meltdown) võrdlemisi vähe asjasse, tehtav on see kõigi all ja lahendus praeguseks on kaiser patchid, mis kõigil kolmel suuremal opsüsteemil tulemas või olemas.
RedHat-i John Terrill ütleb üheselt, et Mõlema Probleemiga / keissiga tegeldakse praegu ühekorraga. icon_cool.gif
- nii, et "ära sae tükkideks" probleeme mida on mõistlik ühtse tervikuna lahendada. icon_smile.gif beer_yum.gif
Red Hat's John Terrill informs Softpedia today that Red Hat is aware of the two hardware bugs (Meltdown and Spectre) affecting most modern microprocessors and they're working on security updates to mitigate them on their supported operating systems.
Lugu ise:
Red Hat Says Security Updates for Meltdown & Spectre Bugs May Affect Performance
Gives users the ability to enable the updates selectively to better understand their impact on sensitive workloads
http://news.softpedia.com/news/red-hat-says-security-updates-for-meltdown-spectre-bugs-may-affect-performance-519214.shtml
sõnum 04.01.2018 12:03:30 vasta tsitaadiga
Mark0 kirjutas:
Mark0 kirjutas:
https://source.android.com/security/bulletin/2018-01-01
Lisame veel otsapidi MediaTek, nVidia, Qualcomm...
NB! Et mitte ennatlikke arvamusi tekitada - näiteks "nVdia" nime mainimine ei tähenda, et nüüd on kohe kõik nVidia GPU'd puudutatud. Pigem on antud juhul juttu osadest kiipidest, mida Androidi telefonides on.
sõnum 04.01.2018 12:08:07 vasta tsitaadiga
need kõik ehitavad armi arhitektuuri peal soc-e. arm ise arvab probleemidest nii:
https://developer.arm.com/support/security-update
- londiste
wezztern
sõnum 04.01.2018 12:23:39 vasta tsitaadiga
Tehti phm tavakasutaja test pärast fixi, gamemisel isegi paar fpsi juures )))
Link
sõnum 04.01.2018 13:12:17 vasta tsitaadiga
https://www.theverge.com/2018/1/3/16846784/microsoft-processor-bug-windows-10-fix
HV valuutakalkulaator
Kommentaarid: 461 loe/lisa Kasutajad arvavad:  :: 12 :: 7 :: 356
lynxfelinae
sõnum 04.01.2018 14:25:22 vasta tsitaadiga
Red Hati ametlik info
Kernel Side-Channel Attacks - CVE-2017-5754 CVE-2017-5753 CVE-2017-5715
https://access.redhat.com/security/vulnerabilities/speculativeexecution
There are 3 known CVEs related to this issue in combination with Intel, AMD, and ARM architectures. Additional exploits for other architectures are also known to exist. These include IBM System Z, POWER8 (Big Endian and Little Endian), and POWER9 (Little Endian).
Lisaks Intel, AMD, ARM protsessoritele on probleemid ka IBM protsessoritega.
Renka
Renka
sõnum 04.01.2018 14:31:13 vasta tsitaadiga
NATAS999 kirjutas:
Keegi polegi rääkinud, et OS kernelid auklikud oleks. Inteli x86-64 on auklik. Ja võibolla ka AMD, ARM arhitektuur - see vajab veel kinnitust.
Mnator
sõnum 04.01.2018 14:36:34 vasta tsitaadiga
Tundub, et RISC arhitektuur on algsüüdlane.
sõnum 04.01.2018 14:43:30 vasta tsitaadiga
Renka, kui arm ise arvab, et kohati on? https://developer.arm.com/support/security-update
Mnator, speculative execution, mis on üsna oluline osa branch predictionist out-of-order prosedes.
- londiste
viimati muutis londiste 04.01.2018 14:45:12, muudetud 1 kord
Renka
Renka
sõnum 04.01.2018 14:46:21 vasta tsitaadiga
londiste, ei arva ju? Ainus mis ma välja suutsin lugeda on, et Kerneli uuendused aitavad probleemi patchida. Nagu seda ka Inteli puhul. Sest no riistvara on võimatu patchida.
Uued prosed/mudelid on ARM sõnul veast priid riistvara tasemel või siis omavad kerneli patchi. ("All future Arm Cortex processors will be resilient to this style of attack or allow mitigation through kernel patches.").
Muidugi huvitaval kombel on kasutatud sõna mitigation - mitte fix vmt samal tasemel väidet.
mitigation - the action of reducing the severity, seriousness, or painfulness of something.
viimati muutis Renka 04.01.2018 14:48:04, muudetud 1 kord
sõnum 04.01.2018 14:48:25 vasta tsitaadiga
Renka kirjutas:
rogue data cache load (cve-2017-5754) = meltdown
variant 3: cortex-a75
variant 3a: cortex-a72, cortex-a57, cortex-a15
võtmesõnad armi avalduses on resilient ja mitigation.
- londiste
sukelduja
sukelduja
sõnum 04.01.2018 16:35:53 vasta tsitaadiga
Renka kirjutas:
See on pigem lubadus, et me tulevikus (tõenäoliselt) fiksime selle probleemi ära. icon_smile.gif
TxT
sõnum 04.01.2018 17:10:25 vasta tsitaadiga
https://www.bleepingcomputer.com/news/security/google-almost-all-cpus-since-1995-vulnerable-to-meltdown-and-spectre-flaws/
uus teema   vasta Uudised »  Riistvara »  Intel protsessorites avastati tõsine viga, turvaparandus vähendab jõudlust 5-30% mine lehele eelmine  1, 2, 3, 4, 5 ... 15, 16, 17  järgmine
