uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  OnePlus 3/3T märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 33, 34, 35  järgmine
sõnum 14.03.2016 14:57:44 OnePlus 3/3T vasta tsitaadiga
Tuleb välja Juunis.
http://www.cnet.com/news/the-oneplus-3-will-launch-in-late-q2-exclusive/
"Uus disain" väietavalt. Samuti muudetakse vist saadavust paremaks.
edit:
The OnePlus 3 concept images come from Chinese technology blog Mobile-Dad and show a sleek device with an elegant, chamfered metal frame. The front camera seems to be located on the top right side, while a speaker grille comes in the middle, slightly higher than the camera module. At the bottom, the OnePlus 3 apparently features a physical home button, which should house a fingerprint sensor.
On the rear, the OnePlus 3's main camera seems to have a dual-tone LED flash. The familiar "1+" logo rests below the camera.
The OnePlus 3 further has a USB Type-C port, an alert slider and a dedicated camera button.
When it comes to hardware specifications, the OnePlus 3 is expected to sport a 5.5-inch full HD display (1,920 x 1,080 pixels), pack the latest Qualcomm Snapdragon 820 powerhouse under the hood, boast 4 GB of RAM and run Android 6 Marshmallow out of the box. The handset should also come with a 20-megapixel rear camera.
The OnePlus 3 will make its official debut in June, as OnePlus co-founder Carl Pei recently confirmed. The smartphone could cost roughly $350 unlocked.
As always, take all leaks, rumors and speculation with a grain of salt until the official announcement. In the meantime, we're still waiting for some higher-quality images to surface and offer a better look at the OnePlus 3 design.
Allikas: http://www.techtimes.com/articles/139168/20160307/oneplus-3-shows-up-in-concept-images-rocking-new-design-to-complement-snapdragon-820-horsepower.htm & http://www.mobile-dad.com/a/286/18421.html
viimati muutis SKG 24.12.2017 20:56:39, muudetud 1 kord
sõnum 14.03.2016 15:25:27 vasta tsitaadiga
Kommentaarid: 133 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 120
kusjev
kusjev
sõnum 14.03.2016 15:48:10 vasta tsitaadiga
Hea uudis, eriti dedicated camera button
W!ngs
W!ngs
sõnum 14.03.2016 19:29:41 vasta tsitaadiga
kusjev kirjutas:
Mis selles nii erilist on? Tänapäeval saab paljudel telefonidel erinevaid nuppe või kombinatsioone seadistada nõnda, et kaamera avaneks ja/või teeks pilti.
sõnum 14.03.2016 21:31:01 vasta tsitaadiga
Küsimus ei olegi selles, et nupule saab erinevaid funktsionaalsusi määrata, vaid et lisaks kolmele-neljale nupule on olemas veel eraldi füüsiline nupp, millel on omaette põhifunktsionaalsus, ehk siis üks koht, mis teeb ainult ühte asja igal ajal. Lisaks nupu paiknemine loogilises kohas, kui pildistaja hoiab telefoni käes nagu fotoaparaati ja mis ka käitub füüsilise juhtimise poolt sellena.
Oluline neile, kes pildistavadki rohkem, kui räägivad nutiseadmega.
See eraldi füüsiline kaameranupp oli vahepeal surev nähtus, nüüd siis pannakse mõnele mudelile jälle tagasi.
sõnum 14.03.2016 22:01:38 vasta tsitaadiga
Minu OPO-l on power nupp selleks. Ei igatse otseselt eraldi nuppu.
OPO tehti üldse nii hea ja oma ajast ees telefon, et pole veel endale põhjusi leidnud, miks peaks OP2, OP3 või mõne muu ostma.
sõnum 14.03.2016 22:17:11 vasta tsitaadiga
Ajaga tuleb kaasas käia ja silmad häbenevalt maha lüüa ülemöödunud aastase tehnika kasutamisest rääkimisel. icon_cool.gif icon_biggrin.gif
Kaameranupp tundub palju loogilisemal kohal olevat, nagu seda näitena mu vanal Xperia S telefonil oli. Toitenupp on lihtsalt kasutusmugavuselt vale koha peal. Aga maitse asi.
mufferino
sõnum 20.03.2016 08:34:59 vasta tsitaadiga
Jälgin, eks siis juunikuus saab opo välja vahetada thumbs_up.gif icon_lol.gif
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 32
sõnum 17.05.2016 14:43:39 vasta tsitaadiga
http://www.besthotdeals.in/2016/03/oneplus-3-appears-on-antutu-benchmark.html
edit:
Nonii.. Pole paha. meenutab HTC-d, aga soliidne valimus. 3.5mm audioport all nagu Apple-l?
OnePlus 3 with AMOLED display and 3000mAh battery.
Allikas: https://twitter.com/evleaks/status/732465553378418688
Tint
sõnum 17.05.2016 14:51:10 vasta tsitaadiga
Aku võiks suurema mahtuvusega olla ehk..
Kommentaarid: 33 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 30
lightbluefox
sõnum 17.05.2016 14:54:24 vasta tsitaadiga
Miks nad sõrmejäljelugejat külje peale poweri nupu juurde tuua ei taha, sinna keskele vajutamine on tüütus.
sõnum 17.05.2016 17:56:17 vasta tsitaadiga
lightbluefox kirjutas:
Mu poolest voiks taiesti olemata olla. Kaotagu see mehaaniline home nupp ara, nagu OPO puhul oli ja telefon oleks ilusam.
Tint
sõnum 23.05.2016 09:02:50 vasta tsitaadiga
On igasuguseid lekkeid Oneplus 3 välimusest, pole kusagil confirmed, et välimus just selline on. Paljud lekked näitavad, et füüsilist home nuppu justkui poleks... Varsti tuleb, eks siis näe
Snaztastic
Snaztastic
sõnum 23.05.2016 17:25:07 vasta tsitaadiga
Kellelgi õnnestus endale Oneplusi uus VR ka saada? 30 000 andsid tasuta ära. Ise jõudsin 1 võtta.
sõnum 23.05.2016 17:26:23 vasta tsitaadiga
Tint kirjutas:
Loodan, et see on tosi.
Rasvane
Rasvane
sõnum 23.05.2016 19:42:10 vasta tsitaadiga
Snaztastic kirjutas:
Nägin kui mail saadeti 1h tagasi. Siis olid juba outof stock, sadly.
mauro
mauro
sõnum 23.05.2016 21:40:39 vasta tsitaadiga
Jah, u 40 min tagasi - tuli korraks saadavale nii umbes 5 minutiks. Eks nad tilgutavad vähehaaval neid.
Zonerman
Zonerman
sõnum 23.05.2016 22:18:48 vasta tsitaadiga
Üritasin ka mingi pool tundi aga tundub, et päris otsas. Need kes said viimati on ka hädas tellimuste vormistamisega.
Edit: Tegin refresh peale seda sain carti pandud ja maksmisel oli juba otsas. Minge persse tõesti icon_biggrin.gif
Kommentaarid: 63 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 62
mauro
mauro
sõnum 23.05.2016 22:29:54 vasta tsitaadiga
Zonerman kirjutas:
Edit: Tegin refresh peale seda sain carti pandud ja maksmisel oli juba otsas. Minge <b>piixu</b> tõesti icon_biggrin.gif
Nad tegid vea - lasid rohkem kui ühe tellida (iseasi kas läbi läheb) ning ei olnud mingit paid account piirangut (ehk kui selle kasutajaga on keegi varem neilt ostnud) - pole ime kui varsti näed mingit hiinlast ebays müümas "1000 in stock".
Snaztastic
Snaztastic
sõnum 01.06.2016 19:53:59 vasta tsitaadiga
mauro
mauro
sõnum 01.06.2016 20:42:47 vasta tsitaadiga
Welcome out of stock and shipping queue.
Tundub, et brändile nimi tehtud - nüüd saab hinda tõsta ja "ustavaid jüngreid" koorida.
newarvuti
sõnum 01.06.2016 21:36:59 vasta tsitaadiga
Sain kohe alguses jaole, pending shipment.
Kommentaarid: 87 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 76
mauro
mauro
sõnum 03.06.2016 19:45:39 vasta tsitaadiga
Postitamine algab esmaspäeval.
JRISETH
sõnum 14.06.2016 19:47:09 vasta tsitaadiga
400€ 6GB/64GB versioon, sai tellitud ja guaranteed delivery date näitab 20 juuni.
Kommentaarid: 227 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 200
kriist
kriist
sõnum 14.06.2016 20:21:07 vasta tsitaadiga
Link
Kommentaarid: 101 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 91
uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  OnePlus 3/3T mine lehele 1, 2, 3 ... 33, 34, 35  järgmine
