uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Samsung I9100 Galaxy S II märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 206, 207, 208 ... 284, 285, 286  järgmine
danny
danny
sõnum 27.01.2013 19:45:31 vasta tsitaadiga
commoon kirjutas:
Mis selle originaal 4.1.2 ja leaked versiooni vahe on?
Üks on leaked teine ei ole lihtsalt veel meie maale välja lastud.
Lisaks on JB baasil Wanamlite.
Based on latest Jelly Bean base LS8
Repacked Stock Kernel + Safe CWM (Thanks to Philz)
Deodexed (smali 1.4.2) & Rooted & Zipaligned & Busybox
Pure Stock Themed
Aroma installer
Unlimited SMS recipient list
No SMS to MMS convert
Automatic SMS encoding (Arabic support)
23 customizable Status bar + Numeric Circle battery (Available on a separate patch)
Numeric Circle battery (Optional on Aroma)
Tweaked Speed & Battery life
Disabled scrolling cache
Enabled All languages (Arabic, Hebrew...) on settings menu and keyboard
Debloated (Removed Apps available on Aroma installer)
Large APN list
No incremental ringtone
Enabled Call recording
Enabled Ripple effect on Stock Lockscreen (Optional on Aroma)
Enabled Sensor aiding for fast GPS lock & better battery life
4 Way reboot
Fixed Right to Left allignement for Arabic/Hebrew (Optional on Aroma)
4 Shortcuts on the Lockscreen
Clean build.prop for best Market compatibility
Kies support
Call Button on Contacts List (You can hide it from Aroma installer)
Stock dialer buttons
Hacked Email App
Unlimited Wifi AP clients
Unlimited Contact joining
Disabled Shutter on Apps
Moved All system apps on Preload partition to get more space on System partition
Swype keyboard (Optional on Aroma)
Enabled Shutter sound menu on Camera
Tweaked CPU sampling rate for better battery life
Kommentaarid: 46 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 39
ivar80
ivar80
sõnum 28.01.2013 12:25:01 vasta tsitaadiga
Kiire akutühjenemine oli ka minu telefonil probleemiks, kui seda testversiooni JB'd kasutama hakkasin. Suurim põhjus oli selles, et vaikimisi seadetega hakkab google+ üles laadima kõiki pilte ja videosid mis sul telefonis on, konks maha ja kohe palju parem. Teine suur killer oli "Asukoha teenuste" all asuv google asukohamääraja.
cuda
sõnum 30.01.2013 17:57:11 vasta tsitaadiga
Üritan seda wanamlite'i ROMi peale lasta aga system recovry annab järgmise veateate:
E:unknown volume for path [SDCARD:/romi asukoht mälus]
E:can't mount SD card SDCARD:/romi asukoh mälus
Hetkel on peal see ametlik jelly bean'i hispaania versioon. Rootimiseks kasutasin CWM-SuperSU-v0.87.zip-i.
Wanamlite'e ROMi zip on kopitud telefoni sisemälusse ja siis CWM rom manager'ist valides "install ROM for SD card" annab ülaloleva veateate.
Esimest korda mässan rootimisega ja seege üsna tõenäoline, et teen midagi valesti.
Oskab keegi abistada?
sõnum 30.01.2013 18:12:29 vasta tsitaadiga
Sa pead minema sd kaardile ja selle. zip yles otsima ja siis vajutama ok.
Ma ei saanud aru, kas sa tegid nii.
Kui ma õigesti mäletan, siis mobla mälu ei saanud kasutada (võin ka eksida)
Google abiks
Edit:
Vaatasin järgi
Install zip> choose zip internal>otsi yles zip yles ja installi ära
cuda
sõnum 30.01.2013 18:35:07 vasta tsitaadiga
jeesus188 kirjutas:
Kus sellised valikud on? CWM menüüst midagi sellist ei leidnud (ROM manager 5.5.1.7)
sõnum 30.01.2013 18:41:06 vasta tsitaadiga
cuda kirjutas:
jeesus188 kirjutas:
Ee, ma ei tea, mul wanamlite koguaeg peal, CWM on alati kaasas olnud icon_lol.gif
Pole midagi juurde installinud.
Pane siis läbi ODINi peale, kui nii ei õnnestu
eltso
eltso
sõnum 31.01.2013 01:35:19 vasta tsitaadiga
sa üritad seda telefoni menüüst teha, see ei toida. Pead minema CWM recoverysse ja selleks lülita telefon välja ja hoia vol+ home power korraga all. Seal on need vajalikud valikud olemas icon_smile.gif
sõnum 31.01.2013 01:55:29 vasta tsitaadiga
eltso kirjutas:
kuna mul pole kunagi mõte isegi selle peale tulnud, siis ma ei osanud seda oodata icon_smile.gif
eltso
eltso
sõnum 31.01.2013 02:06:20 vasta tsitaadiga
Ma mingil hetkel kunagi proovisin ka ühe telefoni sisest imeproge, aga ei toiminud see asi seal väga, seega tunne on tuttav icon_biggrin.gif
marti384
sõnum 31.01.2013 15:22:26 vasta tsitaadiga
jamad järgmised:
1. WIFIga netis olles vahel telefon lambist lülitab ennast välja, samas kui aku on näidu järgi (battery indicator app) veel 50-60% ringis. Kui telefon uuesti sisse lülitada, siis näitab et aku on peaaegu tühi....vaid 10% ringis alles.
2. vahel kiilub WIFI nupp kinni. Kui telefonile restart teha, siis on jällegi aku näit kõvasti langenud.
telefon ise 1a 4kuud vana. 5 kuud tagasi garantiis vahetatud esipaneel, sest kodunupp pani segast (võttis tihti ühe nupuvajutuse ikkagi 2 nupuvahetuse pähe ja see aktiveeris Voice commandi...muutus väga häirivaks).
androidi versioon 4.0.3
on see selle android 4.0.3 viga? või on aku läbi? või midagi muud?
Tänud ette vastajatele.
night596
night596
sõnum 31.01.2013 15:50:45 vasta tsitaadiga
See et wifi nupp kiilub on androidi viga,sest 4.1.2 seda enam pole. AGA kui sa wifi kastutad , kas telefon muutub soojaks ka v, kui jah siis koormab mingi muu asi telefoni ja sp näitabki 10% aga miks ta välja lülitub seda ma öelda ei oska.
föönitaja
sõnum 31.01.2013 18:53:00 vasta tsitaadiga
Kuna SII-l puudub notification LED indikaator, siis kas keegi on leidnud programmi, millega saaksin alumised puutetundlikud nupud panna vilkuma kui olen maha maganud kellegi kõne, sõnumi või muu notificationi? Ainukene programm mille leidsin on NoLED, kuid too kuvab mulle ekraanile vaid väga ebapäraselt paigutatud väikesed ikoonid. Kuna olen selline minimalist, siis neoon-värvides ikoonid ei ole just minu teema. Äkki kellelgi sama mure?
isiklik
sõnum 31.01.2013 19:16:20 vasta tsitaadiga
föönitaja kirjutas:
Mina vajutan HOME nuppu ja vaatan, kas on vastamata kõnesid, SMS-e jms.
eZ
eZ
sõnum 31.01.2013 20:45:31 vasta tsitaadiga
föönitaja kirjutas:
Kui kasutad CustomROMi ja kernel toetab BLN muutmist siis on see võimalik, STweaks või misiganes selle appi nimi ei olnud, millega saad kerneli seadetes BLN seadeid näppida.
kr6ll
kr6ll
sõnum 31.01.2013 21:56:13 vasta tsitaadiga
kuulge. ma siin yritan seda 4.1.2 peale panna aga ilge jama on selle tar.md5 unzippimisega. millega seda teha
Kommentaarid: 89 loe/lisa Kasutajad arvavad:  :: 1 :: 2 :: 69
Dijital
Dijital
sõnum 31.01.2013 21:57:30 vasta tsitaadiga
Seda ei peagi unzippima.
Mobrog tasustatud küsitluste paneeli affiliate link: KUTSE
Kommentaarid: 40 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 31
teitur
teitur
sõnum 31.01.2013 22:10:18 vasta tsitaadiga
marti384 kirjutas:
jamad järgmised:
Mul tutikas telefon lülitas ka ennast välja ja tõmbas aku tühjaks kui õigel ajal jaole ei saanud.
Viisin garantiisse, eks varsti näeb siis mis kostavad.
kr6ll
kr6ll
sõnum 31.01.2013 22:10:23 vasta tsitaadiga
seal odin 3.7. kuhu ma selle faili panen. kas sinna PDA, PHONE või kuhu? Need õpetused imevad.
Dijital
Dijital
sõnum 31.01.2013 22:21:07 vasta tsitaadiga
kr6ll kirjutas:
Need õpetused, mida mina näinud olen (suvalised google'i esimesed lingid) on ikka väga korralikud olnud. Kui nendest aru saamisega probleeme, siis ma parem ei torgiks
kr6ll
kr6ll
sõnum 31.01.2013 22:25:57 vasta tsitaadiga
korralikud õpetused jah aga failid mis seal on, mul nagu selliseid pole. Kust seda alla 4.1.2 tõmmata?
night596
night596
sõnum 31.01.2013 23:25:25 vasta tsitaadiga
Vaata siia : http://www.ibtimes.com/android-412-jelly-bean-official-update-available-samsung-galaxy-s2-gt-i9100-how-install-it-manually#.UP-VfE2Enf8.twitter
kr6ll
kr6ll
sõnum 31.01.2013 23:37:00 vasta tsitaadiga
sõnum 31.01.2013 23:59:53 vasta tsitaadiga
kr6ll kirjutas:
kr6ll
kr6ll
sõnum 01.02.2013 00:11:34 vasta tsitaadiga
no mingi õpetus oli et tee odin lahti ja siis pane yks fail phone ja teine ma ei tea kuhu nupu alla jne. Lihtsalt need õpetused imevad. Siis arvasingi et tuleb ehk see lahti pakkida kuna mul polnd selliseid asju nagu need seal õpetuses näitasid. Lõpuks oli mul nii savi et panin lihtsalt tuimalt nagu ise arvan et õige on. Abi oli sellest et öeldi siin et pakkida lahti pole vaja thumbs_up.gif
Zeto
Zeto
sõnum 01.02.2013 18:09:12 vasta tsitaadiga
teitur kirjutas:
marti384 kirjutas:
jamad järgmised:
Mu oma käis ka kohe peale ostmist garantiis. Samamoodi lülitas end poole aku pealt lambist välja ja käima ilma akut korra eemaldamata ei saanudki.
Oli 2 nädalat elisas remondis ja kättesaades oli tarkvara uuendus tehtud.
Aga nüüd pole rohkem jamanud. Lasin kohe Jelly Beani ka peale, ehk see ka abiks.
Kui aga akuteema välja jätta (mis peab ikka häbematult vähe) olen aparaadiga rahul, eriti Wildfire pealt tulnuna.
Siiamaani parim norm suuruse ekraaniga mobla turul.
uus teema   vasta Hinnavaatlus »  Mobiiltelefonid/ GPS seadmed / Muu tehnika »  Samsung I9100 Galaxy S II mine lehele eelmine  1, 2, 3 ... 206, 207, 208 ... 284, 285, 286  järgmine
