sõnum |
XeStAiSy
29.10.2011 08:18:38
Kurrat üks uuendus keeras käkerdi sassi. Nende uuendustega peab ettevaatlik olema. Nüüd on jälle korras. Lasin vana uuends pakki tagasi.
Sant, Kust sa võtsid ,et hakkab skoorima nüüd. Ahhjaa no heakene küll.
Nii xtop GPU Linuxis on minuoma 6970.
http://moowrap.net/gpu_list.php
Nojaa wtf
Total
(1.000) AMD Radeon HD 6900 series (Cayman)
(0.941) ATI Radeon HD 5800 series (Cypress)
(0.690) ATI Radeon HD 4700/4800 (RV740/RV770)
(0.337) ATI Radeon HD 5700 series (Juniper)
Windows
(1.000) ATI Radeon HD 5800 series (Cypress)
(0.729) ATI Radeon HD 4700/4800 (RV740/RV770)
(0.358) ATI Radeon HD 5700 series (Juniper)
Linux
(0.890) ATI unknown
Mac
No GPU tasks reported
Kommentaarid: 11 loe/lisa |
10 |
sant
31.10.2011 00:21:41
Sicis oli küsitlus gpu failimiste kohta (24\7 crunchimisel siis) ja üllatavalt vähestel oli probleeme old kunagi, põhi fail oli jahutus ventide ärasuremine, sama probleem vaevas ka kunagi Steve.
Tsiteerin cncguru:
tsitaat: |
WHAT I HAVE HAD PROBLEMS WITH is power supplies and motherboard pcie channels not being able to withstand the constant current with 4 or more cores running OC'd 24/7. I've killed two Asus P6T7's and one P6T6 plus 2 antec 1200's. The antec will happily drive (4) non overvolted 5870's but (4) 6970's @ 950/685/1200 killed them dead after only a few months.
And I even killed a Silverstone ST1500 with (5) MSI Lightning GTX580's running @ 950/1050/+140 on my SR-2(which survived TG)he also ran away from everyone on Primegrid.
Tsitaat minult:
tsitaat: |
I have had no bad experiences with gpus. Crunched on over 10 different ones over the years and no failures. One gpu did fail (allmost immediately), but that was a faulty one and i rma-d it. Currently runnin on 7 gpus, 5 of them nvidia, all aircooled and all nvidias have their shaders oc-d to max stabile w\o overvolting, been doing that for years and i dont expect failures. They probably will go out of date before failing.
Huvitav info einsteini kohta:
tsitaat: |
Part of the project is run by the University of Milwaukee and part of it by the Albert Einstein Institute in Hannover. The main database and all CPU work is handled in Milwaukee. All the GPU work is coming from Hannover
Mina ei teadnud näiteks seda
Millega tegeleb einstein:
tsitaat: |
Einstein@Home is a program that searches for gravitational waves from spinning neutron stars (also called pulsars) using data from the LIGO gravitational wave detector. Einstein@Home also searches for radio pulsars in binary systems, using data from the Arecibo Observatory in Puerto Rico.
Einsteinis leiti uus pulsar: http://einstein.phys.uwm.edu/forum_thread.php?id=9150#114698
_________________ So, at the end of the day, after I have butchered all the nvidiots all around me, standing alone in a pool of blood surrounded by the corpses of my victims, a horrible truth reveals itself to me: I am an amd\ati fänboy...and I must do my dark masters bidding, for I am damned for all eternity... |
Kommentaarid: 67 loe/lisa |
60 |
XeStAiSy
31.10.2011 09:15:20
Ma küpsetasin 4870X2 kaardi maha ventilaator juba pärises ja kaart oli vajunud banaani. Kaart vajus aastaga kõveraks. Peale 2 aastat suri ventilaator. Plärisema hakkas. Intelt stock ventilaator on ikka mehiselt vastu pidanud samuti 5 aastat vana 24/7 olnud PSU TX650 on ka ikka juba klass omaette.
Mina teisi ei osta sest surevad aastaga maha paljukiidetud forton suri aastaga maha + keeras emaplaadi ka nässu ja ilmnesid vead kuigi parandasin ära kasutasin ja ostsin uue PCI-Ex ver 2.0 siine oli vaja.
100 euro eest saab uue psu corsairi oma. Suvel võtangi uue PSU ligi. 700-850w Hetkel ei kanata teist kaarti masinasse toppida. Kui juba siis üks HD7k midagi võtta ligi double power ja sama vooluõgimine. Nice oleleks siis singlegpu kaardiga lasta millel hetkeseisuga double power. Muidu maksa 300 raha teise 6970 eest ja kui 7k tuleb saab palju parema lahenduse sama rahaeest.
Mina teisi tootjaid ei eelista rohkem kui siis ainult Sapphire. Samuti ma ei tegele fläshimise ja kellamisega. Tõesti tore tükk on vähimatki probleemi pole.
Lolli aruga sai linuxis x.org server core uuendatud siis viskas compute errorit. Aga muidu on kõik ok.
Liigapalju uuendusi tuleb linnile pidevalt. Windows ikka ei uuene nii tihti ja seal ka vähem probleeme.
Ma olen oma linni 20 päva kottinud no ei lähe katki nagi win seda teeb 2 kuupärast, eriti asi muutub imelikuks kui voolukatkestus winnis tuleb kohe on ka anomaaliad. cache on kinni väänatud ja ikka ḿuutub naljakaks see win.
10 |
sant
01.11.2011 02:05:28
tsitaat: |
Margus, ups aitab selle vastu hästi, mul endal on neid kokku 3 et ei oleks pobleeme.
Palju sul neid pci-e siine on muidu mobol? Kui tahad võid soodsa hinnaga mu gts 450 ära osta, saaksid nvidia projcte lisaks\vahelduseks jooksutada ja mina saaksin endale põhjuse 550ti osta. Ati\nvidia mix winni all on mul probleemi vaba, linuxi kohta ei oska öelda midagi.
60 |
XeStAiSy
02.11.2011 10:04:53
Nii linn läks peale ati 11.10 driveritega x64 peal segi. Maadlesin tunde ja lõin käega sellele installile panin 32bit peale ja näe imet toimib 11.10 catalyst.
Selline jebla mis x64 peal oli seda 32 peal pole. Linuxis pole vahet kas x64 või 32 mälu on ikka 4GB kasutusel, see pole windows mis selliseid nalju teevad.
vaatame kas purustab linuxi 32 bitine ver 30 päeva ennem kui midagi juhtub. Igatahes catalyst driverid läksid täielikult peale.
Hetkel saab ainult milkywayd kasutada. Niikaua kui 32 bit moo wrapperisse tuleb. Hetkel seal ainult x64.
10 |
sant
06.11.2011 01:14:06
Niih, pg-s nüüd pps sieve cuda wu scoor 2251 punni. Gtx 580 peaks tegema ühe sellise wu 10-ne mindiga või nats alla, kellatuna kiiremini muidugi. Mu gtx 570 nats kellatuna teeb 10 minti 30 secci per wu. Rohkem neil scoori madalamks lasta pole plaanis.
DistrRTgen-nist ei saa juba pikemat aega gpu wu-si, neil on jälle servu probleemid, project on mõnesmõttes ikka veel beeta staadiumis ja paistab et nii jääb mingiks ajaks, cpu wu-si saab aga mind need ei huvita.
Vaatasin huvipärast oma statse, ja siin olen kohal 60: http://boinc.berkeley.edu/chart_list.php
Boinc totali järgi olen esimese 200-ja seas maailmas: http://boincstats.com/stats/boinc_user_graph.php?pr=bo&id=df8a8be23d4c1474e98475e522340a39
Selle järgi ei ole: http://boinc.netsoft-online.com/e107_plugins/boinc/get_user.php?cpid=df8a8be23d4c1474e98475e522340a39&html=1
Ma olen alati imestand miks nad erinevalt näitavad
60 |
Sahib
07.11.2011 16:21:03
sant kirjutas: |
Gtx 580 peaks tegema ühe sellise wu 10-ne mindiga või nats alla, kellatuna kiiremini muidugi. Mu gtx 570 nats kellatuna teeb 10 minti 30 secci per wu. |
Ca 9,05minti. Pisut kellatud jah (core 858, memory 2100. Fan speed 50% ja temp max 77C )
Kas sebid ühe kasti juurde, sest miljonit päevas ei tule?
_________________ Mõtet harutades võib jõuda mõttetuseni ... |
Kommentaarid: 60 loe/lisa |
55 |
sant
07.11.2011 21:49:57
tsitaat: |
Sahib, ei ole vajadust, praegu jooksutan muid asju. Ei viitsinud kogu rauaga einsteini challengest osa võtta, neid challengeid nii palju viimasel ajal et kopp ees juba. Otsustasin ati driverid järjest ära proovida, praegused toodavad nüüd teist päeva usinasti prahti juba
60 |
XeStAiSy
20.11.2011 09:38:27
sant kirjutas: |
tsitaat: |
Sahib, ei ole vajadust, praegu jooksutan muid asju. Ei viitsinud kogu rauaga einsteini challengest osa võtta, neid challengeid nii palju viimasel ajal et kopp ees juba. Otsustasin ati driverid järjest ära proovida, praegused toodavad nüüd teist päeva usinasti prahti juba |
Mul ka linni all 11.10 praht, 1.9 praht, 11.8 hea. Windoozas on kõik head.
E:
Sain selle linni bugile jälile miks prahti tuli. Nimelt tavaline ja lihtne bug. Kui näiteks külastada erepublikut ja panna battle, seal tuleb scriptitud java siis seal hakkabki prahti tootma. Ma ei tea ka kuidagi adobe flash ka prahistab. 11.11 catalyst tõi natuke eemale prahist.
Linni stabiilsust võib pidada väga rahuldavaks, nagu ka windows. Boinc võib kuudeviisi müttata ilma ,et peaks mingeid trikke tegema. Sarnaselt foldimisel nagu seda folding@home olid ponnistused igapäev.
10 |
Sahib
23.11.2011 00:46:16
Mingit kummalist on toimumas. Vahepeal viskab tööaja ka kahekordseks
55 |
sant
06.01.2012 03:14:25
Sahib, distrtgen muutis wu-d pikemaks ja suuremaks:
tsitaat: |
WUs will be 7.625 MiB per upload and the chain count is aligned with cuda kernel call sizes.
They should take longer than the current table per WU so the uploads should be less frequent.
Mul jooksevad wu-d pea 2 korda kauem kui enne. Gtx 570 enne ~12 minti, nüüd ~20 minti (runtime 1223 sec\score 7470) See screen mis sul on Sahib, seal on wu-d waiting to run, mul nii ei ole. Huvitav miks sul nii on
Edit: uus cpu project on boinci all väljas (kui kedagi huvitab): http://boinc.med.usherbrooke.ca/nrg/
Distrtgen: cuda töö jälle maas:
tsitaat: |
Cuda work hand out is stopped. CPU hand out continues for the current time. This work stoppage is likely to be 2 weeks or more.
Essentially there is 8 TB worth of completed data that needs perfecting runs. The literal meaning is we are out of space. Planning for when our power supply gets replaced based on unknown time frames and computational growth are items that meant the date and time of hitting this point were not expected this soon.
Having 100 new cuda cards in a week seemed crazy previously but a quick glance at a graph seems to show 200-300 new cuda cards this past week.
At this point even if we found co-location, we now have been blacklisted by 2 payment processors so we cannot even accept donations much less ensure we could pay such a bill.
Probleeme neil jätkub kahjuks
Teema arutlus siin: https://www.freerainbowtables.com/phpBB3/topic3197.html
Pg-s tuleb pps sieve gpu challenge :
http://www.primegrid.com/
Seoses sellega:
tsitaat: |
The WU size was increased by 50% to make it easier on the servers during the upcoming Winter Solstice Challenge. Credit per WU was therefore increase by the same amount.
Kes tahab võtku osa, toetab ka ati kaarte Ei skoori ni hästi kui nvidial, aga töötab.
Eelmine kord jäin 37-le kohale, vaatab palju seekord saab. Seekord võtan ati kaartidega kah osa
Edit:
Primegrid challenge läbi ja jäin kohale 72 Vähemalt esimese 100-ja sisse siiski
Distrtgen:
tsitaat: |
WUs for GPU now flowing.
Tuld
Edit: Ah, fack it, servu mitu päeva maas juba
Aga Moo! annab jõulu boonus crediiti praegu http://moowrap.net/forum_thread.php?id=178#1906
tsitaat: |
I like that Mill Im getting from 2, 5830's, a day.....
Use to be 450k.
hull boonus nagu
Edit: sain päeva kasutaja olla , vist esimest korda elus: Sellise profiiliga siis: http://boinc.freerainbowtables.com/distrrtgen/view_profile.php?userid=16722
60 |
XeStAiSy
08.01.2012 19:53:32
UUs projekt ati meestele. POEM@HOME http://boinc.fzk.de/poem/ pornu on veel kuid eks areneb veel. Ei kasuta kogu GPUd.
10 |
sant
16.01.2012 21:22:10
Nalja kah:
tsitaat: |
Renderfarm had done some upgrades lately.
Unfortunately, there are people that are receiving 0 credit for crunching.
I had over 50% of the WUs receive 0 credit.
Suggestion:
Do not crunch unless you don't care..
tsitaat: |
i don't care... but i don't crunch either.
koomikud koos krt.
Edit:
Margus, varsti proovin seda poem@home värki, pole aega praegu jamada. Aga:
tsitaat: |
7970 up and running at MW if anyone has one, and you want to stretch its legs, 52-53 seconds per WU. Its solid and runs well.
tsitaat: |
At present 7970s are running on MW using a NVidia OpenCL app - works well, high utilisation, usual OpenCL speed issue but runs faster on a 7970, than a 6970 runs a native AMD CAL app.
tsitaat: |
PPS Sieve AMD not running on a 7970. Tried two sessions of two WUs each time.
WUs fall over right at the start around 15-20 seconds and hit computation error. Thats the same behaviour on MW with their AMD Stream app. Moo also falls over similar symptoms.
Collatz runs ok and completes, awaiting to see if they validate against a Wingman
Teema: http://www.primegrid.com/forum_thread.php?id=3921#46481
Margus, palju see 7970 su 6970-st kiirem on MW-s?
Mu kunagine 4870 tegi nats alla 4-ja minuti MW wu.
60 |
Sahib
17.01.2012 15:01:24
tsitaat: |
580 GTX teeb 2.50-3.00 minutit. Paar päeva käian seda projekti vahelduseks
Kahju et Distrtgen on maas
55 |
XeStAiSy
18.01.2012 07:37:39
Ma ei tea palju kiirem on 400€ ei taha hetkel kaardi alla panna. Kui 6k kaob turult peaegu siis langevad ka hinnad. Ma lasen mõned MW wud ja ütlen ajad.
51-54 sek on hetkel. Mul on tuunitud bios arvutil ka. Ma arvan ,et PCI-E läbilase jääb paljudel piirama seda 7970 kaardi x2 versiooni. Umbes 2000 shaderit oli vist, peaks juu kiirem käkerd olema. CPU ei tohiks jalgu veel jääda. Ilmselt siin double p shadereid sama kogus mis minul.
Kes oma ATIde ja idiootide käkerditega tahavad natuke betatestida Siis teile Albert@home samuti boinc kuid see vist einstein@home ristsugutis.
10 |
sant
19.01.2012 06:15:01
tsitaat: |
tsitaat: |
Margus, Siis on ju küll sukcs rohkem ei oskagi öelda.
60 |
XeStAiSy
19.01.2012 06:55:17
sant kirjutas: |
tsitaat: |
tsitaat: |
Margus, Siis on ju küll sukcs rohkem ei oskagi öelda. |
Sukcs võib ainult MW all olla, kuid moo ja teised on kiiremad. Teised DP ei kasuta vist.
10 |
sant
05.02.2012 16:52:54
Nonii täna panime siis meie oma väikse Eestimaaga suurest maast nimega Mehhiko mööda: http://boincstats.com/stats/boinc_country_stats.php?pr=bo&st=0#37
Järgmine suur maa millest me väiksed ja väetid Eestlased mööda paneme on Türgi
Edu lammutajatele
Edit: pg-s hakkab cpu challenge ~20 tunni pärast: http://www.primegrid.com/
Cpu only võtan osa ikka.
Edit: pg run läbi ja jäin esimese 300-saja sekka Sinna ma ka sihtisin. Tarmo Ilves jäi samuti esimese 300-saja sekka Kõrgema koha sai krt:
http://www.primegrid.com/challenge/2012_1/top_users.html
Täna õhta saan siis poemi proovida.
Edit: milkywaylt uudist:
tsitaat: |
A few weeks ago, we ran double credits in order to make up for a database error that occurred earlier in 2011. Unfortunately, the server crashed with just 12 hours left until the make-up credits were finished. Now that the new server is up and running (and stable! very stable!), and everyone here is back from travels and winter break, we are ready to finish running those last 12 hours of double make-up credits. If there are no significant objections, we'll run the double credits on St. Valentine's Day (February 14), from 10:00 am until 10:00 pm, US Eastern time (EST). This corresponds to 3pm (Feb14)-3am (Feb15) UTC. Happy crunching!
tsitaat: |
The old CAL version is gone; it's replaced with the OpenCL application. On AMD/ATI GPUs (older than 79xx) it is using some hackery to use the same IL kernel as before so it should be as fast. However this also means the Radeon 38xx cards aren't supported with new stuff. - Radeon 79xx stuff should work - The occasional validate errors from empty / truncated stderr should stop - AVX will be used if available on Linux and Windows (64 bit only for Windows) - I've increased the default GPU target frequency so GPU stuff should make things less laggy on average. You can now also configure this with the web preferences now so you don't need to use app_info stuff if you want to play with that. - Partial workaround with high CPU usage with recent Nvidia drivers. It should cut down on the CPU usage a bit while not sacrificing too much. There are options to change the polling mode if you want to lower the CPU usage further while not slowing it down. (--gpu-wait-factor and --gpu-polling-mode work similarly to how they did with the old CAL one, but slightly different)
viimati muutis sant 09.02.2012 02:51:48, muudetud 1 kord |
60 |
Sahib
08.02.2012 19:10:40
Mina aga langesin koha võrra Ega ühe kaardiga teile vastu või vähemalt tempot hoida ei saa.
Hea uudis on see, et DistrRTgen elustus.
Generalized Fermat Prime Search (GFN) on keegi jooksutanud? Poob kaarti hirmsasti, aga temp on madal
Saan uhke märgi rinda ja siis pensionile - ehk keegi mäletab veel seda
55 |
sant
13.02.2012 15:29:43
tsitaat: |
Ei, ja ei jooksutagi kuna skoor vilets.
Sahib,
tsitaat: |
Saad küll Tarmo Ilves ja Margus, neil mõlemil üks kaart mis samaväärne sinu omaga. No mina ja Aants paneme hunniku gpude pealt, aga see on ka kõik. Sa oled ju ikkagi eesti tipptegijate hulgas
Kui oled väsind pane pausi Ja hiljem lase edasi. Sa ei pea ju 24\7 laskma. Mul endal üks kast 24\7 ei lase praegu, lasen tal puhata, teisega lasen 24\7 edasi. Muidu oleks mill+ päevas koguaeg. Kui sa vaadand oled siis ka Aants paneb pikalt pausi vahel, ja kogu rauaga ta 24\7 ei lase niikuinii.
Edit: päris huvitiva scooriga wu-si saab distrtgen-ist vahel - runtime 431.39 sec ja scoor 8,665.00
60 |
Sahib
13.02.2012 19:32:08
Üldiselt on neid seinast seina, aga väga palju ei kõigu.
Ühel päeval tuleb 7,470.00 (run time jääb alla 1000de) ja siis teine päev otsa 8,665.00.
55 |
XeStAiSy
17.02.2012 08:56:46
MW Ati opencl app küpsetab 51-52 sekiga 100% wu valmis ja siis uimab kuni 57-58 aja välja. Hetkel ei prae GPUd ka nii hullult kui oli CAL. Ei kooma ka nagu ei oleks midagi toimumas. Parem surfamine netis kui seda oli Moo.
10 |
sant
04.03.2012 22:03:21
Poolel teel: http://boincstats.com/stats/boinc_user_stats.php?pr=bo&st=0&co=30#1
Sain täna 500.000.000 punni täis boinc totalis
Edit: einsteinis leiti jälle pulsareid: http://einstein.phys.uwm.edu/forum_thread.php?id=9317
Krt, mingeid asju uuendasin 23-ndal ja nüüd pooled gpu wu-d teevad erroreid ja invalid wu-si Hui mäletan mida uuendasin, polegi ammu juhtund midagi sellist, uus win vaja jälle peale panna
Edit:
Margus, Poem@home vajab beeta boinci ja sellega osad projectid ei tööta korralikult. Ootan siiski final releasi ära enne kui saan proovida, Poem on peal muidu aga gpu wu-si ei saada sunnik, saab aru et pole beeta boinc
Milkyway run tuleb, kel dp toega ati võtku osa (eriti sina Margus pole ammu üheski runnis näinud sind), mul MW certified rauda pole seega pass. Pg-s cw gpu runnis jäin 27-ndaks asi seegi http://www.primegrid.com/challenge/2012_2/top_users.html
tsitaat: |
Name The March Milky Way
Project MilkyWay@home
Issued by Crystal Dream
Start time 2012-03-09 00:00 GMT
End time 2012-03-16 00:00 GMT
60 |
XeStAiSy
08.03.2012 14:48:22
Ma teen need mõned pävad kuid olukord on sucks. 12 tundi veel ja läheb lahti. CPU omadest ei võta osa jah. Ma ei jõua igale poole korraga. Ilmselt venis aeg pikkaks.
10 |
sant
05.04.2012 21:34:10
Margus kirjutas: |
Ma teen need mõned pävad kuid olukord on sucks. 12 tundi veel ja läheb lahti. CPU omadest ei võta osa jah. Ma ei jõua igale poole korraga. Ilmselt venis aeg pikkaks. |
Cpu omad ongi sucks Ma ise ka igast challengest osa ei võta Mw challengest pole ühestki osa võtnud kuna pole rauda. Ma mõtsingi et sa võtaks minu eest nagu osa Su kaart teeb wu mingi 55 sec, mul gtx 570 teeb mingi 9 minti wu ja gts 450 teeb umbes pool tundi pole nagu pointi lolli mängida mul. Cpu pealt ei lase keegi gpu runni niikuinii
Edit:
MW run läbi. ja Margus, sai koha 36 Nagu Moon* ütles:
tsitaat: |
...or Estonia wouldnt been represented in this challenge - and that
would be a shame, or course.. International is supposed to mean International. So hurray for Margus! (and all the rest of us)
http://www.arizonamoon.eu/cs/Milkyway-09-03-2012-TM.html
Moo! run tulemas:
tsitaat: |
Name: The March Titans Moo! Wrapper
Project: Moo! Wrapper
Issued by TitanesDC
Start time: 2012-03-19 00:00 GMT
End time: 2012-03-26 00:00 GMT
Edit: Eesti on seljatand vahepeal sellise suure riigi nagu Türgi: http://boincstats.com/stats/boinc_country_stats.php?pr=bo&st=0#36
Edit: Pg run tuleb, cpu only: http://www.primegrid.com/forum_thread.php?id=4191#51745
tsitaat: |
Marie-Sophie Germain Challenge:
Start: 1 April 2012 18:00 UTC
End 3 April 2012 18:00 UTC.
Length: 2 day (48 hours)
Subproject: Sophie Germain Prime Search (LLR)
Edit: run käib juba
Tsitaat Mankkalt:
tsitaat: |
can't afford any more 1500 euros monthly electrical bills, so cutting down here, 9 GPU's & around 30 CPU's will still be running, but count me out for the next challenges, not stopping, but taking it easy for a while.
Tsiteerides teisalt:
tsitaat: |
With great power, comes great electric bill.
Eks ta ole nii
Edit: run läbi, jäin kohale 204 Krt tahtsin esimese 200-ja sisse saada http://www.primegrid.com/challenge/2012_3/top_users.html
Edit: lõpuks ometi sain ati mälu kiirused alla lasta (thanks to Rob*):
tsitaat: |
To ease up on the temps and power use I have also downclocked the memory speed of my card through Catalyst. Here's how:
Exit Boinc.
Go into Catalyst and make a preset for the speeds you want to use. I called mine 900-300 (GPU speed 900MHz/Memory speed 300MHz).
Close Catalyst.
You need to find and edit the profile for this preset file. Catalyst put it here: c:/users/computername/appdata/local/ATI/ACE/profiles/900-300.
If you cant find it, check your folder options - show hidden files etc... windows has to show everything.
There you will see an xml file with the file name you named it in the Catalyst. You will edit this file in Notepad.
Approximately midway down this file you will see a section that looks something like this:
(First gpu (gpu 0) or only gpu: )
<Feature name="MemoryClockTarget_0">
<Property name="Want_0" value="50000" />
<Property name="Want_1" value="90000" />
<Property name="Want_2" value="90000" />
(Second gpu (gpu1): )
<Feature name="MemoryClockTarget_1">
and so one...
Change each of the values to 30000 where the first three digits is the new lower memory speed you want. Save the file and exit.
Open Catalyst again and go to Presets.
Click on the name of the preset file you created.
Now go to Overdrive. You will see the new lower memory limit displayed to the left of the Memory Speed slider. Move the slider to the new lower speed.
Click the name of the preset file name again to set the new speed.
Restart Boinc.
I give full credit to Zydor from the MW forum for his patient assistance in getting this to work.
Distrtgen testib ati beta appi:
tsitaat: |
Here are the time / wus for AMD ATI and NVIDIA DistrRTgen.
HD 7970 = 10 minutes
HD 6990 = 35 minutes (2 WUS)
HD 5770 = 1 hour and 35 minutes
GTX 590 = 23 minutes (2 WUS)
GTX 580 = 19 minutes
GTX 295 = 60 minutes (2WUS)
Lisaks:
tsitaat: |
Times are estimates...
HD 7970 = 10 min
HD 7950 = 16 min
HD 6990 = 35 min
HD 6950 = 40 min
HD 5870 = 51 min
HD 5830 = 85 min
HD 5770 = 95 min
GTX 680 = 17 min
GTX 590 = 23 min
GTX 580 = 19 min
GTX 570 = 24 min
GTX 560 TI = 35 min
GTX 560 = 44 min
GTX 460 = 51 min
GTS 450 = 73 min
GTX 295 = 60 min
GTX 275 = 77 min
Not bad ise veel ei käpi seda samal põhjusel nagu Poem beeta gpu appi - vajab boinc beetat ma ei viitsi beetadega jamada.
Edit: lisasin põhikastile mälu juurde pärast poolteist aastat mõtlemist http://www.upload.ee/image/2229537/nfs_at_home.jpeg
Nüüd saab nfs @home normaalselt jooksutada Kuigi põhieesmärk on siiski neuronat proovida, sel 1 wu per 1cpu core võtab kuni 6giga rammi. Sisse saab invitationiga, ma mingi koodi sain aga servu on praegu maas kahjuks. Eks ta üks eliidi project ole
Edit Distrtgen run tuleb paari päeva pärast:
tsitaat: |
Rainbow Resurrection: 2012-04-07 16:00:00 GMT - 2012-04-10 16:00:00 GMT
This 72 hour challenge will feature Primegrid style user and team statistics and only work handed out after the start time and returned before the completion time will be counted. In addition all WUs that are part of the challenge will receive 1.25x the credit that is received ordinarily.
The reason for this challenge is two fold:
1) The new hardware has been performing excellently and is averaging less than 20% utilization
2) An ATI/OpenCL app version is in early alpha stages and this challenge will be helpful in seeing if we can handle full 24/7 CPU+GPU where ATI will be added in the future.
60 |
