praegune kellaaeg 09.06.2024 17:10:32
sõnum |
MitchriX
15.11.2009 20:19:45
mikk36 kirjutas: |
Sellist ühendust kasutati koos 3.5mm auguga välise puldi jaoks osadel pleieritel, tõenäoliselt sama sellega. |
Yup, hindamatu väärtusega vidin on see pult - ise ei kujutaks X5'e ettegi ilma selleta
Kommentaarid: 34 loe/lisa |
26 |
vull
16.03.2010 03:11:31
krt, jetaudio bbe efekt ruulib
tsitaat: |
BBE is designed to add clarity and more pronounced highs, which is claimed to produce no audible processing side-effects. It also increases the prominence of vocals relative to amplified instruments. |
tsitaat: |
BBE addresses the issue that the inductance of all speakers cause the high frequencies to be delayed more than the low ones. This is part of the "transient response" issue that is often talked about and little explained. BBE makes some correction by delaying the low frequencies to compensate. It's use is big in pro audio (public address systems). It can be implemented as a digital process or as an analog circuit. |
Kommentaarid: 46 loe/lisa |
43 |
lisa lemmikuks |
