uus teema   vasta Hinnavaatlus »  Sülearvutid »  Mida teha kui Vistaga sülearvutile ei saa XP-d installida... [LAHENDUS] märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... , 11, 12, 13  järgmine
mazdagti
mazdagti
sõnum 13.10.2009 13:46:11 vasta tsitaadiga
Tere. Arvutiks on HP DV6315e ja mina olin muidugi nii tark et installisin kohe nii XP peale et Vista kustus lootes et Recovery säilib aga ei säilinud. Seega installisin peale, leidsin HP lehelt mõned draiverid ning olen nüüd proovinud puuduvaid mitmest kohast alla laadides arvutil käima saada aga mitte ükski pole õnnestunud. Senine seis on järgnev:
Summary
Computer:
Computer Type ACPI Multiprocessor PC (Mobile)
Operating System Microsoft Windows XP Professional
OS Service Pack Service Pack 2
Internet Explorer 6.0.2900.2180 (IE 6.0 SP2)
DirectX 4.09.00.0904 (DirectX 9.0c)
Computer Name REGINAS-800518B (Minu)
User Name ReginaS
Logon Domain REGINAS-800518B
Date / Time 2009-10-13 / 12:14
Motherboard:
CPU Type Mobile DualCore AMD Turion 64 X2 TL-50, 1600 MHz (8 x 200)
Motherboard Name Hewlett-Packard HP Pavilion dv6000 (GF656EA#ABB)
Motherboard Chipset nVIDIA GeForce Go 6150, AMD Hammer
System Memory 960 MB (DDR2-667 DDR2 SDRAM)
BIOS Type Phoenix (12/27/07)
Display:
Video Adapter nVIDIA GeForce Go 6150
3D Accelerator nVIDIA GeForce Go 6150
Multimedia:
Audio Adapter Conexant Cx20549 @ nVIDIA nForce 430 (MCP51) - High Definition Audio Controller
Storage:
IDE Controller Standard Dual Channel PCI IDE Controller
Disk Drive SigmaTel MSCN USB Device (941 MB, USB)
Disk Drive ST9120821AS (120 GB, 5400 RPM, SATA)
Optical Drive TSSTcorp CD/DVDW TS-L632M
SMART Hard Disks Status OK
Partitions:
C: (NTFS) 5624 MB (1292 MB free)
D: (NTFS) 57341 MB (54424 MB free)
Total Size 61.5 GB (54.4 GB free)
Input:
Keyboard HID Keyboard Device
Keyboard Standard 101/102-Key or Microsoft Natural PS/2 Keyboard with HP QLB
Mouse Synaptics PS/2 Port TouchPad
Network:
Primary IP Address 127.0.0.1
Primary MAC Address 00-1A-73-38-5C-3C
Network Adapter Broadcom 802.11g Võrguadapter
Peripherals:
FireWire Controller Ricoh RL5C832 IEEE1394 Controller (PHY: Ricoh RL5C832)
USB1 Controller nVIDIA nForce 430 (MCP51) - OHCI USB 1.1 Controller
USB2 Controller nVIDIA nForce 430 (MCP51) - EHCI USB 2.0 Controller
USB Device USB Composite Device
USB Device USB Mass Storage Device
USB Device USB Video Device
Battery Microsoft AC Adapter
Battery Microsoft ACPI-Compliant Control Method Battery
DMI:
DMI BIOS Vendor Hewlett-Packard
DMI BIOS Version F.3E
DMI System Manufacturer Hewlett-Packard
DMI System Product HP Pavilion dv6000 (GF656EA#ABB)
DMI System Version Rev 1
DMI System Serial Number CNF7123JSY
DMI System UUID 434E4637-3132334A-5359001E-683653FE
DMI Motherboard Manufacturer Quanta
DMI Motherboard Product 30B7
DMI Motherboard Version 65.2B
DMI Motherboard Serial Number None
DMI Chassis Manufacturer Quanta
DMI Chassis Version N/A
DMI Chassis Serial Number None
DMI Chassis Asset Tag
DMI Chassis Type Notebook
Jätkan seni katsetamist, ehk ei saa EMT 3GB ennem täis, muidu kiirus 25kb icon_biggrin.gif
No ikka täitsa kagu nukas!
sõnum 13.10.2009 13:57:33 vasta tsitaadiga
vaja on siis lõpetan selle installi sul ära.
otsi nvidia lehelt kiibile draiverid, kaardilugeja on ilmselt rikoch. saund peaks olema realtek.
Ketas, ketta, ketast, kettasse, kettas, kettast, kettale, kettal, kettalt, kettaks, kettani, kettana, kettata, kettaga. <--SPIKKER! https://www.yaga.ee/mox-fulder
https://www.facebook.com/marketplace/profile/100087345405856/ värskeim loetelu.
siLc
sõnum 13.10.2009 14:01:03 vasta tsitaadiga
XP SP2? Kui jah, siis helile jõuad nõksu lähemale kui installid SP3-e. Base System Device`d on RICOH mälukaartilugeja.
sõnum 13.10.2009 14:20:14 vasta tsitaadiga
mazdagti,
uusim chipseti/video draiver: http://www.nvidia.com/object/nforce_winxp_15.45.html
mazdagti
mazdagti
sõnum 13.10.2009 14:41:41 vasta tsitaadiga
Heh seda juba tiringi, nüüd vaja veel card reader ja audio tarvis soft leida thumbs_up.gif
sõnum 13.10.2009 14:49:31 vasta tsitaadiga
ricoh i reader on siit läbi käinud.
mazdagti
mazdagti
sõnum 13.10.2009 18:45:59 vasta tsitaadiga
Hetkel siis video toimib õige resoga, toimub audio ja kaardilugeja softi transportimine mälupulgale ning siis hakkab installimine. Eks näis mis välja valitud softiga teha annab.
Kui õieti aru saan siis see PCI jubin ongi audio icon_question.gif icon_rolleyes.gif igatahes selle leidmine tundub olevat kõige raskem, katsetatud juba u. 10 erinevat ja tulemus endiselt vaid kiljuv piiks kõlaritest icon_evil.gif tegu siis Conexant cx20549 piibistikuga ning ka 11-s ei andnud tulemust bullshit
Probleemiks veel "Modem Device on High Definition Audio Bus". Mis see on ja kuidas saada sellele driverid?
Edit: Need sobivad draivud leidsin Conexant enda kodulehelt ja toimisid. Seega minul nüüd asi nullist tööle saadud icon_cool.gif
Aga kui on uuesti vaja siis enam taas vist ei oska kuna esimese otsa soft juba kustutatud icon_lol.gif
siLc
sõnum 13.10.2009 18:56:19 vasta tsitaadiga
On sul iidset 56k telefonimodemit üldse vaja? Ei usu - pane seade "Disabled" ja asi klaar.
mazdagti
mazdagti
sõnum 13.10.2009 19:26:09 vasta tsitaadiga
Lihtsalt häiris see kollane hüüumärgike aga nüüd pole enam ühtegi kuskil thumbs_up.gif
sõnum 13.10.2009 22:22:10 vasta tsitaadiga
siLc, muu " euroopa" veel väga palju laseb modemi peal. mazdagti, võta nüüd minipe ja vaata , kas sa saad sellega ghosti teha.
tarx1000
tarx1000
sõnum 14.10.2009 06:45:31 vasta tsitaadiga
Ja nüüd tee Driver Genius nimelise progega Driver Backup (AutoInstaller), et järgmine format muretult mööduks! icon_wink.gif
Mul kõigist tuttavate HP-dest see olemas. Teed lihtsalt formati, installid XP, käivitad selle auto installeri, ootad 15 minutit ja naerad! icon_lol.gif
asjameez
asjameez
sõnum 01.05.2010 13:17:00 vasta tsitaadiga
Arvuti on Compaq nx9420 läptop ja peale on installitud Windows XP Pro SP3.
Et saaks üldse installida, siis BIOSist lülitasin SATA välja.
Nüüd tundub, et kõvaketas on peale värsket installi hirmus aeglane, aga SATA režiimi ei saa sisse tagasi lülitada, kuna XP viskab sinist siis. Eelmise installiga oli SATA režiim sees.
Kõik draiverid sain siit: LINK
SATA driver küsib mingit floppyt, aga läpparil pole ju flopit icon_confused.gif
Kust kohast saab juba peale installitud Windowsile SATA draiveri, et BIOSist saaks SATA sisse lülitada ja masin ka üles tuleks?
Laptop on Designed for Windows XP.
viimati muutis asjameez 01.05.2010 13:17:57, muudetud 1 kord
tarx1000
tarx1000
sõnum 01.05.2010 13:48:37 vasta tsitaadiga
Otsid vist seda: link
Kuidas toimida: http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
kuigi lihtsam oleks suvaline xp reliis tirida, millel juba sata klge poogitud
asjameez
asjameez
sõnum 01.05.2010 14:55:35 vasta tsitaadiga
Installisin selle peale nagu üks õpetus käskis täpselt sama mudeliga ja enam ei tule Windows üle ei SATAga ega ilma.
Selline asi peaks out-of-the-box töötama tänase päeva seisuga uuendustega icon_evil.gif
sõnum 26.07.2010 11:53:16 vasta tsitaadiga
kaevan vana teema üles.
olukord on selline, et on 1 kloon, kuhu on installitud ports jura, mida uuesti installida ei viitsi aga masinas, millega kloon tehti, sai biosist ahci ideks ümber lülitada, uute masinate insydeH2= f.01 aga seda võimalust ei paku isegi mitte mingi utiliidiga. uus masin tahaks saada intli 9nda või 10nda põlvkonna ihc draiverit, mida selles kloonis aga pole. kloon sellest tyulenevalt sureb sninsega buutimisel, tahaks midagi kuskile kopeerida, et klooni sisse need draiverid saaks aga ei tea kuhu ja mida, st mida teeb win installi käigus sellel ajal , kui kopeeritakse ahci driaver...
wiilweer
wiilweer
sõnum 25.08.2010 16:35:28 vasta tsitaadiga
Läks poolteist tundi aega ning suutsin enda DV4-1030en'ile ajada selga absoluutselt kõik mis võimalik. Töötab nii vaimselt kui ka füüsiliselt. thumbs_up.gif
Mais
Mais
sõnum 06.11.2010 18:37:41 vasta tsitaadiga
Selline mure, et installin Inteli AHCI/SATA draiverid aga kui lähen (C:\Intel\) siis seal ainult log failid vms.
milles probleem?
Edit:
SAin asja korda
Viktor
sõnum 21.11.2010 00:54:29 Samsung nf210 xp driverid,ja xp peale saamine vasta tsitaadiga
tere!
probleem selline ostsin Samsung nf210, aga tahaks talle Xp-dpeale panna, drivereid ei leia, äkki saate kuidagi avitada
ette tänades-Arsen
Siemens556
sõnum 06.12.2010 00:10:56 vasta tsitaadiga
Sai kunagi HP pavilion dv 6500 seeria masinale vista asemele xp installima hakatud.Algul ei saanud tööle ja driverid jooksma xpl .
Asja lahendus oli suht lihtne
Recovery partinsioon kustutatud, xp installitud, kõik driverid oma järjekorras, järjekord kõige tähtsam.Juhendi sain HP supporti lehelt aga ei nvida ega muu amd driverid ei sobinud.
Fooruminurgast sain moderated driverid, seal oli terve pack olemas.
Osa oli Igor Pavlovi nimelise selli looming ja keegi hr.xp oli veel siis lisanud packi moderated driverid.
Hiljem tegin drivermaxiga backupid ja algsed driverid on ka kuskil täitsa olemas.
Samas, arvutitest ei tea suurt midagi aga tehtud ma sain asja ja toimib siiani.
See sata ja nlite teema ei vii mitte kuskile, hiljem ei saa seda ja toda tööle ja tõrked.
Igatahes selle moderated driver packiga töötab arvuti kenasti ja enam nii kuumaks ka ei lähe:)
ik2
sõnum 15.10.2011 00:50:53 vasta tsitaadiga
ei saa lahti pakkida selle käsuga IATA89ENU.exe -a -p C:\Intel\ saadab pikalt
allsight
allsight
sõnum 05.04.2012 16:19:32 vasta tsitaadiga
Plumbum
sõnum 05.04.2012 16:52:02 vasta tsitaadiga
Kui Windows on installitud IDE mode'is ja vaja hiljem SATA peale ümber minna siis aitab selline asi:
Start-Run-regedit.exe, ava võti HKEY_LOCAL_MACHINE/System/CurrentControlSet/Services/Msahci
seal on selline võti nagu Start, paremklikk ja Modify
Väärtuseks pane 0
Seejärel restart ja BIOS'is pane AHCI mode peale ja peaks installima AHCI driverid ja töötama, no more BSOD.
Ja üleüldse oleks tark tegu võtta oma XP installikas ja lisada sinna SATA driverid. jääb see F6 ja muu jama ära.
kakukeo
sõnum 06.12.2013 00:20:11 Re: Samsung nf210 xp driverid,ja xp peale saamine vasta tsitaadiga
arsen kirjutas:
tere!
ette tänades-Arsen
http://www.odrivers.com/2012/06/samsung-nf210-drivers-windows-xp.html
sabs
sabs
sõnum 09.02.2014 22:24:31 vasta tsitaadiga
Tere!
Arvutiks Dell Studio 1557
Intel I7
8GB ram
Win 7 ulitmate
Soovin kõrvale installida win xp sp3, kuid viskab ette errori peale laadimist.
Olen vahetanud ACHI ATA vastu biosis, kuid tulemus on sama.
Soov oleks, et arvutis oleks nii WIN 7 kui ka XP.
Oskab keegi lahendust pakkuda?
K3ndu
K3ndu
sõnum 09.02.2014 22:26:27 vasta tsitaadiga
WIndows 7 ju miski XP mode tugi ka, tõmbad Microsofti kodukalt alla ja jookseb sul eraldi aknas.
uus teema   vasta Hinnavaatlus »  Sülearvutid »  Mida teha kui Vistaga sülearvutile ei saa XP-d installida... [LAHENDUS] mine lehele eelmine  1, 2, 3 ... , 11, 12, 13  järgmine
