uus teema   vasta Ärifoorumid »  Varia ja muu tehnika (sh helitehnika) ost/müük/vahetus »  » M: Kiirmüük!! Autel Robotic EVO II Pro 6K (2 akut+laadija, 256GB SD, kohver, pult) :: Asukoht: Tallinn märgi kõik teemad loetuks
Slaava007
Slaava007
sõnum 24.04.2024 00:13:40 » M: Kiirmüük!! Autel Robotic EVO II Pro 6K (2 akut+laadija, 256GB SD, kohver, pult) :: Asukoht: Tallinn vasta tsitaadiga
Link
*'Kaasa tuleb:
Laadija koos kahe akuga, pult koos kaablitega (MicroUSB, USB-c), 256GB V30 SD-kaart, mõned lisapropellerid, ND-filtrite komplekt ja kohver.
Puudused:
- gimbali transpordi kaitseplastik kadus ära, kuid saab muretult ja turvaliselt transportida ilma selleta.
- mõned täkke, kriimud korpusel.
AH: 650€
Lisainfo inglise keeles:
The Autel Robotics EVO II PRO has a 1-inch CMOS sensor with a 28mm lens. 6K resolution, adjustable aperature of f/2.8 – f/11. HDR and intuitive camera controls. Lossless in-camera zoom up to 4x magnification. Max image size is 5472 x 3648. Supports (10-bit) 5.5K-60fps, 4K-60fps, 4K-120fps, 2.7-120fps and FHD-120fps. This is a perfect drone for mapping or cinematography.
The drone has a 9-km (5.59 mile range) and 360° collision avoidance. 12 computer vision sensors controlled by a Dual-Core Processor and AI Machine learning makes possible omni-directional protection. Begin detecting potential hazards up to 30 meters away and let the EVO II accurately control the speed of the drone to avoid a collision. Optionally disable obstacle avoidance and use the radar feature to still provide alerts while maintaining full control of the aircraft! This drone has been tested and is capable of flying in Level-8 wind conditions (46mph)!
Using the same 12 computer vision sensors, the EVO II can navigate itself in all directions while avoiding obstacles!
The EVO II Series features the longest battery life of any foldable drone (up to 40-minutes of flight time). With a top speed of 45mph and up to 9km (5.59 mile) video transmission range, you can now go further and faster. EVO II presents an all new sensor and storage package and omnibus-directional obstacle avoidance.
EVO II comes standard with a 7100mAh rechargeable battery. Providing up to 40-min of flight time in forward motion and 35-min at a hover. Patented "battlock system" guards against battery ejection during high-speed maneuvers or hard landings.
No Geo-Fencing in No Fly-Zones
EVO II Pro still not programmed in no fly zones (NFZ). Autel leaves that responsibility to the pilot to be aware of any rules and regulations in the area so Please fly legally!
12* Omni-Directional Obstacle Avoidance Sensors
The EVOII's frone, rear, left, right, top and bottom binocular vision sensing systems use image data to calculate the distance between the aircraft and potential obstacles. The system will halt the aircraft's forward progress when an obstacle is detected.
The front, rear and bottom binocular vision systems also feature the Starpoint Positioning System. This system uses ultrasonic sensors to calculate the current height of the aircraft and uses binocular cameras to obtain location information via image analysis. icon_cool.gif
Baltikumi parim sõidusimulaator
Www.virtuaalreaalsus.ee
viimati muutis Slaava007 24.04.2024 11:57:27, muudetud 1 kord
Kommentaarid: 731 loe/lisa Kasutajad arvavad:  :: 4 :: 3 :: 635
rmz
sõnum 24.04.2024 07:50:20 vasta tsitaadiga
AH.
Kommentaarid: 77 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 69
Slaava007
Slaava007
sõnum 25.04.2024 16:50:49 vasta tsitaadiga
rmz kirjutas:
AH.
Ei no muidugi alusta icon_biggrin.gif Eesti oma Jackass ootab tegemist
xtr
xtr
sõnum 26.04.2024 10:06:47 vasta tsitaadiga
V2?
M: Apple Magic Keyboard with Numeric Keypad (SWE) ja Magic Trackpad 2
M: Tasakaaluliikur
M: Ryzen 2600/B450M/16GB/1TB/GTX1080/650W
Kommentaarid: 295 loe/lisa Kasutajad arvavad:  :: 2 :: 2 :: 247
Slaava007
Slaava007
sõnum 03.05.2024 16:24:07 vasta tsitaadiga
xtr kirjutas:
V2?
jah
Droon oli mul näiteks abiks selle hobivideo loomisel:
https://vimeo.com/681137724
UPDATE:
Panen homme (03.05) lukku kell 13:00. Läheb parimale pakkujale või OK pakkujale kohe.
OK: 788€
