sõnum ![Teata moderaatorile Teata moderaatorile](./images/icon_move_w.gif) |
![Tomorrow Tomorrow](https://foorum.hinnavaatlus.ee/files/me3_667.jpg)
15.03.2024 16:27:29
pwn13 kirjutas: |
Ma panin ühe programmi läbi shell:startup -i automaatselt käivituma. Mingihetk enam polnud seda tarvis, kustutasin otsetee sealt kaustast ära aga ikkagi käivitub. mis variante veel oleks sellest lahti saada? |
HKCU\Software\Microsoft\Windows\CurrentVersion\Run
HKLM\Software\Microsoft\Windows\CurrentVersion\Run
HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run |
ChatGPT vastus kah:
tsitaat: |
In Windows, program startup entries can be found in several locations within the Windows Registry. Here are the main ones:
1. **HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run**: Programs listed here will run automatically when a specific user logs into Windows.
2. **HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run**: Programs listed here will run automatically when any user logs into Windows.
3. **HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\RunOnce**: Programs listed here will run automatically once when a specific user logs into Windows.
4. **HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunOnce**: Programs listed here will run automatically once when any user logs into Windows.
5. **HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\RunOnceEx**: Similar to RunOnce, but allows for more complex operations.
6. **HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\Userinit**: Specifies what programs are run by Winlogon when a user logs in.
7. **Startup folders**: Startup entries can also be added by placing shortcuts to programs or scripts in the Startup folders. These folders are located at:
- **%APPDATA%\Microsoft\Windows\Start Menu\Programs\Startup** (for current user)
- **%ALLUSERSPROFILE%\Microsoft\Windows\Start Menu\Programs\Startup** (for all users)
Each of these registry locations controls different aspects of program startup, such as whether they start for all users or just the current user, and whether they run every time the system boots or only once. It's important to be cautious when modifying these entries, as changing the wrong values can potentially disrupt system stability or cause unwanted behavior. |
![](templates/HinnaVaatlus/imagesHV/spacer.gif) |
pwn13
![pwn13 pwn13](https://foorum.hinnavaatlus.ee/images/avatars/upload/2113b2a261414cb55dd56a18f312554f.jpg)
15.03.2024 21:38:26
see ülemine variant lahendust ei toonud, homme vaatan alumisi. Aga tänud vastamast.
_________________ pWn |
raul141
![raul141 raul141](https://foorum.hinnavaatlus.ee/images/avatars/upload/cae25138fdeeb8d862d2fb8ac20f9ead.gif)
18.03.2024 18:11:17
23H2 uuendust keegi julgeb kommenteerida. Olen ka nüüd w11 ohver , iga sookolli ka ei julge koju laastama.
_________________ dell somm ding mi poi |
![laurx laurx](https://foorum.hinnavaatlus.ee/images/avatars/upload/ca79a0feec3dca855e409664ca0392c7.JPG)
18.03.2024 18:22:52
pole ükski masin katki läinud. samas ma pole nn ise kasutanud.
_________________ Ketas, ketta, ketast, kettasse, kettas, kettast, kettale, kettal, kettalt, kettaks, kettani, kettana, kettata, kettaga. <--SPIKKER! https://www.yaga.ee/mox-fulder
https://www.facebook.com/marketplace/profile/100087345405856/ värskeim loetelu. |
18.03.2024 18:32:47
raul141, Seni on olnud probleemivaba minu jaoks. Copilot mis lisati selle uuendusega saab kergelt kinni keerata.
raul141
18.03.2024 18:49:47
laurx, six - pack mulle ka väga nagu meeltmööda, mis selle kõrvalmõjud`?Arvata jöudlus, nagu lugenud, mingi huinjaa, te osalete teatud rakenduste allalaadimistes, kes sellest ju ärilist kasu saavad. Ise aru saamata, miks see teil arvutis olemas on? Kui kahjulik ei ole siis keegi saab kasu? Võibolla olen mina lollakas? Võibolla isegi rahapesu?
pwn13
18.03.2024 19:03:24
raul141 kirjutas: |
23H2 uuendust keegi julgeb kommenteerida. Olen ka nüüd w11 ohver , iga sookolli ka ei julge koju laastama. |
mul kaks erinevat 23H2 uuendust peal ja töötab. Vana z97 plate.
raul141
18.03.2024 19:16:27
pwn13, ikka töötab, aga miks ja kuidas ja miks sul seda vaja kui ei ole vaja? See ei koorma su arvutit ja su aju, sest sa võibollla ei sa saa aru, miks sind selles ära kasutakse? Või siis potentsiaalset klienti, kes selle "elemendi" ära ostab.
pwn13
18.03.2024 19:18:14
ma ei tea mida see uuendus tegi, aga copilotit vms pole märganud.
raul141
18.03.2024 19:42:35
pwn13, Räägi, mis ta sinuga eesti keeles tegi see w11. Vaimne trauma küll, aga mis see copilotit sinuga tegi? Loodan, et füüsilisi traumasi pole, ühesõnaga tekst ei ole tõlgit
Vabandust, teksti vale kasutuse pärast! Võibolla eesti keeles pole vanainimestele veel mõeldud, proovime integrreeruda "uude maailma"
18.03.2024 20:58:30
raul141 kirjutas: |
laurx, six - pack mulle ka väga nagu meeltmööda, mis selle kõrvalmõjud`?Arvata jöudlus, nagu lugenud, mingi huinjaa, te osalete teatud rakenduste allalaadimistes, kes sellest ju ärilist kasu saavad. Ise aru saamata, miks see teil arvutis olemas on? Kui kahjulik ei ole siis keegi saab kasu? Võibolla olen mina lollakas? Võibolla isegi rahapesu? |
Repeat that with subs..
Mis kasu, mis asi..? Ma teen puhta masina, lasen wu "lõpuni", teen resa ja hiljem annan lõpp kasutajale.. 23H2 tuleb ka peale..
![SKG SKG](https://foorum.hinnavaatlus.ee/images/avatars/upload/db1ec2c4826213c2ec506b8bfbbd5419.gif)
21.03.2024 04:25:53
Miks on vaja Windows 11 installi jooksul sama asja mitu korda küsida? Et äkki muutsin installiprotsessi jooksul regiooni ja klaviatuuri layouti?
Spoiler ![Spoiler](/images/exclamation.gif)
Ostsin uue AMD laptopi ja ikka veel vaja "peitust mängida". Windows Update soovib uusima AMD videodraiveri mingi igivana versiooniga üle kirjutada, peale mida Catalyst kontrollpaneel enam ei toimi. Hea, et see äpp veel töötab ja saab tülikaid uuendusi peita Microsoft võiks aga õppida, et kui uuem draiveriversioon on juba ees, siis vanemat jõuga selga ei lasta. Mis sa mulle sest 30.x versioonist tahad panna kui mul 31.x WHQL draiver juba peal johhaidii .
_________________ 17/1/2023, Scart: "Selle sajandi senise möödunud aja üks suuremaid skandaale on hetkel lahti rullumas..." |
Aeg maha 1p
![Sold OUT Sold OUT](https://foorum.hinnavaatlus.ee/images/avatars/upload/11d2f17ec9a26408c1e9535790e7f6bb.jpg)
21.03.2024 04:36:56
Kurat sul ikka juhtub pulli
_________________ People have been calling for a month and we've been sold out for a week or so.
21.03.2024 04:39:05
Pööran detailidele liialt tähelepanu ilmselt. Enamusel on ükskõik.
Aeg maha 1p
21.03.2024 04:42:54
Mul on tööandja läpakas. Ma teen vaid kaane lahti ja panen pärast kinni. Ei taha süveneda windows 11 enam. 10 oli juba selline kus ma pidin asju ja settinguid taga otsima
21.03.2024 05:11:20
SKG, Niipalju kui ma aru olen saanud, siis installiprotsess ei ole üks keskkond. WinPE (Preinstallation Environment) on see esimene mis on selle Vista/Win7/Win8 disaini hübriid ja teine on OOBE (Out Of Box Experience).
Eeldan siis, et need keele ja klaviatuuri sätted on seatud erinevatele protsessi osadele. Kuigi ma ei tea miks keegi peaks tahtma osa protsessist teha ühes keeles ja teise osas teises keeles.
OOBE ei toeta ka dark mode mis mind häirib kasvõi nt pimedas win paigaldades.
Tehniliselt autounattend.xml kasutades saab suure osa sellest protsessist automatiseerida aga see on kasulikum pigem siis kui paigaldus toimub kahe, kolme või neljakohalisele arvule masinatele millel on kas sama või väga sarnane raud ja kui midagi pole vaja muuta iga paigalduse juures.
Rufus aitab kah tavakasutajat.
Selles osas olen täiesti nõus, et MS saaks ja peaks kohendama paigaldusprotsessi, et kasutajate käest ei küsitaks järjest dubleerivaid küsimusi.
Väga palju paigaldusprotsessi jooksul küsitavast saaks tegelikult seadistada siis kui win desktop juba ees on ja puudub tegelikult vajadus protsessi pikendada iga väiksema mutrikese konfigureerimisega.
Lisaks MS pushib pidevalt oma MS kontot aga samas ei suuda sinna kontole sünkroniseerida paigalduse sätteid. See muudaks MS konto kasutamise vähemalt osaliselt kasulikuks kui sellega sisse logides paneks süsteem ise paika enamuse keele, regiooni jms sätetest.
![Betamax Betamax](https://foorum.hinnavaatlus.ee/images/avatars/upload/a99a252cf8cd42f48705f190ff41acde.jpg)
21.03.2024 08:59:29
Kui tihti sa pimedas Windowsit paigaldad? Lihtsalt huvi pärast küsin, kuna tõid selle eraldi välja.
Aeg maha 1p
21.03.2024 09:19:12
Sa julged valges teha seda?
Mnator
21.03.2024 09:31:27
Sold OUT kirjutas: |
Sa julged valges teha seda? |
keerab ukse lukku
21.03.2024 09:55:01
Asi on põhimõttes. OLED monitorid on järjest levinumad ja dark mode on süsteemiüleselt toetatud. Minul isiklikult on ka silmade teema. Valge taust on minu silmadele valus isegi tunduvalt vähendatud heledusega monitoril. Seda ka päevasel, mitte ainult öisel ajal.
MS suurusele firmale ei tohiks olla tegu suure arendusega võtta praegune OOBE disain ja teha dm ühilduv versioon sellest.
Aga mida ka mina tean. Olulisem on lisada uued emotikonid ja AI, AI ja veelkord AI /s
raul141
21.03.2024 10:20:38
Nii kui outlooki sisse logisin, võtab süsteemi admin nimeks outlook konto nime. Ilma midagi teavitamata. Proovin kuidagi kustutada, kogemused puised. Outlooki panin sätetest kinni.
siinus
![siinus siinus](https://foorum.hinnavaatlus.ee/images/avatars/upload/f277e16a82d23e5317ca19eaf7eeb15b.png)
21.03.2024 10:53:57
kas see uus notepad ongi nii halvaks tehtud, et jookseb triipkoodi lugemisel kinni? Nii 1D kui 2D koodi puhul sarnaselt. Lugeja on mingi wireless, usb dongliga.
Teistes programmides toimis laitmatult.
keylogger ei jõua piisavalt kiiresti datat ameerikasse saata?
_________________ suck less | ANNA MU SAI!
Mnator
21.03.2024 11:26:53
peasüüdlane selles tõenäoliselt see usb-dongle vahelüli
21.03.2024 11:39:45
Pole 11 peal juhtmevaba lugejat katsetanud veel, kuna hetkel kõik töömaal. Juhtmega variant siiani on laitmatult toiminud.
siinus
21.03.2024 11:39:56
Miks dongle on süüdi kui notepad on sitt?
