praegune kellaaeg 26.05.2024 00:34:00
sõnum |
amority
17.09.2022 10:08:39
LG WebOS/Samsung Tizen versus Go3/Viaplay |
Küsimus targematele: Kas LG OLED WebOSile või Samsung QLED SmartTV Tizenile saab peale panna Go3-e või Viaplay-d või peab selleks kasutama Chromecasti võimalusi?
The LG OLED runs LG’s WebOS smart TV system, which recently got a face-lift and is slightly easier on the eyes and simpler to navigate than it was just a year ago. However, I’ve found WebOS to feel increasingly cluttered the more I use it, and its implementation in the A1 OLED proved to be annoyingly sluggish. I often found myself frustrated with the amount of lag between my button presses and the corresponding action on the screen. The system is serviceable for watching Netflix, Hulu, Amazon Prime, and other apps, but I would highly recommend the addition of a Chromecast with Google TV, which will provide a big improvement in experience and responsiveness, though it will take up one of just three HDMI inputs.
Kommentaarid: 2 loe/lisa |
Anti112
17.09.2022 13:28:06
Viaplay peaks mõlemale olemas olema, LG-l on Go3 kindlasti olemas, Samsungi kohta ei tea.
Kommentaarid: 124 loe/lisa |
107 |
amority
17.09.2022 20:17:54
Tänud. Oli abiks. Täiesti töötab jep - WebOS.
lisa lemmikuks |
