uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia GeForce ForceWare Driverid märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... , 111, 112, 113  järgmine
sõnum 27.09.2020 22:57:48 vasta tsitaadiga
olafsand, http://download.msi.com/uti_exe/vga/MSIAfterburnerSetup463Beta2.zip
https://www.resetera.com/threads/guide-how-to-use-rtsss-scanline-sync-to-reduce-stuttering-screen-tearing-and-input-lag-on-pc-alternative-to-vsync-g-sync-and-freesync.138764/
Kommentaarid: 89 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 79
olafsand
olafsand
sõnum 27.09.2020 23:00:16 vasta tsitaadiga
Tomorrow, suur tänu! Homme rahulikult lahkan need teemad läbi siis icon_smile.gif
Kommentaarid: 60 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 57
majooro
majooro
sõnum 29.09.2020 20:43:13 vasta tsitaadiga
https://www.nvidia.com/Download/driverResults.aspx/164741/en-us
Game Ready Drivers provide the best possible gaming experience for all major new releases. Prior to a new title launching, our driver team is working up until the last minute to ensure every performance tweak and bug fix is included for the best gameplay on day-1.
Game Ready for NVIDIA Reflex Support for ‘Call of Duty: Modern Warfare’ and ‘Call of Duty: Warzone’
Our latest GeForce Game Ready driver provides support for NVIDIA Reflex in the blockbuster titles, Call of Duty: Modern Warfare and Call of Duty: Warzone, as well as offers the best experience in Star Wars: Squadrons. The new Game Ready Driver also improves stability in certain games on RTX 30 Series GPUs.
Installisin koos Call of Duty: Modern Warfare & Warzone Seasone 6 Update'iga ja FPS kukkus 180 pealt 40 peale. Kellelgi veel sarnane probleem?
Praegu panin puhta süsteemi arvutisse ja proovin uuesti.
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 29
Aeg maha 1p
sõnum 30.09.2020 02:21:03 vasta tsitaadiga
LOL, ma vist siis ei uuenda.
Kommentaarid: 195 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 181
majooro
majooro
sõnum 30.09.2020 11:35:32 vasta tsitaadiga
Lükkasin puhta Windows'i peale, draiverite installimisel kasutasin NVCleanstall ja kõik hakkas toimima. FPS 150-180 ja input väga terav! Samas kiilus mäng mingi aja pärast kinni (2070 Super), mida siiani pole mul juhtunud. Sama sõbral (1080 Ti, uus Windows, viimased draiverid). Nii et miski tundub olevat toores.
Aspiriin
Aspiriin
sõnum 01.10.2020 08:02:57 vasta tsitaadiga
Mul jooksis samuti kokku peale driverite uuendust.
Puhast installi pole proovinud veel. Teen mängule kõigepealt reinstalli.
Aeg maha 1p
sõnum 14.01.2021 17:27:17 vasta tsitaadiga
Mingi väga huvitav asi Dynamic Super Resolutioniga lambist hakanud... native reso 1080P ning mängudes kasutan 1440P (et prose bottlenecki vähendada, lisaks paremale pildile :lol). Hiljuti hakkas selline jama peale, et 1440P peal on Steam-i overlay mega väikese reso peal, ehk interface on väga suur. Lisaks näen, et mängu all olev muu desktop jne. on mingi tabaluku suuruse peal, lülitab ümber kui väljud mängust või alt-tabid.
Netist nagu midagi ei leia... ütleks, et see DSR on kõvasti halvem kui AMD vaste VSR, mille puhul paned linnukese, et tahad kasutada ja resod lisatakse kõik otse menüüdesse. Nvidial roni "kapoti alla" ja sealt ükshaaval enable-i, seejuures kordajaga, mitte resolutsiooni järgi, seega see juba eos paras tüütus. Nüüd siis siuke viga ka kopp.gif
EDIT: üpris absurdne, et notificationeid salvestistel kuvab - AMD puhul saab kuvamist valida.
EDIT: kas uusimas Win10-s on non-DCH installer keelatud?
EDIT 2021: Kolisin 1080p 60Hz pealt 1440p 165Hz ja avastasin, et GFE ei suuda >60Hz salvestada? Mis mõte sel on? icon_lol.gif
Ma muidugi ei tea, kas AMD vaste seda suudab, ei saanud seda seal testida.
sõnum 15.06.2021 16:32:05 vasta tsitaadiga
Support Plan for Windows 7 and Windows 8/8.1
https://nvidia.custhelp.com/app/answers/detail/a_id/5201/related/1
Effective October 2021, Game Ready Driver upgrades, including performance enhancements, new features, and bug fixes, will be exclusively available for systems utilizing Windows 10 as their operating system. Critical security updates will be available on systems utilizing Windows 7, Windows 8, or Windows 8.1 through September 2024.
jtz
sõnum 30.06.2021 12:59:47 vasta tsitaadiga
Tekkis selline mure.. ehk keegi oskab nõu anda...
Nimelt kuidas muuta GeForce Experience In-Game Overlay hotkey ära?
Default on Alt+Z -> selle jah saan muuta näiteks Ctrl+Alt+X... Kuid AltGr+Z jääb ikkagi toimima! See aga ei sobi üldse kuna AltGr+Z = ž ja Ž mis igapäevaselt kasutuses kirjamärgid. Ehk mure siis see kui ž vaja avaneb hoopis in-game overlay..
On kellelgi kogemusi äkki?
Inflation Nation
SirAskAlot
sõnum 30.06.2021 14:04:32 vasta tsitaadiga
jtz kirjutas:
Mul küll töötab.
(hotkey muutmine siis)
viimati muutis SirAskAlot 30.06.2021 14:05:27, muudetud 1 kord
WäntWõll
make.believe
WäntWõll
sõnum 30.06.2021 14:05:10 vasta tsitaadiga
Üheselt pead ära muutma combost või välja jätma ALT variatsioonid.
Kommentaarid: 373 loe/lisa Kasutajad arvavad:  :: 1 :: 2 :: 299
jtz
sõnum 30.06.2021 21:18:10 vasta tsitaadiga
WäntWõll kirjutas:
Täpselt nii oligi. Proovitud, tehtud, toimib.
Inflation Nation
sõnum 30.06.2021 22:10:07 vasta tsitaadiga
jtz kirjutas:
altgr = ctrl + alt.
lihtsa näitena, ctrl + alt + z = ž.
- londiste
Kommentaarid: 238 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 213
WäntWõll
make.believe
WäntWõll
sõnum 30.06.2021 22:17:08 vasta tsitaadiga
Kõiik kes on töötanud est klavkaga teavad alt z ja ž asju.
jtz
sõnum 01.07.2021 09:00:54 vasta tsitaadiga
londiste kirjutas:
altgr = ctrl + alt.
beer_yum.gif tänud, kirjeldab miks AltGr toimima jäi minu puhul.
WäntWõll kirjutas:
ära siin üldista icon_lol.gif -> näe üks vanamehest clown.gif siin nüüd ei teadnud.. (mina) dance.gif
Aga lahendus jah, ALT kombinatsioonidest üldse välja võtta.
Inflation Nation
NATAS999
sõnum 01.07.2021 10:30:49 vasta tsitaadiga
WäntWõll kirjutas:
mis mõttes ei mõista? klaviatuuril on 2 alt klahvi, vasakpoolne on harilik alt ja parempoolne on altgr. altgr teeb sama asja, mis alt+ctrl. mitte mingisugust ž tähte sa alt+z kombinatsiooniga ei saa. ž tuleb kombinatsiooniga altgr+z või alt+ctrl+z. üli vana nali juba.
"Kuidas on see hea?"
-Auto kirurgia kliinik
sõnum 12.10.2021 19:08:44 vasta tsitaadiga
NVIDIA Releases Game Ready 496.13 WHQL GeForce Graphics Driver, Support Removed for Windows 8.1/8/7 & Kepler
https://www.techpowerup.com/287749/nvidia-releases-game-ready-496-13-whql-geforce-graphics-driver-support-removed-for-windows-8-1-8-7-kepler
472.12 on siis viimane mis ametlikult Keplerit toetab aga kuna Kepleri tugi on ainult .INF failist eemaldatud, siis lihtsa modimisega peaks toe tagasi saama.
Ühtlasi eemaldatud Win 7, 8 ja 8.1 tugi aga ma ei tea kas selle saaks samuti tagasi modimisega.
Suurem probleem on see, et edaspidi on kõik DCH versioonid. Ehk siis kontrollpaneeli kasutamiseks tuleb see eraldi alla laadida ja paigaldada läbi selle neetud Micro$oft $tore thumbs_down.gif
Gap
Gap
sõnum 12.10.2021 20:36:11 vasta tsitaadiga
Tomorrow kirjutas:
Neil on vist kole igav.Juba mingite augusti kuu driveritega oli mul selline pull.mõtlesin et mida kuradit icon_eek.gif Koguaeg on driveritega installitud ilusti ka control panel.aga ohh ei üks geenius mõtles et teeme asja huvitavamaks ja kasutame seda stta microsoft storet ka veel thumbs_down.gif
Kommentaarid: 20 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 16
sõnum 12.10.2021 21:20:51 vasta tsitaadiga
Tuleb kasutada seda siis: https://www.techpowerup.com/download/techpowerup-nvcleanstall/
Added tweak to install NVIDIA Control Panel app from Microsoft Store (without Microsoft account), DCH drivers only
Aeg maha 1p
sõnum 12.10.2021 22:58:35 vasta tsitaadiga
Oot, tavalisi draivereid ei saa enam koos control paneli ja GFE-ga? Või on mingi võimalus? Kasutan ka salvestust...
olafsand
olafsand
sõnum 13.10.2021 10:25:17 vasta tsitaadiga
rmc, +1
sõnum 13.10.2021 10:52:23 vasta tsitaadiga
rmc, Tundub jah, et nüüd on R495 branchi ja edasised draiverid kõik DCH. Isegi allalaadimislingi manipuleerimine (dch tähtede eemaldamine lingist) ei toimi enam.
NATAS999
sõnum 13.10.2021 11:04:57 vasta tsitaadiga
ausalt öelda see nvcp on juba kõva kümmenkond aastat ilgelt uimane. selle asemel, et korda teha, roogitakse üldse välja ja asendatakse mingi veel õudsema asjaga thumbs_up.gif, tubli töö, mehed, tubli töö. thumbs_up.gif
Aeg maha 1p
sõnum 13.10.2021 11:10:01 vasta tsitaadiga
NATAS999
sõnum 13.10.2021 11:35:54 vasta tsitaadiga
rmc kirjutas:
ei soovi amd'st kuulda ega näha ka midagi.
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia GeForce ForceWare Driverid mine lehele eelmine  1, 2, 3 ... , 111, 112, 113  järgmine
